    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 02-13-2015, 10:11 AM   #11596
The screw should always go on the "passenger side" of the vehicle. If installed on the other side, the rotation will cause the diff adjustment to loosen.
Originally Posted by Logi Maker View Post
Count the gears. Shot from the B5m lite manual. To each his own. I always run it towards the spur to remember which side the head is on.... all adjustments (slipper, gear mesh, diff) on the same side.
Spikesef is offline   Reply With Quote
Old 02-13-2015, 10:18 AM   #11597
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
So by installing it in this "correct" position it will then cause the diff to tighten?? We really need a whole thread dedicated to this subject. As said earlier, it does not matter which side it goes in. If you were to break a thrust (how often does that happen?) it could matter, but it is up to you on which side it is easier adjusted from.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 02-13-2015, 10:20 AM   #11598
Jordan Anderson's Avatar
How many grams of weight to you save going to Titanium screws on the B5M?
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 02-13-2015, 10:22 AM   #11599
shannow's Avatar
Then your thrust bearing isn't working. If it loosens while accelerating (or going left hand corner for example) it would then tighten while braking (or going right hand corner for the example).
shannow is offline   Reply With Quote
Old 02-13-2015, 10:22 AM   #11600
HYPERformance06's Avatar
exotek slipper emininator screws are comfirmed to be 3x5mm. i contacted them directly. just incase anyone else wants to lighten the rotational mass even more.
Patrick Hertel
B5M - Trinity d4 17.5 1s ss
As I lay rubber down the street.
I pray for traction I can keep, but if I spin
And begin to slide, please dear god protect my ride.
HYPERformance06 is offline   Reply With Quote
Old 02-13-2015, 10:22 AM   #11601
Super Moderator
I read in the range of 30-35 grams if replacing all the screws with titanium. I have not done mine yet though to verify...and when i do i dont plan on doing all of them, probably skip the underside screws.
Old 02-13-2015, 10:38 AM   #11602
Thomas PA's Avatar
I believe the 83 piece set saves a tick over 20 grams.
-Thomas Kauffman
KDRC Carbon Fiber Upgrades
Bumps & Jumps RC, Pit Stop Hobbies
X6^3: Tekin, Fantom, Sav÷x
B5M: KDRC, Fantom, hobbywing, Sav÷x, Schelle, AC RC
Thomas PA is offline   Reply With Quote
Old 02-13-2015, 10:40 AM   #11603
why would u skip the pan screws? i did the full kit swap and it was pretty quick todo. i waited to rebuild my diff before i did the trans
Patrick Hertel
Old 02-13-2015, 11:57 AM   #11604
Mason's Avatar
Originally Posted by air8 View Post
Trailing axle inserts--Can the insert be moved back and forth without wrecking the setup? Like how critical is it to move the front wheelbase at the same time?
If you did not adjust the other stuff you would be messing with ackerman and that could alter the car a bit. Why don't you try it and tell us how it altered your car's drive-ability?
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 02-13-2015, 11:58 AM   #11605
Mason's Avatar
Speaking of pan screws.. I can't wait to hear about how such and such removed every other screw or loosened them x amount of turns and now his car is dialed.
Mason McCombs
Old 02-13-2015, 12:27 PM   #11606
raceguy13's Avatar
I did full Lunsford screw kit, front axles, and 4.8mm ball studs and removed 45 grams or so, plus got free moving ball cups out of the deal.
raceguy13 is offline   Reply With Quote
Old 02-13-2015, 12:35 PM   #11607
I need $20 more stuff so I can apply a Tower Hobbies coupon. Or, I could add $50 more stuff to apply a different coupon.
What would you guys get for a B5M for $20 or $50? I have some spare front arms already but that's about it.
I'm running a 13.5 motor.
Racing on a pretty tight carpet track with pin tires so super high grip and I already have the stuff below installed.
Gear diff
3 gear tranny
Aluminum rear hubs
Aluminum hexes
Ti turnbuckles
Ti front axles
Sway bar kit
Red front springs
Blue rear springs
Aluminum steering set
Tekno EB48.2, ET48, SCT410
Hot Bodies D413
AE B5M, T5M
38.4 percent of RC tuning is 75 percent placebo effect
87.26 percent of statistics are just made up
iScream is offline   Reply With Quote
Old 02-13-2015, 12:42 PM   #11608
onefast8's Avatar
Trader Rating: 41 (100%+)
1.) Gold rims all the way around
2.) Alum Hexes
3.) Avid clutch
4.) C&D mounts
Also a small list here. Scroll down. Team Associated RC10 B5m Mid-Motor Thread
Jake R.
onefast8 is offline   Reply With Quote
Old 02-13-2015, 12:46 PM   #11609
2.) Alum Hexes
3.) Avid clutch
4.) C&D mounts
Hmm, I'm liking the gold rims. Forgot that I already have the aluminum hexes. Edited the post above.
I don't know what C&D mounts is though.
Hot Bodies D413
AE B5M, T5M
Old 02-13-2015, 12:47 PM   #11610
vito's Avatar
got a call from the dr all is good go back in 3 mo i can eat now thank you my god you are awesome for sur
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
