    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 02-13-2015, 12:51 PM   #11611
onefast8's Avatar
Trader Rating: 41 (100%+)
Originally Posted by iScream View Post
Hmm, I'm liking the gold rims. Forgot that I already have the aluminum hexes. Edited the post above.
I don't know what C&D mounts is though.
They are both the rear arm mounts. You will need to order the inserts also.
Jake R.
onefast8 is offline   Reply With Quote
Old 02-13-2015, 01:58 PM   #11612
BS-Racing's Avatar
I need $20 more stuff so I can apply a Tower Hobbies coupon. Or, I could add $50 more stuff to apply a different coupon.
What would you guys get for a B5M for $20 or $50? I have some spare front arms already but that's about it.
I'm running a 13.5 motor.
Racing on a pretty tight carpet track with pin tires so super high grip and I already have the stuff below installed.
Gear diff
3 gear tranny
Aluminum rear hubs
Aluminum hexes
Ti turnbuckles
Ti front axles
Sway bar kit
Red front springs
Blue rear springs
Aluminum steering set
Rear Camber Block
B5M
BS-Racing is offline   Reply With Quote
Old 02-13-2015, 02:56 PM   #11613
bilster44's Avatar
Originally Posted by HYPERformance06 View Post
lighten the rotational mass even more.
Been there...do that
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 02-13-2015, 03:23 PM   #11614
HYPERformance06's Avatar
yea u gave me the idea to run parma and ti screws lol. the parma gear actually helps out alot on a tini track with big jumps right after a 180 turn
Patrick Hertel
B5M - Trinity d4 17.5 1s ss
As I lay rubber down the street.
I pray for traction I can keep, but if I spin
And begin to slide, please dear god protect my ride.
HYPERformance06 is offline   Reply With Quote
Old 02-13-2015, 07:27 PM   #11615
thecman26's Avatar
Trader Rating: 99 (100%+)
What are these gold rims people are speaking of?
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 02-13-2015, 08:25 PM   #11616
vito's Avatar
rc cars are like women all the same but so different
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 02-13-2015, 09:01 PM   #11617
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
what parts are NEEDED for 3 gear tranny conversion? gear case, gear cover. can i use my existing alum top shaft? are the three gears in the case different? if they are, does anyone sell them cut?
thanks.
RC*PHREAK is offline   Reply With Quote
Old 02-13-2015, 09:10 PM   #11618
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
New topshaft same gears
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-13-2015, 09:18 PM   #11619
RC*PHREAK's Avatar
thanks. also what's everyone's preference for where/which cut gears to use?
Old 02-14-2015, 06:37 AM   #11620
Trader Rating: 75 (100%+)
thanks.
I just pieced a 3-gear transmission together this week. You will need:
3-gear case
3-gear motor plate
3-gear spur cover
3-gear top shaft
(2x) 5x10x4 bearings. The 3 gear aluminum top shaft rides on smaller bearings compared to the 4 gear transmission which uses 6x12x4 .
(2x) diff shims (#1733). The B5M Lite manual lists 2 diff shims and they are correct because when I installed the diff in the three gear transmission case there was a lot of lateral movement between the diff and cases. The shims eliminated most of that play.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 02-14-2015, 07:45 AM   #11621
I have been running them without issue. they definitely make everything more free and smoother. I run on high bite and have had the same set in for months.
Old 02-14-2015, 07:47 AM   #11622
3-gear case
3-gear motor plate
3-gear spur cover
3-gear top shaft
I think shimming is a tolerance thing. I didnt have to shim mine, but other have. I had to shim my 4 gear, but with the same diff, I didnt have to shim the 3 gear /weird
Old 02-14-2015, 08:47 AM   #11623
RC*PHREAK's Avatar
Thanks. I meant where did you get yours from. Like do people have a preference for someone's cut gears. A google search only showed CB's cut gears. I don't know if anyone else out there makes them.
Old 02-14-2015, 08:49 AM   #11624
RC*PHREAK's Avatar
3-gear case
3-gear motor plate
3-gear spur cover
3-gear top shaft
Thanks!
Old 02-14-2015, 09:20 AM   #11625
cb's are the main one. the guy that does it is local to me. u can do it yourself if u feel like you can. lay the gear flat on sandpaper and go to town, belt sander helps alot
Patrick Hertel
