    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-28-2015, 10:51 AM   #10861
Mason's Avatar
Anyone find a clear gear cover for 4 gear? I'm working on a special tribute paint scheme and really didn't want to paint the stock cover.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-28-2015, 11:20 AM   #10862
kdub's Avatar
Originally Posted by dbowen View Post
Awesome thanks Kurt! Now what did going to the 30 degree kick up do and why did you do it? Also why did you change your rear roll center and what were you running before?
30 deg kick (0 caster insert) makes the front end less agressive, works well with 3-Gear to balance the car. The rear link was standard 1-B, 1 washer height. When you lower the outer its a bit more of the effect of a softer rear end in roll compared to raising the inner.
Honestly both inboard link changes are in the same "direction", but I think lowering the outer ballstud gives a bit larger change which is what I wanted at Reedy since the track was getting really abrasive.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 01-28-2015, 11:26 AM   #10863
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Matt Trimmings View Post
IMO i would get the reedy flat wire. The one time i tried a TQ sensor wire i didnt like it. The plug was super tight and the wire was flimsy. I had to ruin it to get it out of a motor.
I find it helpful to use a pair of lexan scissors to get the plug unseated from the motor, its better than having a loose plug that can come unplugged on its own.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-28-2015, 11:27 AM   #10864
Jordan Anderson's Avatar
Originally Posted by kdub View Post
I did dremel my Schelle battery strap a bit on the tongue to remove some of the drag from running cells back.
What do you have to dremel on the Schelle battery strap to run the battery all the way back? Can someone provide a bit more detail/pics on that.
Thanks!
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 01-28-2015, 11:33 AM   #10865
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You have no idea what i had to do to get this plug out of there...I have been using Reedy / LRP sensor wires mainly and never had an issue with a wire coming unplugged. It was like this one was glued in, ridiculous.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-28-2015, 11:45 AM   #10866
dbowen's Avatar
Thanks for the reply Kurt! Ok I really noticed a difference steering wise going to the 3 gear, didn't necessarily think it was to much, but maybe taming it down just a hair would be perfect so I am going to try it. And cool I will try lowering my outer ballstud 1mm and then maybe even 2.
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 01-28-2015, 12:19 PM   #10867
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Thoughts on servos. I have a Spektrum S6040 Shorty Servo. I also have plenty of high speed/high torque (.08 or faster/250oz or higher), Should I use the shorty, Or regular?
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 01-28-2015, 12:37 PM   #10868
dbowen's Avatar
First of all the 6040 is fullsize so I think you mean 6070 (I think thats the spektrum shorty) but anyways I have a 6040 in mine and I tried a shorty and I just didn't like it I dont know if it was in my head but my car seemed to want to do weird things with the shorty (it could have been the servo itself idk). Also Im not a fan of shortys bc they strip easier. But you can't go wrong with a 6040 IMO best servos out there for the money.
Old 01-28-2015, 12:42 PM   #10869
MikeXray's Avatar
Novak motors were the only ones to give me that much trouble, and no one runs those anymore
Old 01-28-2015, 12:43 PM   #10870
"Smiley"'s Avatar
Lol, Yea meant 6070.
Old 01-28-2015, 12:47 PM   #10871
MikeXray's Avatar
I've actually felt the same, the 6040 feels better than the 70, I have the 70 in my 4wd though and it seems fine. The shorty can struggle to get off of a pipe, even though their rated torque seems fine, it's not great.
Old 01-28-2015, 12:54 PM   #10872
Run the full size servo smiley!! That's what all the cool kids run!
Now get back to work!!
Rhett McNair is offline   Reply With Quote
Old 01-28-2015, 02:43 PM   #10873
kdub's Avatar
Default Battery Strap Dremel pic
Thanks!
Here's a pic, just take some material off the top where it goes through the plastic brace, typically about 0.5-0.8mm.
If you prefer to cut plastic rather than carbon fiber, then you can remove the plastic part and dremel it.
Old 01-28-2015, 03:18 PM   #10874
Thanks!
JORDAN // EVAN
Old 01-28-2015, 03:46 PM   #10875
advpball's Avatar
Trader Rating: 28 (100%+)
Smiley...had 6070 in my X-ray xb4 and broke the gears 20.00...I'm running one in my b5m working good..besides i have new spare now.
xray xb2 de
Johnny 5 designs xsc2
Tekno eb410
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
