    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-04-2014, 12:17 PM   #9496
shannow's Avatar
Originally Posted by bbrace3m View Post
hey guys i am having a little problem with my car. i built it a few weeks ago, polished all ball studs and all the arms move freely as they should. i have ran 3 packs through the car. i noticed my front shocks were not returning all the way so i removed them and changed the fluid and made sure there was no air in there. I also made sure the shaft moved freely from all the way compressed to all the way extended. and it does move in and out freely with no binding and sticking. now i bolted the shocks back onto the car, and they still stick. the return almost all the way out but then stick. has anyone else had this problem and what should i do? thanks
Just an idea, what spring cup are you using ?
shannow is offline   Reply With Quote
Old 12-04-2014, 12:19 PM   #9497
i honestly could not tell you. i noticed there are different ones. which ones should i be using? this is the first kit i have built, first time buying something brand new lol
TEAM HOLY ROLLERS
Team Associated B5M
PHILIPPIANS 4:13
bbrace3m is offline   Reply With Quote
Old 12-04-2014, 12:22 PM   #9498
shannow's Avatar
I know that when I tried the 0mm ones (the shorstest) it bound and the cup touched the arms before full extension of the shocks.
Old 12-04-2014, 12:24 PM   #9499
i believe the ones i am using are the shortest ones, i will put a different cup on and see if it helps. thank you!
TEAM HOLY ROLLERS
Team Associated B5M
PHILIPPIANS 4:13
Old 12-04-2014, 12:41 PM   #9500
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Use the "middle" height cups.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 12-04-2014, 12:50 PM   #9501
AE-Reedy
Originally Posted by Boostinswifty38 View Post
So, moved the esc behind the battery and shortened some wires. Buggy tips on at 1531 grams. Still have more to remove, like screws, Turnbuckles, slipper, etc. Why is minimum weight 1499? I don't get it. Why not call it even 1500?
I think because the number was converted from pounds.
Originally Posted by McCroskey View Post
Silly question. When figuring the weight of the car, is it with or without tires on?
Yes with tires, race ready.
Sean Cochran is offline   Reply With Quote
Old 12-04-2014, 12:53 PM   #9502
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
1499 grams = 3.304729 pounds.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-04-2014, 03:22 PM   #9503
AE-Reedy
IDK then.
I just checked IFMAR and this is what they show,
4.3.3 Minimum weight limit: 3.25 Pounds 52 ozs. 1.474 Kilos
Old 12-04-2014, 05:08 PM   #9504
onefast8's Avatar
Trader Rating: 41 (100%+)
Sorry for OT but anyone happen to know where I could pick up a exotek slipper eliminator (aside from Stormer that wants $8 in shipping for one)?
Jake R.
onefast8 is offline   Reply With Quote
Old 12-04-2014, 07:28 PM   #9505
Curious if anyone has tried drilling a 4th hole in the rear shock towers?
robbie_gtc is offline   Reply With Quote
Old 12-04-2014, 08:56 PM   #9506
Trader Rating: 29 (100%+)
personally i run the middle stock hole a lot so i can not see the need to stiffen the rear end to that degree?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 12-04-2014, 09:26 PM   #9507
STLNLST's Avatar
Trader Rating: 21 (100%+)
Got you covered. Check your PM
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-04-2014, 11:48 PM   #9508
ckoetsch's Avatar
Trader Rating: 18 (100%+)
try the 5mm shock cups
Sick Graphics - KYOSHO RB6.6 - "If you ain't first you're last" R. Bobby
NW Hobbies of Albany and Dave's RC Tracks of Hubbard.
ckoetsch is offline   Reply With Quote
Old 12-05-2014, 04:14 AM   #9509
Also looking for a slipper eliminator
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 12-05-2014, 05:58 AM   #9510
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
http://www.exotekracing.com/trf201-d...nt-also-xr-xm/
According to Exotek, the TRF201 is compatible with the B5 one and is in stock. I assume it is the exact same dimensionally, only probably slight differences in anodizing color. Mike should be able to confirm.
Dan is offline   Reply With Quote
