    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 02-25-2015, 03:58 PM   #11956
AE-Reedy
Originally Posted by Nat Maniac View Post
I have it installed as it came with it but still have the slop,i cant help but think i must be doing something wrong.
http://youtu.be/KPhC9hlnekE
You have it right. There is nothing wrong with what you show in the video.
It's better to be free and not have any binding.
Sean Cochran is offline   Reply With Quote
Old 02-25-2015, 04:13 PM   #11957
Nat Maniac's Avatar
Thanks for taking the time to look.
What I am trying to rationalize is if the the original design (out of the box stock standard) called for no slop (shock on the right rear) which I agree with, then why release a FT version that allows for 2mm of slop.
More slop = less consistent and over time damaging to that part.
Either I've not installed it correctly or poor inconsistent design from AE.
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 02-25-2015, 04:16 PM   #11958
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
the plastic caps do wear. My plastic caps have to be replaced every 5-6 months
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-25-2015, 04:28 PM   #11959
Trader Rating: 486 (100%+)
I already gave you the part # you need to reduce the "slop". Do I need to post pics? All 3 of my b5ms have the bushing ball insert things....
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 02-25-2015, 04:28 PM   #11960
Nat Maniac's Avatar
Even if they were worn shouldn't there be equally as much slop on the standard brushing as the FT if the design was consistent?
Old 02-25-2015, 04:29 PM   #11961
mine are the same as yours. I would not worry about it. I also have some AVID standoffs. Same thing. I actually think your kit ones are a problem. My kyosho and tlr cars also floated front to rear.
Old 02-25-2015, 04:36 PM   #11962
Nat Maniac's Avatar
Originally Posted by QDRHRSE View Post
I alrrady gave you the part # you need to reduce the "slop". Do I need to post pics? All 3 of my b5ms have the bushing ball insert things....
I already have them installed, you can see from the you-tube clip. I actually ordered them separately thinking that the blue brushing did'nt come with them but they do.
So you're saying that you don't have the same slop issue even though you're using the same parts? Perhaps I got two batches of bad parts...
In any case I've removed them for now, I prefer a the original parts with no slop.
Thanks everyone for your feedback.
Old 02-25-2015, 05:01 PM   #11963
Trader Rating: 14 (100%+)
Since i couldn't find an actual answer, the aluminum screw kit saves.......
12 grams.
Oh well
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 02-25-2015, 05:05 PM   #11964
AE-Reedy
The reason your kit ones do not move is because you can crush them when you tighten them. This is binding and not good. There is nothing wrong with the FT mounts and everyone runs them with that little play front to back. You will never notice it when the car is on the track.
Old 02-25-2015, 05:09 PM   #11965
Mason's Avatar
Slap an old red o-ring on the standoff and call it a day already.
Mason is offline   Reply With Quote
Old 02-25-2015, 06:04 PM   #11966
gooba's Avatar
Run it with slop. Loose fitting AE cars are normal and fast
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 02-25-2015, 06:23 PM   #11967
These statements are silly
XFactory X6^3, XFactory SCX-60CF, Durango DEX410v3
All Kyosho damped with Viper Power and SMC Juice
Serpent SRX-2MM, Serpent 811E
VBC Firebolt DM
Barge is offline   Reply With Quote
Old 02-25-2015, 08:35 PM   #11968
Trader Rating: 29 (100%+)
Sean is right... the more you tighten the kit standoff the more it will crush the plastic and cause it to be tight like it is in the vid. The FT however will not crush so it lets the shock be free and have play like it should. With his kit ones I guarantee that when you fully compress that side and try and wiggle or spin the shock it is completely stuck and thats not good and WILL cause your car to behave strangely. Put the FT standoffs on and snug the nut down and make sure the shock is free when fully compressed, then your cars suspension will be performing as it was designed. Hope this helps you.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 02-25-2015, 08:37 PM   #11969
I guess I'm not sure what we're calling slop. The shock is supposed to sort of swivel on the shock bushing ball. Mine move but do not really have any slop. If the movement is the issue then don't worry about it. They are not supposed to fixed in place at the top.
Old 02-25-2015, 08:58 PM   #11970
He is referring to the movement fore and aft. (forwards and backwards) as far as I can tell because I didnt see it moving up and down much which it shouldnt.
