    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 02-12-2015, 09:26 AM   #11551
MikeXray's Avatar
Trader Rating: 73 (100%+)
It matters if your thrust fails, that is all, in the right way, the diff will tighten and you can finish a race, on the left side, it will loosen.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 02-12-2015, 09:33 AM   #11552
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
I have been racing for 17-18ish years....never have I had a thrust fail. Maybe im not trying hard enough.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 02-12-2015, 10:05 AM   #11553
vito's Avatar
and update donig ok fill fine got a new body to paint cant do much
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 02-12-2015, 10:14 AM   #11554
MikeXray's Avatar
So that means its not possible?
Old 02-12-2015, 10:17 AM   #11555
Super Moderator
No, that means im not trying hard enough.
Old 02-12-2015, 10:25 AM   #11556
If the screw is on the right side and the thrust fails, big if, the diff will loosen if the left wheel spins and tighten if the right wheel spins.
If you put the screw on the left side, the same thing happens.
As already stated, it doesn't matter.
Cautrell05 is offline   Reply With Quote
Old 02-12-2015, 10:48 AM   #11557
Razathorn's Avatar
Yeah, I have people tell me it matters all the time, and I'm like, dude, 4wd ball diffs. The front is in backwards. Logic!
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 02-12-2015, 10:49 AM   #11558
Originally Posted by Wildcat1971 View Post
so you are running a gear diff and slipper eliminator, and are getting a high pitched squeal from the rear of the car?
Leigh
You Aint right......hahahahah
Bubonic-X is offline   Reply With Quote
Old 02-12-2015, 12:46 PM   #11559
BS-Racing's Avatar
It doesnt matter. It is user preference, whichever way allows you to make needed adjustments easier.
B5M
BS-Racing is offline   Reply With Quote
Old 02-12-2015, 01:09 PM   #11560
+1 Take apart your tranny and trouble shoot it. a high pitched squeal from a gear diff sounds very odd.
Have you checked the motor? Remove pinion and give it a rev... just not too much.
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 02-12-2015, 02:03 PM   #11561
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Logi Maker View Post
I had AE put that back in the manual so people would stop asking.
If it matters, why does TLR have you put it on the opposite side?
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 02-12-2015, 02:21 PM   #11562
shannow's Avatar
If it matters it would only be because of a fitting problem (if not symmetrical). If it fits then it's almost certainly symmetrical.
Otherwise is it was symmetrical and somehow mattered then it would mean the car would diff better turning right hand than left hand (or the opposite).
PS: BTW I went cheap to try out the 3 antisquat without the whole brass/aluminium parts by putting a 1mm washers under the C 3+2 arm mount (sandwiched by each screws).
shannow is offline   Reply With Quote
Old 02-12-2015, 02:21 PM   #11563
AE-Reedy
For guys who were wondering about the Lite Chassis weight, it is 104g.
Savings of about 25g over the original.
Sean Cochran is offline   Reply With Quote
Old 02-12-2015, 02:29 PM   #11564
onefast8's Avatar
Trader Rating: 41 (100%+)
Nice! Hopefully its around $40.
Jake R.
onefast8 is offline   Reply With Quote
Old 02-12-2015, 02:37 PM   #11565
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
YESSSSSSS. right where I wanted it... now get them in stock please
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Crazyybikerdude
