    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-29-2015, 12:01 PM   #10981
HYPERformance06's Avatar
So really the only thing special on that car for us guys that have a built up b5m already is the chassis that's factory milled out. I wonder how much it will be
HYPERformance06 is offline   Reply With Quote
Old 01-29-2015, 12:13 PM   #10982
Jmuck69's Avatar
The chassis and the HD rear axles are what I'm interested in. Hopefully the axles are stronger and the chassis is a little flexier. They even updated the set-up sheet.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-29-2015, 12:34 PM   #10983
blade329's Avatar
Trader Rating: 114 (100%+)
Originally Posted by Cpt.America View Post
You're welcome.. and I'm sure it was the driver Oh, and that motor has the least amount of run time of any of my motors. Maybe 20 packs through it.
The battery game is FAR FAR FAR more important than the motor game at the moment in spec racing. I can see 10%-15% increase in performance when I am running my batteries the special secret sauce way.... motor of the month? 1-2%.
What is "juicing batteries" all about?
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 01-29-2015, 12:45 PM   #10984
same axles. alot of the info on the new car is copied from the old car. even says bigger front bearings but they are the same. if you look closley, the rear axles are the exact same. i guess they are just saying beefier compared to the b4
Patrick Hertel
B5M - Trinity d4 17.5 1s ss
As I lay rubber down the street.
I pray for traction I can keep, but if I spin
And begin to slide, please dear god protect my ride.
Old 01-29-2015, 12:47 PM   #10985
Mason's Avatar
Originally Posted by racer1812 View Post
That's just me..I actually crash unlike the rest of RCTech
Most honest quote on RCTech... EVER.
I'm leaning towards putting this in my sig.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-29-2015, 12:48 PM   #10986
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Basically you are discharging the pack at at least 20amps and then immediately charging it at say...40 amps. The discharge cycle puts heat into the pack and the 40amp charge charges the pack quick while keeping the heat in. The heat lowers the internal resistance of the pack which enables it to flow the "juice" much easier.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-29-2015, 12:51 PM   #10987
Suspended
Trader Rating: 61 (100%+)
........I don't know anyone who cycles at a 20a discharge and charges at 40+ amps that worries about "battery life".
And that doesn't touch on the "other stuff" an Icharger can do to gain performance.
"Stock racing..where skill level plateaus and wallet racing begins"
20amp discharge rate? sorry, that's a little too low for me.I'll continue to discharge at 40 sir.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 01-29-2015, 12:52 PM   #10988
Super Moderator
and I will continue to charge at 5 amps and run mod.
Old 01-29-2015, 12:53 PM   #10989
and i thought charging my orion 4000 max charge 5c, charging at 20amps was scary and hella fast to charge. i never do anything special with my batts, just concentrate and driving clean the whole race instead of your batterys
Patrick Hertel
Old 01-29-2015, 12:54 PM   #10990
Suspended
There are several mod racers now charging at 40amps Around these parts.
Old 01-29-2015, 12:58 PM   #10991
my top 20 would have been close to the top 10 but i waited for mark udell to atleast have a fun battle on one of our slower wed night races
Patrick Hertel
Old 01-29-2015, 12:59 PM   #10992
Super Moderator
because that makes sense...
Old 01-29-2015, 01:12 PM   #10993
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Like with Racer, this normally comes into play in 17.5 when you need that power to make the jumps the entire race. Some tracks use really easy layouts and it might matter less. You have 11 second lap times, I assume your track is tiny.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-29-2015, 01:13 PM   #10994
Graham11's Avatar
Trader Rating: 21 (100%+)
seriously why waste your battery's long term life charging at 40amps just go get a 4.5t motor if you want more speed in Mod. Although personally I think theres a tipping point where to fast of a motor actually makes me slower, when i went from 6.5t to a 7.5t in 2wd buggy I was actually faster with the 7.5t but it may just be me, Im sure there are people who can control the throttle better.
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 01-29-2015, 01:14 PM   #10995
you are incorrect. That makes no sense at all. Lowering the IR to go faster, when you can boost, turbo or use a lower turn motor to get speed, makes no sense at all. Matt, you really need to think these things through
