    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 11-23-2014, 06:38 PM   #9271
kslimm0714's Avatar
Trader Rating: 18 (95%+)
Hey guys im sure this was talked about but here is my question this is my first 2wd buggy and was wondering i already have saddle packs has anyone seen a difference performance wise between saddle and shorty
Kerry Slimm
HotBodies - De Racing - Dialed-RC Hobbies - Upgrade rc - FTM Tire Grip - Boca Bearing
kslimm0714 is offline   Reply With Quote
Old 11-23-2014, 06:44 PM   #9272
MikeXray's Avatar
Trader Rating: 73 (100%+)
Just realized a car I got has RM front arms, but the MM tower, I remember someone posting the right way to make that work?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-23-2014, 06:48 PM   #9273
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by [email protected] View Post
I have this same issue and want a cure also
change the dirt to super tacky clay, lol. lol, J/K. I run on medium to high bite indoor tracks. For rear bite, I run 3-1 toe/squat, Rm rear arms and hubs forward. Smallest pinion and spur combo to move the motor back. I weight in at 1560 grams. And I run my shorty back with the esc center-lined against the battery. Rear shocks inside/inside. 32.5/30 oils with Avis 1.5x1.1 front and 1.6 rear pistons. White front and grey rear springs. Also, my slipper is set to prevent wheelies, meaning it is not locked. I am running the Avid Evo woth white/red/white. I have plenty of rear bite, but I could possible have more traction on the track than some of you.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-23-2014, 06:57 PM   #9274
thecman26's Avatar
Trader Rating: 99 (100%+)
Get the RM front tower, easy fix and pretty cheap. My $0.02
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 11-23-2014, 07:29 PM   #9275
Cridd's Avatar
Trader Rating: 16 (100%+)
Yes change your tower.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 11-23-2014, 08:28 PM   #9276
MikeXray's Avatar
Yeah I know that, I will get one, but I was curious what the setup is to use the MM tower.
Old 11-23-2014, 08:56 PM   #9277
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
Running same except 1.6 all around... Ill try loosening my slipper... Anyone know if you can program timing on stock spec v3.1 hobbywing??
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 11-23-2014, 08:57 PM   #9278
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Originally Posted by JFuel11 View Post
I am curious what your thoughts may be on the following:
My B5M is almost perfect. We run on a medium to lower traction surface indoors. The B5M has been fantastic taking the win last weekend. I would like to obtain just a little more rear grip or forward bite upon corner exit. The car tends to step out a little bit right when you pick up the throttle on exit. Keep in mind again car is really good and this can be managed with throttle, however I was curious what a few of you thing of these options... I will test some later this week as well.
1. Go down in rear spring rate to allow rear to drop faster on throttle currently on white and may try green.
2. Go down in rear shock oil. Currently at 30 may try 27.5 with the 1.6 piston
3. Go down to 0 degrees anti-squat vs current 1 degree
4. Go up in front spring rate as I am currently on green and may go up to white or gray.
5. Move battery back as it is one foam from back position now.
Being car is still rotating off corner would a role center change improve this as well. I am running Schelle Caster Plate in up position with no shims.
Thanks!
JRF
I would try a roll center change. Try lowering the inner rear link 1mm, it should help keep the car more planted and create more traction. Its also a much quicker change than most of whats listed above. I had a similar problem with my car, but it was more entry-mid corner transitioning onto the throttle. I went to 0mm and it helped greatly. Another think you could try is adding .5 degrees of toe at the hub.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 11-23-2014, 09:18 PM   #9279
Trader Rating: 125 (100%+)
Does anybody know how much the aluminum screw kit saves in weight?
Chris Gierse is offline   Reply With Quote
Old 11-23-2014, 10:02 PM   #9280
3D-Seth's Avatar
Originally Posted by The Wease View Post
I'm using a 6070 just had to remove the spacer , I get full deflection left and right
Thanks! Appears your 6070 has a touch more clearance than mine. I ground down the case just a touch and everything is moving freely now!
Seth
3D-Seth is offline   Reply With Quote
Old 11-23-2014, 10:32 PM   #9281
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by McCroskey View Post
for example a 81/36 and a 72/32 will both give you a fdr of 5.85, what determines the combination you go with? What would the difference be running each combination on the same motor?
Motor position. Larger gears move the motor (and therefor your weight bias) forward, smaller gears moves it back.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-23-2014, 10:33 PM   #9282
Super Moderator
That is what I am currently running. Dialed. Shorten your shock shaft stroke to 18.5mm. (i think you go from 2mm to 4mm internal limiters).
- RCSpecialties -
Old 11-23-2014, 11:51 PM   #9283
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
What does it do differently with mm tower and flat front arm?
pink_sleeve is offline   Reply With Quote
Old 11-24-2014, 04:29 AM   #9284
McCroskey's Avatar
Thanks. I hadn't thought about weight bias. What role does the motors torque and RPM play in the making a choice? I'm thinking a low torque motor would have a hard time spinning a larger pinion with a small spur vs a small pinion with a larger spur. I've tried different combinations and I'm not getting the results I expect.
When I marshal I've noticed that those that are fast, when they come around a turn and hit the throttle their car launches forward real hard. Mine doesn't have that jump but instead has to build up speed. ESC is a Tekin RS Gen2 and the current limiter is turned off when running mod and in blinky when running stock, so that's why I'm focused on gearing.
Looks like I picked the wrong week to quit sniffing tire sauce.
McCroskey is offline   Reply With Quote
Old 11-24-2014, 04:42 AM   #9285
STLNLST's Avatar
What motor are you running? I have no problem with pull out of the corners in blinky. I'm geared 72/30 with a tekin gen2 motor.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
