    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 02-28-2015, 09:58 AM   #12061
aeRayls's Avatar
Originally Posted by Jpdanger View Post
Anyone try the new FT +4mm aluminum arm mount? Is it worth the upgrade?
I've got mine, just waiting on a track day. It's important to note that you also need the narrower 5mm rear hex as well.
This should prove to be a good tuning option when on high grip and carpet and will some stability to the car.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 02-28-2015, 12:35 PM   #12062
When you say stability, does that translate to increased resistance to traction rolling?
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 02-28-2015, 12:40 PM   #12063
air8's Avatar
Originally Posted by Jmuck69 View Post
I got a 4x4 piece of marble. It has a really flat surface and place the paper on it. Use motor spray to lube the paper. Makes it nice and flat. No need to but the expensive aftermarket rings that are way overpriced.
I've only purchased the AE diff rings. Guess I didn't know there were others that fit. Good to know wet sanding the rings works as well. Yet again that is something I have thought of before, but just never tried it.
Glad to see others are sanding the diff rings. Sometimes I wonder if I'm doing something wrong when people at the track look at me weird for wasting the time to sand the rings. Like Razathorn said, sometimes the new rings have something on them, or imperfections on the surface.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 02-28-2015, 03:10 PM   #12064
gooba's Avatar
+1 on sanding rings I like a nice fine crosshatch on mine. Question for the guys who have gone with Velcro to hold the body on are you shaving the front body mount off the top plate or do u still use it?
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 02-28-2015, 03:16 PM   #12065
Whats the best savox servo anyone has tried for the b5m. Money is not an issue. I currently have a spare 1258tg, sv1274mg, and a sb2275mg...
b4.1 FT hobbywing justock 17.5t
b5m
Moyanator609 is offline   Reply With Quote
Old 02-28-2015, 03:38 PM   #12066
Cridd's Avatar
Trader Rating: 16 (100%+)
I shaved it off so I don't have to cut a hold in my body up front.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 02-28-2015, 03:39 PM   #12067
vito's Avatar
set timeing in the motor or boost in the esc
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 02-28-2015, 04:29 PM   #12068
aeRayls's Avatar
In theory yes
Old 02-28-2015, 06:24 PM   #12069
HYPERformance06's Avatar
I'm running the 1258tg,I've had no issues in my b4.2 and the b5m. Works great and plenty fast
HYPERformance06 is offline   Reply With Quote
Old 02-28-2015, 06:41 PM   #12070
I just put the 1258tg on my FT B4.1. And the sv1274mg on the b5m.
b5m
Old 02-28-2015, 08:51 PM   #12071
air8's Avatar
After the mod race tonight, we did musical cars like people often do. I drove a friends B5M and it was on fire. I couldn't believe how that car felt. I mean hard acceleration, quick quick quick in all corners, and jumped like I always imagine a pro car would. None of us are even close to pro by the way. It was flat out awesome, didn't want to give the radio back. LOL. However I was lucky enough to still get the W. The others made more mistakes than I did is all.
Unless he is hiding his setup it is setup the same as us other four B5M users. Same radio, different ESC (Orion), and 7.5 motor instead of 8.5, same tires, pretty identical electronics layout. His car is the newest of us all at three weeks old but Wow what a car. I'm unsure how he builds his shocks and diff but it was an amazing feeling car. So smooth, tons of grip, and mucho side bite.
I just bought a conversion kit for my B5R and i'm gonna hope it turns out nearly as awesome. LoL.
--"U Ain't Fast!!"
Chris Pearce
Old 02-28-2015, 09:32 PM   #12072
kdub's Avatar
Here is the link to Download my setup sheet for a Associated B5M for the 17.5 Stock 3-Gear Gen1.
http://dialedsetups.com/sheets/downl...-gen1-1735.pdf
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 02-28-2015, 10:51 PM   #12073
Trader Rating: 29 (100%+)
When did you start running stock? I think its cool.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 03-01-2015, 01:25 AM   #12074
air8's Avatar
How do you arrive at 3 wing angle? My brain isn't picking up on how to set the wing shim for 3. LOL.
--"U Ain't Fast!!"
Chris Pearce
Old 03-01-2015, 01:48 AM   #12075
Razathorn's Avatar
I believe the wing mount is 6, then the shim forward makes 9, and the shim backwards makes 3. Run the shim on top in any orientation for 6.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
