    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-21-2014, 08:20 PM   #9946
billdogg's Avatar
Trader Rating: 15 (100%+)
Originally Posted by thecman26 View Post
Flat fronts and tower, you dont have to put the RM rear arms on at the same time but you need the front tower with the flat arms.
If you're good enough and don't hit too many walls, I would go with the hards, but if ya hit stuff go with the regular, they flex more and won't break as quickly.
So what is the advantage of running the hard parts?
billdogg is offline   Reply With Quote
Old 12-21-2014, 08:39 PM   #9947
Cridd's Avatar
Trader Rating: 16 (100%+)
I have two B5m going to start moving one to hard parts to see the differences here and there. Need something to work on
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-21-2014, 08:55 PM   #9948
Cridd's Avatar
it does look like they may be making a change on the B5 and B5m. Out of stock at most locations. I was getting a little bored!
Chris
B6D / T5M / SC5M
Old 12-21-2014, 10:25 PM   #9949
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I have 2 cars. one mine and one my kids. Hers is all plastic, mine is mostly hard parts. I cant really feel a difference. They do make the car a bit heavier though
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 12-21-2014, 10:47 PM   #9950
Cridd's Avatar
any breaking issues on the hard parts? I know the B4.2 carbon parts, were very brittle.
Chris
B6D / T5M / SC5M
Old 12-21-2014, 10:48 PM   #9951
They are more brittle. They are not obscenely brittle, but your car will no longer be a tank. You click a pipe going fast, it will probably break.
Old 12-21-2014, 10:51 PM   #9952
Cridd's Avatar
might try in the winter and if they break go back.
I could deal with inline possibility on 5.1. would be another tuning option.
Chris
B6D / T5M / SC5M
Old 12-21-2014, 10:52 PM   #9953
They are fine, but I dont have that invincible feeling with them. I don't air it out on triples or take as many chances. Lol, it probably helps me overall to have a little fear.
Old 12-21-2014, 10:56 PM   #9954
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
The hard parts also have a different appearance. I have the hard front tower on my car and it is a light gray compared to the rest of the car being almost black plastic. Only reason I have the hard over normal is it was the only flat arm tower in stock when I bought it.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 12-22-2014, 08:06 AM   #9955
Dog Runner's Avatar
Send a message via Skype™ to Dog Runner
I'm building a B5M for the first time and got the aluminum rear camber link mount and aluminum rear hubs. On Cav's Spektrum race setup, it says for the rear camber link mount "low +3mm". I'm assuming this means to mount it in the "-2mm" position and then add 3mm of spacers? And for the hubs, it just says "+3mm". Again, I'm assuming to simply add 3mm of spacers under the ballstud? Thanks!
JR
Need a real estate agent? I can help.
Dog Runner is offline   Reply With Quote
Old 12-22-2014, 08:12 AM   #9956
Jmuck69's Avatar
rear aluminum link in low position (-2mm as compared to stock plastic which is at 0mm) so he is running (based on plastic mount) 1mm spacer. Running 3mm on the hub is stock position (equivalent to A or B tower)
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-22-2014, 09:43 AM   #9957
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2014/12/revolut...m-spring-cups/
Revolution Design B5/B5MM aluminium spring cups
Revolution Design Racing Products introduce their new Team Associated B5 series aluminium spring cups in +5mm offset configuration. They are a direct replacement for the stock plastic cups and improve spring fitment and overall rigidity for optimised suspension performance especially on high-bite surfaces that put a lot of stress on the suspension. The parts are CNC-machined from aircraft-quality 7075-T6 aluminium, they are light of weight at only 1.65g per piece, they come blue anodised and laser-etched for that ultimate factory touch and to match the other forthcoming RDRP B5 series option parts.
RCBuddha is offline   Reply With Quote
Old 12-22-2014, 10:31 AM   #9958
Mizchief's Avatar
Is that the same offset used in the 44.3? Very interested as I broke one over the weekend.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 12-22-2014, 10:50 AM   #9959
I would bet on a factory Team version rather than changes to the chassis.
DJG24 is offline   Reply With Quote
Old 12-22-2014, 10:54 AM   #9960
it has been a year. AE has been doing "something" after a year. What? who know.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
