    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-02-2015, 07:26 PM   #10126
Graham11's Avatar
Trader Rating: 21 (100%+)
For those running on 100% clay indoor, small to medium track using clay slicks or broke in ions/typos/etc.... My car is a little loose coming out of the turns even w good tires, what are the first 2-3 things I should look at... Diff is tight.
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 01-02-2015, 07:35 PM   #10127
Trader Rating: 29 (100%+)
where are your rear hubs located and are you running your front hubs all the way forward?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 01-02-2015, 08:40 PM   #10128
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
on our clay track broke in typos and clay slicks are vastly different. slicks have a ton of grip and my rear never breaks loose. If I try "treaded" clay tires, traction drops off a lot. I dont run on your track, just saying those 2 can be vastly different. I assume you have the RM arms and rear hubs forward and are running 4mm trailing?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-02-2015, 08:49 PM   #10129
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
STAY ON THROTTLE!! lol
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 01-02-2015, 10:28 PM   #10130
xyzracer's Avatar
Got a trinity ti xl 3400 shorty and wondering what u guys do to secure it in the car? Its way too thin for the stock battery hold down system. Is there another hold down made specifically for the thin pack or do I just need to stack and pack foam? I tried flipping the stock hold down upside down but it is still a little too loose for my liking.
xyzracer is offline   Reply With Quote
Old 01-02-2015, 10:37 PM   #10131
Cridd's Avatar
Trader Rating: 16 (100%+)
Stack on top is what I do.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-02-2015, 10:44 PM   #10132
Razathorn's Avatar
Originally Posted by rc23 View Post
thats not necessarily true, if its a high bite track and the rear is too soft, its going to dump and lose side bite.
This. Same experience if you try going to green springs in the rear on anything but a low traction track.
The 3x1.4s offer a different high speed vs normal damping profile than the 1.6s. A lot of folks tend to interchange the 2x1.6 and the 3x1.4 with the same oil and it just doesn't work out exactly the same, even though they appear very similar on the bench. The 2 hole piston has larger steps in low speed damping with oil, and 30wt oil in it is thicker "in the corners" than with the 3 hole piston. That has been my experience at least. I tend to use the 3x1.4 pistons in the rear on our looser outdoor track, sometimes even tapered ones, and prefer the 2x1.6 flats in the rear when indoors where the traction is much higher.
Wayne
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
Old 01-02-2015, 11:35 PM   #10133
tape it down
Old 01-02-2015, 11:47 PM   #10134
Suspended
Originally Posted by 3srcracing View Post
Anyone looking to trade for a RB6?
Just need a better car for a low bite track, and this isn't cutting it.
Did you try your RB6 in rear motor?
Mantis Toboggan is offline   Reply With Quote
Old 01-03-2015, 12:26 AM   #10135
I run the promatch racing 3500 and use one of the thinner battery foams on top the battery. Not ideal but it works.
Justinb86 is offline   Reply With Quote
Old 01-03-2015, 12:30 AM   #10136
+1
Old 01-03-2015, 08:53 AM   #10137
mxer373's Avatar
I run a piece of foam on top between the battery and brace .....
Dan Wilcox
mxer373 is offline   Reply With Quote
Old 01-03-2015, 09:30 AM   #10138
Trader Rating: 90 (100%+)
same here I just put a piece of foam to help secure.
dan-o is offline   Reply With Quote
Old 01-03-2015, 10:19 AM   #10139
Trader Rating: 32 (100%+)
you can trim down the battery posts a little so it will go lower. And flip over the hold down nuts. I only had to trim off 1/8 of and inch.
AE B6, SC5M, T5Mx2
Tekno SCT410.3, eb410
astarback is offline   Reply With Quote
Old 01-03-2015, 12:24 PM   #10140
mschumi101's Avatar
Send a message via Skype™ to mschumi101
Finished Painting up a New Finnisher Body! Also installed some new upgrades bringing my total to:
Schelle Slipper
Fin Titanium Turnbuckles
Aluminum A arm mount
Aluminum 12mm rear Hex
X-rings
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
