    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 12-17-2014, 05:02 AM   #9751
MiCk B's Avatar
Originally Posted by Graham11 View Post
if anyone knows of a 30mm fan protector let me know, I think PSM makes one but I dont believe its 30mm?
30mm Fan protector:
http://www.fast-webshop.com/tonispor...rbon-Protector
MiCk B. :-)
http://www.dublinmodelracing.com
http://www.p-dubracing.co.uk
http://www.msdmodels.ie
MiCk B is offline   Reply With Quote
Old 12-17-2014, 07:25 AM   #9752
dbowen's Avatar
Originally Posted by sstriano View Post
So this is what I just pulled the trigger on:
1) Reedy Sonic 540 Mach 2 17.5 Spec Brushless Motor
2) HobbyWing XERUN-120A-V3.1 ESC (1/10, 1/12 Car), Black
3) Hobbywing Multifunction LCD Program Box for ESC Programming (3-function)
4) Savox SC-1258TG Super Speed Titanium Gear Standard Digital Servo
5) Thunder Power RC TP610C-ACDC Multi-Chemistry AC/DC Charger/Discharger/Cycler with Balancing System
That combined with the B5M Kit and the Spektrum DX4r Pro and all I need now is batteries...
I wanted a good ESC that I can run mod with too eventually... So I went with the V3.1 not SPEC.
What do you think? Did I make the right choices?
The stock spec is basically the same as the regular 3.1 only it is 100a vs 120a but it still can run down to a 5.5t which the regular 3.1 runs down to a 5.5t with 2s lipo off road the only major difference is the stock spec only ways like 40 grams bc it has a plastic case which is great for stock, were the regular 3.1 weighs like 90 grams bc it has an aluminum case. But the 3.1 is still a great choice just making sure you realize the differences I know it is very misleading to call it "Stock Spec"
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 12-17-2014, 07:33 AM   #9753
Suspended
Trader Rating: 61 (100%+)
So motor regulations are the same?
Socket is offline   Reply With Quote
Old 12-17-2014, 07:37 AM   #9754
dbowen's Avatar
Yes for 2s lipo off road, which I know doesn't make sense but just click "Specifications" compare them http://www.falconsekido.com/products...ock-v3-1-black
Old 12-17-2014, 08:31 AM   #9755
I have been wanting to try the inline setup with the battery inline also, what are you guys doing to the setup vs. inline electronics with the battery sideways?
As far as shock oils, springs, etc...I have inline electronics with battery sideways now, 32.5 Front, 30 rear, all Asc white springs.
LSHoleRacer is offline   Reply With Quote
Old 12-17-2014, 08:38 AM   #9756
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
good choices, but an FYI. The stock spec esc can handles down to a 5.5 motor....lol
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-17-2014, 08:44 AM   #9757
Graham11's Avatar
Trader Rating: 21 (100%+)
does stock spec also have all the same programming options?
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 12-17-2014, 08:45 AM   #9758
the only difference is 100 vs 120 amp and the v3.1 NON spec has an all alum case, which is heavier.
Old 12-17-2014, 08:54 AM   #9759
The stock spec even has all of the timing and boost functions of the V3.1. I almost didn't buy the stock spec at first because I assumed it was a locked blinky speed controller.
I'm not an expert, just a truggy enthusiast
kawi650 is offline   Reply With Quote
Old 12-17-2014, 09:14 AM   #9760
Jordan Anderson's Avatar
Your servo has a rated stall current of 5 amps and your ESC's BEC is only rated to 3 amps.
I killed a BEC in a Viper VTX10R ESC using the Savox SC-1257TG (sister sevo to 1258TG).
YMMV...
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 12-17-2014, 09:46 AM   #9761
Trader Rating: 14 (100%+)
YMMV...
What would be another good option for a servo then? Also I might go to the V3.1 Stock Spec instead since it is just about the same thing sans 20 amps and a aluminum case.
sstriano is offline   Reply With Quote
Old 12-17-2014, 10:14 AM   #9762
I have been running this one for over a year without any issues.
http://www.amain.com/protek-r-c-130s...oltage/p253592
this one is also very good
http://www.amain.com/xpert-4000-seri...-servo/p276593
Old 12-17-2014, 11:05 AM   #9763
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default No issues with Savox and Hobbywing!
YMMV...
I personally have had no issues with the Hobbywing V3.1 and Savox 1257 or 1258 in any of my applications. I have been running this setup for over 2 years. The Servo is not going to pull near those kind of amps in a 10th scale application, even in a 4wd SCT, I have not had any BEC issues. I am confident you will be very happy with those choices.
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 12-17-2014, 11:11 AM   #9764
Suspended
I run the 1257Tg, a better option than the 1258, with my Orion R10.1 pro and haven't had any issues.
Old 12-17-2014, 11:55 AM   #9765
Mizchief's Avatar
Yea I haven't had any glitch problems with savox/specktrum stuff since running the Tekin gen 2 stuff and using the DSM2 receivers.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
