    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-08-2015, 10:23 AM   #10306
Potoczak's Avatar
Trader Rating: 112 (100%+)
Originally Posted by Wildcat1971 View Post
Well, on top of the gear box. I HATE button head 2mm screws. The tool surface area on the hex is shallow. So I was thinking about using some flat head screws on the top. Maybe SS/Ti screws, with purple washers. Or purple screws with silver alum coned washers. Just a blink thing. My daughter loves purple and it would match her paint scheme which is purple/white/pink.
Anyone use fastener-express? Lookin at these
http://www.fastener-express.com/metr...oc-screws.aspx
+1 have ordered from fastener express a bunch of times. Their aluminum screws are top quality. The hex heads are nice and deep.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-08-2015, 10:25 AM   #10307
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
ok, cool. for about $30 shipped, I can do 2 cars and have a bunch of extras. like 125 screws in all.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-08-2015, 10:36 AM   #10308
Anyone running this buggy outside get it to work?? Or should I just get the rear motor. Not sure what are track will be like yet but won't be high grip. Thanks in advanced!!
Badcompny44 is offline   Reply With Quote
Old 01-08-2015, 10:47 AM   #10309
oh no, here comes the MM vs RM debate. Well, let me put it like this. My laptimes are the same with both, but IMO the RM car is easy to setup for lower bite outdoor racing. That does not mean, the MM wont work. I am saying the RM is easier to get right out of the box. That has been my experience. If you have a lot of fast guys locally running MM B5s, you can always pick their brains. But, me personally? I would buy the RM kit. Then, if I find out I am lacking, maybe get the MM conversion. Actually, that is exactly what I personally ended up doing. MM is nice, but it definitely has its draw backs. Especially in 17.5.
Old 01-08-2015, 01:23 PM   #10310
Mason's Avatar
I have not used fastener express yet but I have used microfasteners.com . I think there's only been one screw i have yet to find on there. That being the b4 front top shock mount screw.. they had both sides of the exact size but not the exact size if i recall correctly.
just another option.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-08-2015, 04:46 PM   #10311
I am currently setting up a second B5M to dabble in Mod a little. I have the buggy setup right now and have all the electronics in it but I have a question as far as can timing on the motor and gearing for those of you running the Reedy Sonic Mach2 8.5T. I am running an Orion R10Pro/Reedy 8.5T combo. Currently it is set at 32* can timing and I am running 23/81 gearing. Temps and everything are good driving it around my warehouse at work but figured I would ask and see what people with similar setups are running as gearing and can timing.
Jade67 is offline   Reply With Quote
Old 01-08-2015, 05:52 PM   #10312
When I run my 8.5 I use the same gearing but run 20degrees of timing. I usually run this on a mid size indoor track with tighter turns. If the track is more flowing or a little larger I run a 7.5 with 21 or 22 pinion and can timing around 20 as well.
DJG24 is offline   Reply With Quote
Old 01-08-2015, 06:13 PM   #10313
Graham11's Avatar
Trader Rating: 21 (100%+)
Kind of confused. I have the AE blue aluminum shock bushings and the aluminum shock caps on my b5m but is it supposed to be metal on metal or is there supposed to be a plastic bushing. The alumni shock caps didn't fit on my Sxhelle bushings w the white bushing so I got the AE blue ones. Anyone know?
Graham11 is offline   Reply With Quote
Old 01-08-2015, 06:15 PM   #10314
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
You need these:
http://www.amain.com/team-associated...ball-4/p275221
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-08-2015, 06:16 PM   #10315
your missing the plastic bushings for the alum ae mounts
Old 01-08-2015, 06:18 PM   #10316
from amain
This is a pack of four optional Team Associated Factory Team Aluminum Shock Bushings. These bushings are machined from aluminum for improved strength and anodized blue for good looks.
NOTE: These must be combined with the Associated Shock Bushing Balls (ASC91447).
This product was added to our catalog on March 14, 2014.
Old 01-08-2015, 06:53 PM   #10317
moto44's Avatar
Trader Rating: 9 (91%+)
Looking to set up my B5M for a indoor clay track small to medium, what is a good starting set-up? Would I benefit from using the front flat lower control arms?
Barnstormers Raceway
Critters
________________________
moto44 is offline   Reply With Quote
Old 01-08-2015, 06:58 PM   #10318
billdogg's Avatar
Trader Rating: 15 (100%+)
http://www.petitrc.com/setup/associa...ktrum20141109/
Yes, use the flat front arms and tower.
billdogg is offline   Reply With Quote
Old 01-08-2015, 07:22 PM   #10319
Trader Rating: 18 (100%+)
Depends on what you feel with the car, the stock gullwing arms give more steering(which may be better for a small track) alot of guys run the b5r tower and arms to tame down the steering, i personally am running the stock arms at Critters Raceway which is a small indoor clay track and have been up front in every race. Running stock springs, with 2x1.6 front 32.5wt 2x1.6 rear 30wt, rear shocks inner hole, front shocks middle hole, camber -1 on all 4
customss is offline   Reply With Quote
Old 01-08-2015, 07:33 PM   #10320
Graham11's Avatar
Thanks but I have those plastic bushings, they don't fit... And thank you for copy and pasting the directions from Amain but that's for when using the stock plastic caps.
I have aluminum caps and aluminum bushings and the plastic bushings you guys are referring to and they don't work.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
