    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-24-2015, 07:11 PM   #10726
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Cridd View Post
so when braking your ass end would get a little skittish and feel really light?
Yes, we have an off camber 180 hairpin where I noticed the most, it's not a huge difference, but it was noticeable, I turned down the brake a little to compensate. I was more consistent overall this week, hotlap was the same.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-24-2015, 08:41 PM   #10727
matt777's Avatar
Just throwing my two cents in, I have the associated 3 gear in my b5m running stock 17.5 with puck system, I see a couple differences, First off less rear traction but I personally like it better than when I couldent get the front to hook up, We run on medium to high bite clay, If definitely feels more consistent in lap times and a slight more predictable, But now I can clear most the mod jumps the stock isnt getting close to, So I say the 3 gear is a win, Gonna experiment with saddle ran as a square pack tommorow, As it is I have the shorty all the way back amd speedo right in front and the ass end is still a little slick even when traction does come up.
matt777 is offline   Reply With Quote
Old 01-24-2015, 09:30 PM   #10728
Trader Rating: 14 (100%+)
I plan on running with a square pack. OCRC is probably similar traction wise and all the really fast guys run shorties. I am thinking the extra weight will be good for me since i don't run very often.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 01-25-2015, 12:03 AM   #10729
mjbtaco's Avatar
The square pack will be quite a bit more weight. With the 3 gear you want to put more weight further back. Myself and another driver at ocrc took our pucks out and are running the stock diff parts. I moved my shorty all the way back and my esc and receiver as well while using the schelle battery strap. Now it feels as stuck as it did with the 4 gear.
mjbtaco is offline   Reply With Quote
Old 01-25-2015, 04:43 AM   #10730
matt777's Avatar
What exactly removing the puck system do?
Old 01-25-2015, 05:37 AM   #10731
Cridd's Avatar
Trader Rating: 16 (100%+)
Less maintenance, same weight.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-25-2015, 10:24 AM   #10732
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Default Took long enough...
http://www.redrc.net/2015/01/mip-b5m...-transmission/
During this weekend‘s Reedy Offroad Race of Champions MIP have a new 3-gear transmission for Team Associated’s B5M buggy to show. The sturdy 7075 aluminium case offers improved precision, optimised gear mesh and thus higher efficiency compared to the standard moulded cases. At the same time the transmission package is relatively of the same overall weight as the OEM 4-gear transmission, keeping the weight distribution the same as what the car was designed for which can often be more beneficial than scrubbing tons of weight. Also as the motor sits at a 3mm offset to the left an optimised left to right weight balance is achieved – the needed spacer and new spring will be supplied with the transmission kit. On top of that the all-alloy gearbox will act as a giant heatsink, making for improved motor cooling and a reduced power fade during a run. The 3-gear design also makes for a more efficient operation making the gearbox ideal for stock and modified racers alike.
RCBuddha is offline   Reply With Quote
Old 01-25-2015, 10:54 AM   #10733
3srcracing's Avatar
Trader Rating: 25 (100%+)
Why would they make that? No way the can compete with AE's case when it's like $10 to get. Then there's theirs for $58ish or more I bet.
3srcracing is offline   Reply With Quote
Old 01-25-2015, 10:55 AM   #10734
Suspended
Trader Rating: 61 (100%+)
It will cost more than that.
And it's pure badass.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 01-25-2015, 11:34 AM   #10735
MikeXray's Avatar
I really like that MIP centered the motor more, that made a difference in jumping level on my kyosho when they released it, I wondered why the B5 wasn't like that since they were redesigning cases and top shafts anyway..
Old 01-25-2015, 01:41 PM   #10736
air8's Avatar
Shock limiters. What would I expect by removing one limiter, from all four shocks?
I race mod class. This weekend I went from my B5-R to a B5-M I purchased from a good friend. The MM car handled similar to the RM except it was difficult to clear small jumps with. Like I had to drive it near full wood to make a 12 foot long jump.
Im' not sure what the setup is. I got the car together for third round of qualifying then ran the main. I am assuming there are more limiters in than my RM had.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 01-25-2015, 02:25 PM   #10737
Suspended
Drive train loss.
Old 01-25-2015, 04:27 PM   #10738
MikeXray's Avatar
Originally Posted by Socket View Post
Drive train loss.
it also can be less actual rear bite, the tires could be spinning just enough to not gain enough momentum.
Old 01-25-2015, 04:32 PM   #10739
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
IMO, MM does not jump as far as RM. why? the rm car is lighter, spins up faster and has more rear bite.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-25-2015, 05:54 PM   #10740
Cridd's Avatar
Rear bite is what I felt. I love how the mm flys though.
Chris
B6D / T5M / SC5M
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
axoid
