    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 12-03-2014, 01:56 PM   #9466
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by rc_speed View Post
17.5 stock
Long story short..build the car and drive it first. THEN decide what aftermarket parts will help you the most.
I'm not even going to suggest the RM rear arms, Front arms and tower to start. Because even those are my opinion.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 12-03-2014, 02:10 PM   #9467
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I have tried the MM arms several times. I just dont like them. they make the steering feel non linear and unpredictable. They do give more initial steering, but it feels weird to me. I found removing ackerman washers had a better feel and increased turn in using the RM arms. But yeah, you need to try them to see if you like them. I did not. The car comes with them, so might as well try them. The car does seem to land jumps a little better with the MM front arms.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-03-2014, 03:10 PM   #9468
3D-Seth's Avatar
Trader Rating: 21 (100%+)
Originally Posted by shannow View Post
Hi all,
I have a little setup question :
I'm running a B5m with shorty on super stock (13.5t with lots of timing) basically completely stock setup.
I have the same tires as everybody on the club (schum mini pin + cut stagger both yellow compound ) running on good grip carpet.
My issue is that the car tends do fight me on mid corners.
I can't zip around as fast as the others. It lets go sideways brutally but can be controlled back again almost instantly up to 2-3times in one corner.
From a viewer it looks like I'm fighting the car and that it's got a sort of side jumping(brutal sliding) ability.
Looking at many guys setup on similar track they have put stiffer spring all around but especially at the front (no one owns the b5m at my club apart from one guy that didn't show up for a while).
Would that help ? I also have a gear diff set at 2000 which I refill on a very regular basis.
Thank in advance
Jonathan
I don't have much experience with this car on carpet, but I do with other cars.
Have you tried going up in weight in diff oil? Like 4K or something? If I recall correctly, I was running 5K the couple nights I did carpet racing.
Also, stiffer springs front and rear would definitely help smooth things out.
What shock oil and pistons are you running? The other thing I found I had to do was go up in oil weight in comparison to dirt racing. Think I ran 42.5wt in the front and 37.5 in the rear. Depends on the track though.
Where is your ride height? I normally run 24mm front/rear on dirt, but on carpet I was dropping to 18mm or even lower depending on the jumps.
Also could try running longer camber links, generally helps reduce chassis roll on higher bite surfaces.
Hopefully this gives you a few things to try!
Seth
3D-Seth is offline   Reply With Quote
Old 12-03-2014, 03:18 PM   #9469
Suspended
Trader Rating: 61 (100%+)
Originally Posted by [email protected] View Post
anyone notice that the B5R rear arms rub on the chassis by the hinge brace? I had to shave the arms down a little in that area... Did not notice if it was making my buggy handle wierd but did not want to take that chance...
I keep looking at your pics, and my newly assembled car, and don't see it. Mine doesn't look at all like there's contact.
Socket is offline   Reply With Quote
Old 12-03-2014, 03:34 PM   #9470
Slight rub yeah.
Old 12-03-2014, 03:43 PM   #9471
Vinny Cancilla's Avatar
[QUOTE=3D-Seth;13696721]I don't have much experience with this car on carpet, but I do with other cars.
Longer camber links will increase chassis roll.
Serpent Srx8
Serpent America: Triton engines/ Nitro pro.Fuel/ Rc Addiction products : Vp pro Usa/Dialed-Rc
Barnstormers: Chester, NY, N.Y.. IRH Lindenhurst
Vinny Cancilla is offline   Reply With Quote
Old 12-03-2014, 04:24 PM   #9472
intimdator10's Avatar
I just bought a B5M and I am currently building it. I am looking for some gearing help. I will be running a LRP Flow esc and a LRP 13.5 motor.
intimdator10 is offline   Reply With Quote
Old 12-03-2014, 04:25 PM   #9473
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
My old kit rubs... My newer kit doesnt... Clearanced both anyways...
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 12-03-2014, 04:32 PM   #9474
shannow's Avatar
Wow very quick replies thank you !
The piston and oil are stock setup. I've just put red spring front (don't have stiffer rear spring appart yellow which maybe too much). And I've put 5k oil in the diff also I just added the 45g 25 brass weight at the front (everybody seems to use it on carpet).
I'll see how that will work
Thank you again
Jonathan
shannow is offline   Reply With Quote
Old 12-03-2014, 05:33 PM   #9475
zeakemedia's Avatar
Trader Rating: 74 (100%+)
What spacers are your referring to? Just curious
I've seen some of the cut gears where they decrease the overall width. I am not saying this is a better or worse method as far as durability simply that some require spacers. I believe the RC Shox gears require spacing and maybe CB?
Blake
DJO Race Designs | Fastraxx Hobbies | R1Wurks | Speedy's Racing Parts | The Ohio RC Factory
zeakemedia is offline   Reply With Quote
Old 12-03-2014, 05:56 PM   #9476
onefast8's Avatar
Trader Rating: 41 (100%+)
Idler centers regardless of width.
Jake R.
onefast8 is offline   Reply With Quote
Old 12-03-2014, 09:44 PM   #9477
So, moved the esc behind the battery and shortened some wires. Buggy tips on at 1531 grams. Still have more to remove, like screws, Turnbuckles, slipper, etc. Why is minimum weight 1499? I don't get it. Why not call it even 1500?
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 12-03-2014, 09:56 PM   #9478
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 12-03-2014, 09:57 PM   #9479
Trader Rating: 29 (100%+)
What class do you run? Most people prefer the car around 1540 gr. If you get the car too lite it seems like it gets too twitchy and hard to drive. In mod from time to time we will throw a square pack in it to calm it down a little bit. with as fast as stock motors are these days im sure that too lite of a car will have an adverse effect.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 12-03-2014, 11:45 PM   #9480
McCroskey's Avatar
Silly question. When figuring the weight of the car, is it with or without tires on?
Looks like I picked the wrong week to quit sniffing tire sauce.
McCroskey is offline   Reply With Quote
