    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-22-2015, 10:31 AM   #10681
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Gpeters66 View Post
You might want to also check out Avid bearings. I run them in all my cars ..I like how they are metal shielded on one side and this lets them spin more free than most bearings. Another Neat thing is you just select you car and they build the kit for you and you can select any bearing style you want like if you want to upgrade the gearbox bearings to ceramic you can.
Yep, Avids are great
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-22-2015, 12:22 PM   #10682
Jason Baliban's Avatar
Originally Posted by HYPERformance06 View Post
so ? im still running the kit bearings (if you would even call them bearings) and the fronts are already really notchy. whats the best bearing kit out there in your opinion? i bought all the aluminum and titanium baddazled parts when i built my car and didnt know how bad the kit bearings where. if i would have known i would have bought them right away.
For the fronts, i dont think bearing quality is the issue. My kit and avid bearings are equally doomed in the front.
jB
High Sundry Productions
B5M | MBX-7Re | T5M | TC3 | RC10 "Graphite"
Jason Baliban is offline   Reply With Quote
Old 01-22-2015, 12:32 PM   #10683
HYPERformance06's Avatar
jB
Really!? its not the axle setup either because im running spindles with clamping hex like the old b4.2 style. maybe its the inserts slightly moving in the caster block and tweaking the bearings
Patrick Hertel
B5M - Trinity d4 17.5 1s ss
As I lay rubber down the street.
I pray for traction I can keep, but if I spin
And begin to slide, please dear god protect my ride.
HYPERformance06 is offline   Reply With Quote
Old 01-22-2015, 12:33 PM   #10684
jB
I have had zero luck with the kit axles. I am not sure what the issue is, but I always get less grit with the FT axles. That being said, I think the true culprit are the inserts. I really wish AE would just come out with 1 piece spindles. If they made 1 piece spindles that were properly aligned, the issue would be greatly minimized. That being said, the kit bears are still junk.
I am NOT a fan of too much aluminum on the cars, but I wonder if these would help the inserts align better.
http://www.hot-racing.com/index.cgi?...=BFR2101;c=877
Old 01-22-2015, 12:35 PM   #10685
timannnn6's Avatar
Trader Rating: 124 (100%+)
What I noticed on mine is after I glued the inserts in the bearings they got notchy. This would indicate that the two bearing holes are not true to each other and introduces a side load causing this. One side on mine is actually worse than the other.
timannnn6 is offline   Reply With Quote
Old 01-22-2015, 01:17 PM   #10686
Yeah, while they are at it they can do the rear hubs as well. You have two choices, break ball studs in the aluminum hubs or break those plastic inserts in the plastic hubs and be forced to buy an entire rear hub kit to replace just the insert.
I think i am seeing this as well. I glued in my inserts in hard front hubs and it really didnt save my bearings. I dont know if its worse, but it isnt any better.
jB
Old 01-22-2015, 03:15 PM   #10687
lbckevin's Avatar
Trader Rating: 91 (99%+)
I run the Schelle bearing all around and use the Exotek front titanium axles. Flawless !!!
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 01-22-2015, 04:00 PM   #10688
I've had two sets of bearings get notchy, with glued and unglued inserts - and I have used the FT axles and clamping hexes both times. I would like them to go back to a one piece design like the 4th gen cars.
StadiumRC is offline   Reply With Quote
Old 01-22-2015, 04:07 PM   #10689
Is the alum rear ball stud mount in the -2m position same as the stock plastic one
speed101 is offline   Reply With Quote
Old 01-22-2015, 04:58 PM   #10690
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
What is everyone's opinion on the MIP Shiny Pucks in Mod?
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 01-22-2015, 05:12 PM   #10691
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You need to add 2mm on the -2 aluminum block to get to 0 or stock plastic.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-22-2015, 06:25 PM   #10692
Thank you sir
Old 01-22-2015, 07:15 PM   #10693
I love them on my car. I have had no issues with them at all. Nice tight no slop or play in drive train.
Kyosho MP-9 TKI3, Tekno SCT-410, AE B5M, AKA racing, Mel's Shells, Family Hobbies in Vineland NJ, Sjrc
purple rides is offline   Reply With Quote
Old 01-22-2015, 07:18 PM   #10694
Trader Rating: 29 (100%+)
I dont know if they are worth the money. The kit dog bones last quite awhile. A guy at my track runs them and he is always replacing the little plastic things.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 01-22-2015, 09:58 PM   #10695
DJM75's Avatar
Dang this thread is long. Do you guys know of any sites other than RC10.com that I can find some starting setups? My track is very high traction carpet. I can't think about turning without traction rolling. Thanks ahead of time.
Donovan
*Team Associated RC10B5m*Airtronics MT-4*
DJM75 is offline   Reply With Quote
