    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-31-2015, 06:27 AM   #11131
Thomas PA's Avatar
Originally Posted by onefast8 View Post
How much lighter was the chassis the guy from FB was doing? From the pics it looks like the AE light one is super milled out. Wonder if it'll be 20-30+ g lighter than stock?
Stock chassis on Amain is $47 bucks, hope the light one is somewhere in that ball park,
If your talking about the guy with the carbon one, my carbon chassis dropped 68g off my weight
-Thomas Kauffman
KDRC Carbon Fiber Upgrades
Bumps & Jumps RC, Pit Stop Hobbies
X6^3: Tekin, Fantom, Savöx
B5M: KDRC, Fantom, hobbywing, Savöx, Schelle, AC RC
Thomas PA is offline   Reply With Quote
Old 01-31-2015, 06:28 AM   #11132
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Cpt.America View Post
hhhm... I tend to be the guy that will buy the bling and spend money I probably shouldn't' spend on my RC gear... but even I won't spend $150 on that when AE has one for $10. (or whatever it costs). BUT.. that is just the MSRP. I bet you will be able to buy it for less.
Same for me - I can justify something expensive if it gives me a good benefit.
I can't justify this.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 01-31-2015, 06:58 AM   #11133
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
The SLRC is like 25g lighter. It is also thinner. I think 2mm instead of 2.5mm.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-31-2015, 09:25 AM   #11134
Logi Maker's Avatar
Trader Rating: 49 (100%+)
We talkin milled chassis?
https://plus.google.com/photos/10712...897?banner=pwa
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 01-31-2015, 09:33 AM   #11135
gooba's Avatar
So for you guys with carbon chassis and all the lightweight parts where are you adding weight and what are you using to make ROAR legal weight of 1499g?
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 01-31-2015, 09:52 AM   #11136
Thomas PA's Avatar
I run a 4600mah battery, a full size servo, and a castle esc. No weight needed! Haha
But when I did try adding a little, I used it get a perfect 50/50 side to side and 60/40 rear to front
If you need steering, put it under the steering stuff. If you need rear traction, under the motor or on the rear of the tower. Keep it as low as possible. Brass parts are pricey IMO but if you don't mind the $, they are nice sometimes
-Thomas Kauffman
Old 01-31-2015, 10:17 AM   #11137
Will mip b5m pucks work with ae 3 gear transmission?
Micah123 is offline   Reply With Quote
Old 01-31-2015, 10:19 AM   #11138
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Yes, it is the exact same diff.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-31-2015, 10:36 AM   #11139
gooba's Avatar
My car makes weight just fine. Im just reading the new lite car is 75g lighter than a b5m and ive seen several posts about carbon fiber chassis dropping 60+ grams. with my car weighing in at 1544g dropping that much weight puts me and anyone else underweight by quite a bit. It seems like everyone keeps saying you need to drop as much weight as possible with no regard for the rules. Ive seen this happen far too many times racing onroad people dump weight and fail tech or get DQed after their race.
Old 01-31-2015, 11:13 AM   #11140
Trader Rating: 18 (100%+)
my b5m has xfactory chassis, light weight top shaft, pucks and slipper eliminator, with a 210gram battery i was light, added jconcepts chassis protector and im at 1506grams race ready
customss is offline   Reply With Quote
Old 01-31-2015, 11:24 AM   #11141
xyzracer's Avatar
Originally Posted by Cridd View Post
It would be a bling monger. Throw some chrome rims on there and bam, cruiser. May get it and chrome my battery .
hahahahah......awesome
xyzracer is offline   Reply With Quote
Old 01-31-2015, 11:41 AM   #11142
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
The point of getting the car as light as you can... gives you few advantages. Here are some points:
1. You don't run the car UNDERweight
2. Being at weight or uderweight, then lets you ballast for better F/R or L/R balance.
3. Being lighter and ballasted allows better flexibility for changing the car's overall weight for traction and response tuning. If your car is at 1700 grams, and traction comes way up and it is now time to lighten up the car... and you have nothing you can take off... how do you tune your weight? You can't.. your stuck. You're better off being lighter and adding where needed.
4. And last but not least... if you have a much lighter car, you can run a higher MAH battery. Maybe even a full sized square pack. ALWAYS put your weight in your pack if possible (running stock) as there is a voltage advantage in a higher MAH pack.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-31-2015, 12:29 PM   #11143
vito's Avatar
ae gear box or mi one help I cant drop 150 right now
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 01-31-2015, 12:57 PM   #11144
Originally Posted by Mason View Post
2 fold issue. weight and you can use smaller gears such as 66 if you really feel the need.
And to answer the other guys question even when you have a slipper locked down it still has more give than an eliminator which has NONE! I didn't believe it until I ran an eliminator in dusty conditions bc I had my slipper almost locked before and it still had some give. But another positive is that the eliminator is lighter so less
Thnx guys. This thread is so active, it's hard to keep up.
ocpop is offline   Reply With Quote
Old 01-31-2015, 03:22 PM   #11145
What transmission is Drescher running?
C.Borgia is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
JsK
