    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-20-2014, 03:00 PM   #9886
RC10Nick's Avatar
Originally Posted by RaceDayHobbies View Post
I hope you are right.
But Associated also stated they would be available in Nov. 2014.
That's odd. I've had a 3 gear transmission since 2012
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 12-20-2014, 03:34 PM   #9887
Thomas PA's Avatar
Talking
That's odd. I thought this thread was for the B5M? Not homemade G10 Dingos?
-Thomas Kauffman
KDRC Carbon Fiber Upgrades
Bumps & Jumps RC, Pit Stop Hobbies
X6^3: Tekin, Fantom, Sav÷x
B5M: KDRC, Fantom, hobbywing, Sav÷x, Schelle, AC RC
Thomas PA is offline   Reply With Quote
Old 12-20-2014, 07:28 PM   #9888
Mason's Avatar
Where are you guys hosting your setups? I was going to share mine and see if it helps any of you out.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 12-20-2014, 07:45 PM   #9889
Spring suggestions for inline setup, med to high traction?
nordfink is offline   Reply With Quote
Old 12-20-2014, 07:47 PM   #9890
Currently on white rear, gray front. ..
Old 12-20-2014, 08:05 PM   #9891
Originally Posted by gooba View Post
For you guys who have spent a ton of money making a lightweight car this is mine BOX stock with LRP spin, jr reciever,turningy 4200 shorty and savox lo pro servo. I have a top shaft and screws coming but not planning anything else. Super light doesn't mean super fast.
Mine is 1540 with a Tekin RS gen2, savox 1258, rx472, and a turnigy shorty. My mods include a Schelle slipper, exotec top shaft and JC motor plate. I'm still running the stock turnbuckles.
Scargoes is offline   Reply With Quote
Old 12-20-2014, 09:14 PM   #9892
Trader Rating: 14 (100%+)
Default Gear Diff Question
So I built the gear diff for the b5m and it seemed to be smooth... When I put it into the tranny and put in the top shaft and the idler gears without putting the other half of the case on it feels smooth as silk... As soon as I put the other side of the tranny case on, I get a bump in the roataion... like a pinched bearing, but all the bearings are smooth as silk...
Should it be smooth as butter or does it need to be broken in?
Help!!
sstriano is offline   Reply With Quote
Old 12-20-2014, 10:26 PM   #9893
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Wildcat1971 View Post
the new stock firmware is not very good imo
I was looking for information on what the difference in new firmware / upgrade was but it doesn't show anywhere. Feels really slow and times confirmed. Last night was ugly, thought I had a 21.5. Going to drop back and check times. New to Orion so playing with it. Any luck with mod firmware in B5m or better to stick with stock firmware for stock?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 12-20-2014, 10:31 PM   #9894
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
the new firmware feels like crap. slow, motor gets hot. you could try dropping a few teeth on the pinion, but i just went back to the old firmware
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 12-20-2014, 10:40 PM   #9895
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Help!!
1) Make sure you don't over-tighten the case
2) The gears will certainly break in. Spin it by hand after a few packs and I bet it's butter.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-20-2014, 11:31 PM   #9896
It does it only when the other half of the case is on even when theres no screw in it and youre just holding it together by hand
Old 12-21-2014, 12:25 AM   #9897
gooba's Avatar
Put some screws in it and tighten them up it could be that it isn't aligned properly. Also make sure there isn't a small burr or piece of flashing on that side of the case.
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 12-21-2014, 01:04 AM   #9898
Trader Rating: 29 (100%+)
if you have some spare bearings might not be a bad idea to swap em out just to see, even though you said yours were smooth. Capt. suggestions is a great one as well. Sometimes gears just need to be run for a min and then they free up.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 12-21-2014, 04:11 AM   #9899
RCBuddha's Avatar
Trader Rating: 35 (100%+)
It should be smooth. Try a new case or check to make sure the bearings are seated properly.
RCBuddha is offline   Reply With Quote
Old 12-21-2014, 04:22 AM   #9900
The top shaft bearings dont always seat the best. use the topshaft and try to press them into place.
