    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 01-30-2015, 01:55 PM   #11101
Question for those who use a slipper eliminator. Why not just tighten down your stock slipper so it doesn't slip?
ocpop is offline   Reply With Quote
Old 01-30-2015, 02:01 PM   #11102
I still run a slipper in stock. I prefer a small amount of slip if needed. My Pucks are lasting a VERY long time with it. So that is nice. I would have to say that I have ran at least 40 packs, cleaned them once. Have yet to replace a puck, but I am due to check it out.
I am running the Avid slipper and it works great over the stock unit.
I have to say, I am a little sad to see that AE did not come out with an option to run the battery inline. The setup has worked so well for so many people... It is just odd that it is not a option yet.
Reading on the 3 vs 4 gear, if I am understanding this correct, 4 gear transfer more weight to the rear tires and 3 gear transfers more to the front (when on power). I would assume that 4 gear is still likely the best option on a med bite, outdoor dirt track?
I am currently fighting a on power steering issue (or lack of) that I just have not had time to figure out. Its driving me a little nuts. I think if I drop down in the shock oil, it will help over all. The rebound seems slow and I am thinking that it is causing some issues... I need some time on the track. lol
AlmostIllegal is offline   Reply With Quote
Old 01-30-2015, 02:03 PM   #11103
dbowen's Avatar
Originally Posted by Davidka View Post
Do you find the slipper to be useful for stock, other than protecting the diff? I never really have.
Yes in medium to low grip or dusty conditions absolutely bc the eliminator has no give and your car will do doughnuts if you get on throttle to hard in those conditions.
And to answer the other guys question even when you have a slipper locked down it still has more give than an eliminator which has NONE! I didn't believe it until I ran an eliminator in dusty conditions bc I had my slipper almost locked before and it still had some give. But another positive is that the eliminator is lighter so less rotating mass.
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 01-30-2015, 02:15 PM   #11104
Mason's Avatar
2 fold issue. weight and you can use smaller gears such as 66 if you really feel the need.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-30-2015, 02:19 PM   #11105
blade329's Avatar
Trader Rating: 114 (100%+)
Originally Posted by Matt Trimmings View Post
Basically you are discharging the pack at at least 20amps and then immediately charging it at say...40 amps. The discharge cycle puts heat into the pack and the 40amp charge charges the pack quick while keeping the heat in. The heat lowers the internal resistance of the pack which enables it to flow the "juice" much easier.
Thanks for the info. That's gotta kill battery life for sure. Please, racers, if you are going to "juice" your batteries, put up a sign in your pit area. I want to make sure I pit very far away from you. That way I can watch the mushroom cloud explosion from a safe difference.
I wonder if people still can't figure out why this hobby doesn't grow all that much.
Anyway....back on topic. I'm probably going to pick up the new buggy when it comes out in March.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 01-30-2015, 02:41 PM   #11106
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by onefast8 View Post
Was just browsing Reddit and saw this random post:
http://i.imgur.com/37cnpFe.gifv
Pretty cool whip, probably one of you guys!
Too bad he blew the turn in the process of looking cool
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 01-30-2015, 02:50 PM   #11107
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
it calms the car down. I like it.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-30-2015, 02:59 PM   #11108
Super Moderator
racer1812's Avatar
Originally Posted by sstriano View Post
I was programming my ESC tonight and had the rear wheels off... Testing the throttle, I noticed the slightest little "bump" in the rear dog-bone on the right side... I am talking very small, but the other side is perfect.
My question is are the dog-bones perfectly straight or do they have a tolerance to be slightly out?
When the RPM increases it seems like the "bump" goes away, and there and no vibrations or anything like that.
What are the risks of running a slightly bent one... I dont think it is bent, that is how minor it is, but it is not perfect like the other side.
Thanks!
Originally Posted by AZJP View Post
Replace it. Any wobble can wear other parts, such as hub bearings or wear the outdrive.
IMO, you don't need to replace anything, if you're sure it's not bent. I've built new kits that have this slight wobble. My unedgeumacated guess..The bone floats in the out drive, fact. As you apply LITTLE throttle load/friction is put on the bone and it won't 'center' in the out drive until enough throttle is applied that the bone overcomes that friction and centrifugal force centers the bone.
Or I could be a complete idiot and be way wrong. (don't answer that)
Old 01-30-2015, 03:03 PM   #11109
Super Moderator
racer1812's Avatar
Avid or Schelle slippers have a 66t spur gear available.
Old 01-30-2015, 03:09 PM   #11110
I had on power issues too. I changed to 3mm trailing and moved my bat forward a small amount. Then moved the rear hubs to the center. U could also drop the front end of the car by a 1/2mm to help or use offset caster bushings
Justinb86 is offline   Reply With Quote
Old 01-30-2015, 03:55 PM   #11111
Trader Rating: 23 (100%+)
I just went on the pre-order list at Amain for a factory lite B5M...Now, I wonder just how long it will take.
sstretch is offline   Reply With Quote
Old 01-30-2015, 05:15 PM   #11112
gooba's Avatar
I too do not want to be anywhere near anybody charging at crazy high amps. too much risk of fire to gain a tenth of a second
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 01-30-2015, 05:50 PM   #11113
timannnn6's Avatar
Trader Rating: 124 (100%+)
Thinking of getting MIP pucks for Mod running. Pros/cons? Running a 7.5/8.5 for various tracks and getting pin wear faster than I'd like. Wondering if pucks are easy to maintain and last or are there issues?
timannnn6 is offline   Reply With Quote
Old 01-30-2015, 05:51 PM   #11114
303slowdown's Avatar
Trader Rating: 24 (100%+)
Your tranfering to much weight to the rear of the car on power so you could try a little less front droop, so put some limiters in the front shocks (alway gives me the on power steering I need) start with 1mm and go from there.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 01-30-2015, 07:08 PM   #11115
rangerjkb's Avatar
Trader Rating: 40 (100%+)
Send a message via MSN to rangerjkb
Recently began using the MIP Pucks in Mod Buggy. So far they seem to have great wear and durability characteristics. It's simple to replace the plastic pucks vs getting outdrive wear, but I don't think they are a must have for modified racing.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Currently Active Users Viewing This Thread: 9 (3 members and 6 guests)
blankenj99, Dmkiefer, Fran
