    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-03-2014, 11:23 PM   #9481
lbckevin's Avatar
Trader Rating: 91 (99%+)
Body on....tires on...ready to put it on the track weight.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 12-03-2014, 11:48 PM   #9482
Originally Posted by intimdator10 View Post
I just bought a B5M and I am currently building it. I am looking for some gearing help. I will be running a LRP Flow esc and a LRP 13.5 motor.
With my 13.5 I run a 31/69 gearing. For 17.5 i'd run a 33/69
SDRC
Associated
TLR
Tekno
uclabruins89 is offline   Reply With Quote
Old 12-04-2014, 05:32 AM   #9483
69/32 here only because no 33's on the wall. Everyone is running a 33 here.
And I'm running stock, since it's our biggest class. I just don't get the weight reasoning lol.
What weight savings can I expect with a slipper eliminator? Ti Turnbuckles? Aluminum screws?
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 12-04-2014, 05:33 AM   #9484
Also, I did the flat front arm and tower conversion, what is this rear conversion for? What does it do, exactly?
JDC Motorsports
Old 12-04-2014, 06:26 AM   #9485
Trader Rating: 121 (99%+)
Does anyone know if the actual overall size of the gears in the transmission are the same as the older generation models? I'm ordering a set of cut gears for my b5m and I'm wanting to lighten up my sc10 as well. Can I put all the b5m (minus an idle gear of course) transmission gears in my sc10 case? Or is it possible to swap out the entire transmission case with my b5 rear motor case?
skoalisbad4me is offline   Reply With Quote
Old 12-04-2014, 06:27 AM   #9486
Suspended
Trader Rating: 61 (100%+)
I would hold off on cut gears, the 3 gear transmission is right around the corner.
Socket is offline   Reply With Quote
Old 12-04-2014, 06:56 AM   #9487
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Here is a video of a friend of mine running his B5M on our local medium bite track. This layout is a MM car dream.
https://www.youtube.com/watch?v=lVNIJ-MRxJI&sns=fb
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 12-04-2014, 07:05 AM   #9488
Why wouldn't I just be able to swap them out to the 3 gear tranny case?
Old 12-04-2014, 07:37 AM   #9489
MikeXray's Avatar
Trader Rating: 73 (100%+)
Exactly, 3 gear doesn't eliminate the benefit..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-04-2014, 09:10 AM   #9490
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
And is not synonymous with running cut gears. The 3gear tranns is going to swap the motor position as well, which will drastically change how the car drives in other ways. It MAY not be what you want.
In my opinion.. cut gears aren't necessary in the slightest.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-04-2014, 09:15 AM   #9491
Trader Rating: 125 (100%+)
Is the lightened top shaft a common upgrade only for stock? I never see it listed on setup sheets. Thinking maybe the extra weight in the rear is a good thing for mod.
Chris Gierse is offline   Reply With Quote
Old 12-04-2014, 09:19 AM   #9492
Super Moderator
Tuning the weight of the car in general is maybe the biggest change you can make in how your car drives, second to only your tires. Mod and Stock will/can benefit from having a car who's weight is where it needs to be to perform best on the track. Sometimes that is lighter... sometimes that is heavier.
I would say running the lightened top shaft in particular, is less about reducing weigh of the car, and more about reducing rotating mass... which certainly benefits spec racing more.
- RCSpecialties -
Old 12-04-2014, 11:26 AM   #9493
vito's Avatar
on the Lunsford upper shock mounts how do you trim the stock spacer to fit and where?
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 12-04-2014, 11:52 AM   #9494
ironzgti35's Avatar
Trader Rating: 20 (100%+)
I didn't trim the spacers. When you tighten the shock it will force the plastic guide over the lunsford piece. No binding and you're good to go
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 12-04-2014, 12:10 PM   #9495
hey guys i am having a little problem with my car. i built it a few weeks ago, polished all ball studs and all the arms move freely as they should. i have ran 3 packs through the car. i noticed my front shocks were not returning all the way so i removed them and changed the fluid and made sure there was no air in there. I also made sure the shaft moved freely from all the way compressed to all the way extended. and it does move in and out freely with no binding and sticking. now i bolted the shocks back onto the car, and they still stick. the return almost all the way out but then stick. has anyone else had this problem and what should i do? thanks
TEAM HOLY ROLLERS
Team Associated B5M
PHILIPPIANS 4:13
bbrace3m is offline   Reply With Quote
