    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 02-16-2015, 11:22 AM   #11671
Mason's Avatar
he's looking for 25mm, not 40mm.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 02-16-2015, 11:31 AM   #11672
air8's Avatar
I usually get 10th scale fans from a local electronics store. The guy charges $4.50 per fan for a 25mm. One of three died after a full winter indoor season. The other two lasted the following season, but then I got new ESC's which came with fans.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 02-16-2015, 12:10 PM   #11673
MikeXray's Avatar
Trader Rating: 73 (100%+)
Minor tip on fans and wires, glue the wires to the fan with ca so they don't break off the circuit board, then you have a bit you can usually chisel and attach a new wire too.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-16-2015, 01:21 PM   #11674
VoyageRC.com's Avatar
nice tip, just don't get any glue on any moving parts.
Someone take the ".com"
off my user name
www.youtube.com/voyagercchannel
VoyageRC.com is offline   Reply With Quote
Old 02-16-2015, 01:33 PM   #11675
Mason's Avatar
might be able to do it with shoe-goo, or the like as well.
Mason McCombs
Old 02-16-2015, 02:29 PM   #11676
Trader Rating: 51 (100%+)
Default Brass
Originally Posted by QDRHRSE View Post
I pretty much only run stock. My home track is outdoors. In the winter when we run the track wet its near freezing on race nights. Traction is really low. Not only do I run the brass C & D blocks, I also run a square pack to add weight. We're back to dry blue groove and its been freakishly warm so its back to a light car.
Thanks QDRHRSE!
mrueye is offline   Reply With Quote
Old 02-16-2015, 02:37 PM   #11677
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I use shoe goo. it the wires snapped after the shoe goo from the vibration of the lead going to the receiver.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-16-2015, 03:44 PM   #11678
I ordered some yeah racing tornado 25mm fans. I have seen some pretty good reviews on them and go-nitro had a good price.
Old 02-16-2015, 05:30 PM   #11679
I did some searching and reading after asking about the inline setup earlier. I think my track is probably one of the best fits for an inline battery that you will find so I decided to go for it this afternoon. Here's what I ended up with.
I really like how much it cleaned up the wiring. I could have shoehorned everything in there without cutting all three cross braces but I wanted some room between the battery and the ESC/servo so I hacked them all.
I notched my stock battery hold-down to clear the bullet connectors. That should get me through the race this weekend but I plan to find a CF brace that fits better.
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 02-16-2015, 05:37 PM   #11680
I have a suggestion for page one. When I got my swaybar kit I tried searching for how to install it before I opened the package. It was hard to find anything. Once I opened the package it was easy to figure out but it could be helpful to have a note about it. Below are pictures from couple different angles. If they aren't clear enough I can get out the real camera instead of using my iPhone.
Hot Bodies D413
AE B5M, T5M
Old 02-16-2015, 05:43 PM   #11681
Trader Rating: 14 (100%+)
What gearing are you guys running that needs a fan on the motor?
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 02-16-2015, 06:29 PM   #11682
72/32
Old 02-16-2015, 06:48 PM   #11683
Suspended
Trader Rating: 61 (100%+)
Very tall for a 17.5.
32x69 with 60 degrees of timing. Coming off right now about 125.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 02-16-2015, 07:33 PM   #11684
air8's Avatar
69/32 for 13.5 and 69/34 for 17.5
--"U Ain't Fast!!"
Chris Pearce
Old 02-16-2015, 07:59 PM   #11685
I dont run a fan because I "need", I run a fan because it is insurance. Less power fade with a cooler motor and longer motor life. I gear my motors for about 150 without a fan, then add a fan to drop temps to 125. this way if my fan fails, I wont fry the motor. last weekend my fan failed and I came off at 150.
Also, we run 5 minute quals and 8-10 minute mains. 150 over 5 minutes becomes 170+ over 8 minutes. Most everyone here is running fans in 17.5. I would not bother in mod.
