    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 01-25-2015, 06:19 PM   #10741
Default moving to 17.5 need some advice
So I just got the x-factory chassis,mip alum topshaft,mip pucks and a Team Scream 17.5.should I run the inline setup......and what do you guys think I should start at for gearing??????thanks for the input.
sheeldzy is offline   Reply With Quote
Old 01-25-2015, 06:36 PM   #10742
Cridd's Avatar
Trader Rating: 16 (100%+)
I would start at 5.7 FDR.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-25-2015, 08:15 PM   #10743
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Cridd View Post
Rear bite is what I felt. I love how the mm flys though.
yeah, jumping am MM car is so easy. jumps so flat. less scrubbing and pitching to make it fly right
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-25-2015, 09:40 PM   #10744
Thomas PA's Avatar
I like inline a lot. But definitely try both. Gearing depends on track size and some other factors, but 72 32 isn't a bad place to start. Or you could even try 64p!
And schelle slipper eliminates a good amount of rotating mass. Something to look in to before buying your gears.
Thomas PA is offline   Reply With Quote
Old 01-25-2015, 10:42 PM   #10745
air8's Avatar
I'm not experiencing that yet. In my case both RM and MM handle great, but MM does not go as far or high. I developed a pucker factor as my third qual and then the main went on.
I'm could agree with tire spin. Because sometimes the MM car would break traction and regain in one instant on the two 180 corners our layout has.
More drive time will reveal what I need...either mental or actual setup. LoL
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 01-25-2015, 10:47 PM   #10746
askbob's Avatar
Trader Rating: 28 (100%+)
Checking into see what is the preferred orientation for the aluminum rear ball stud mount. +2m or -2mm?
Building mostly to a Cav setup sheet which says (Low +3mm) of which I'm not fully understanding.
askbob is offline   Reply With Quote
Old 01-25-2015, 10:57 PM   #10747
That means go with the -2mm orientation on the mount, but with 3mm of washers on the ballstud.
jboylan95 is offline   Reply With Quote
Old 01-25-2015, 10:59 PM   #10748
Low +3mm means flipped upside down -2mm +3mm equals +1mm on stock brace
jamie456 is offline   Reply With Quote
Old 01-25-2015, 11:00 PM   #10749
thecman26's Avatar
Trader Rating: 99 (100%+)
So mount goes -2mm, so the taller side is down.
Then add 3mm of shims under the ball stud.
You could go +2mm and only put 1mm under the ball stud. both would be the same height.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 01-25-2015, 11:30 PM   #10750
askbob's Avatar
This makes the most sense. I appreciate the input fellas!
Old 01-25-2015, 11:59 PM   #10751
Are you sure? I thought -2mm was 2mm below stock and +2mm was 2mm above stock. So -2 +3 would be 1mm higher than stock, and +2 +1 would be 3mm higher than stock.
Old 01-26-2015, 12:16 AM   #10752
Trader Rating: 29 (100%+)
I think your right that's the way I understood it anyways.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 01-26-2015, 12:21 AM   #10753
I want that mip 3 gear. It looks stellar. Am I correct in assuming that it weighs more than the ae 3 gear? I want a ill more weight back there.
Old 01-26-2015, 01:10 AM   #10754
askbob's Avatar
Can anyone confirm which is correct?
Old 01-26-2015, 01:42 AM   #10755
mjbtaco's Avatar
Originally Posted by matt777 View Post
What exactly removing the puck system do?
put some weight back in for the 3 gear. and just all around cheaper and lasts longer.
here is how i have my car setup with the 3 gear. lipo and all other electronics as far back as possible.
mjbtaco is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
axoid
