    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 11-30-2014, 01:05 PM   #9391
Suspended
Trader Rating: 61 (100%+)
Originally Posted by racer1812 View Post
Soooo..Where does the B5M leave X-Factory actually? As far as the 2wd buggy class. Before the B5m they seemed to be moving towards becoming more of a complete car company vs. making conversions. Now it seems AE put a big hole in that boat. Their CF B5m chassis looks fantastic but AE also has the ability to engineer their own CF chassis within a couple weeks and have it programed into a CNC in a day.
Again, their stuff is cool but it would seem to me they took a big hit as far as where they were taking the company.
For obvious reason I'm asking here and not in the X-Factory thread..The Mafia would put a hit out on me
When your number 1 reason for the upgrade is this:
Totally dialed CF look nothing else like it for your B5M.
You know you're grasping at straws.
Socket is offline   Reply With Quote
Old 11-30-2014, 07:27 PM   #9392
Trader Rating: 68 (100%+)
I bought a b5mm used off RCT. I'm curious if it already has the b5rm rear a arms on it already. The seller stated there were b5rm arms as part of the package but I'm uncertain if they are installed. I suspect the are not since the left rear arm is marked left and not reversed. Can someone please confirm? Also for those that have made the change how did it change the handling and how significant was the change.
tom73 is offline   Reply With Quote
Old 11-30-2014, 07:36 PM   #9393
Trader Rating: 29 (100%+)
If its a RM rear arm it will have two of the little sway bar nubs on each arm. The MM ones only have one
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 11-30-2014, 07:38 PM   #9394
It will give the car more forward bite but we wont get into the draw backs of running them. If the track you run on is loose then they might be a good idea to run.
Old 11-30-2014, 09:46 PM   #9395
mschumi101's Avatar
Trader Rating: 21 (100%+)
As stated above it seems you have the stock MM rear arms. He could have meant the front arms were from the RM. The RM front arms are flat, compared to the "gullwing" MM front arms.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 11-30-2014, 09:58 PM   #9396
HUH?!?
Old 12-01-2014, 12:36 AM   #9397
Trader Rating: 18 (100%+)
Going to rewire mine this week. Hopefully I'll be able to figure out a way can run inline and standard without moving the electronics at all.
iTz Nicholas72 is offline   Reply With Quote
Old 12-01-2014, 08:20 AM   #9398
I was able to make it so that I can run in any number of setups without having the re wire.. I can run inline, battery forward and the ESC mounts between the waterfall and the battery. If I move the battery back, I need to put the ESC on top of the battery, keeing the ESC as close as I can to the waterfall and still clearing the body. If I mount the battery sideways (stock) I can move the ESC to the top of the battery or in front of it.
When I wired the motor, I just left a little extra wire, then spun the ESC a couple of times to twist the motor wires... This takes up the slack and I can go back when I need the extra wire. Seems to work well for me.
AlmostIllegal is offline   Reply With Quote
Old 12-01-2014, 09:48 AM   #9399
Trader Rating: 99 (99%+)
I have run my b5m a total of 4 times, front bearings feel very gritty and do not spin freely when put together in the steering block.
Is this a bearing issue or some type tolerance issue?
RC8.2e - B5M - B44.3
isarctard is offline   Reply With Quote
Old 12-01-2014, 10:15 AM   #9400
Have you cleaned the bearings? Might just have to replace them. I purchased a revolution kit from Avid so that I can replace the factory bearings as they wear out. $22 shipped to my door.
DLE RC is offline   Reply With Quote
Old 12-01-2014, 10:18 AM   #9401
What's the predecessor to the square fuzzie? Is it the holeshot?
Old 12-01-2014, 11:13 AM   #9402
Mason's Avatar
I believe you are correct. hole shot, square fuzzy, evil twin.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 12-01-2014, 11:42 AM   #9403
MikeXray's Avatar
Trader Rating: 73 (100%+)
You're not alone on this, the bearings do wear out faster than normal for some reason. I though gluing the inserts into the C-hub would fix it, but they still get gritty fast.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-01-2014, 11:56 AM   #9404
RA99GT's Avatar
I think there was a fuzzie, flat fuzzie, then square fuzzie.
-MurfDogg Racing- Race One or Chase One! -http://www.murfdogg.com/
My RC Racing Blog- http://ra99gt-rcracing.blogspot.com/
My YouTube Channel- http://www.youtube.com/user/ra99gt
RA99GT is offline   Reply With Quote
Old 12-01-2014, 12:00 PM   #9405
Jmuck69's Avatar
Trader Rating: 14 (100%+)
It has to do with the crush sleeve in between the two bearings in the hub being out of tolerance. Solution is place (1) .20mm shim along with crush tube. This will give the additional support the bearings need when you tighten down the wheel.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
