    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 11-15-2014, 09:47 PM   #9136
Failed to read
nordfink is offline   Reply With Quote
Old 11-16-2014, 03:17 AM   #9137
Captain, I still haven't figured out what Nordfink is talking about, have you?
mackelby is offline   Reply With Quote
Old 11-16-2014, 10:22 AM   #9138
does anyone know the weights for the xfactory carbon fiber chassis and the aluminum stock chassis for the b5m?
gearit is offline   Reply With Quote
Old 11-16-2014, 10:37 AM   #9139
Trader Rating: 14 (100%+)
Originally Posted by [email protected] View Post
Looks heavy and big
No more so than the Finnisher that is the flavor of the month out here.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 11-16-2014, 04:20 PM   #9140
Default B5m Build
Bout finished building the B5m. Haven't build a car in 13 years. Comparing this chassis to the XXX that has been sitting on my bookshelf since 2002 is interesting. Seem like there is a much larger emphasis on the rear wing. It's much bigger, and looks like it was designed on CAD and wind tunnel - looks like it might actually do something. The bigger shocks can't help but provide more traction(which will be need to offset the traction lost with the bound up ballcups). This car looks like it would be much more difficult to break than the cars of the era I raced last (98-02). I love how the hinge pins are captured, and I no longer have to deal with c-clips
Gotta say I'm not impressed with AE's quality control. In addition to super bindy ball cups that everyone mentioned, the Shock end cups were even tighter and bound up......One of the outdrives is defective. The drive shaft fits in it so tightly that I can dangle the entire tranny from it. Ive never seen that happen. That will destroy the handling of the vehicle I'm guessing...When did replacement outdrives become so expensive?........The diff is not very smooth, hopefully when I break it in, it will be better............Also, one of the Shock caps bleeder holes is not drilled out or molded out. Going to have to try to find a tiny drill bit to fix.
Can't wait to get it finished and take it out to the track!
mgers75 is offline   Reply With Quote
Old 11-16-2014, 07:41 PM   #9141
3D-Seth's Avatar
Trader Rating: 21 (100%+)
Considering picking up this kit, have a lot of experience with 2WD buggies, just one of the "other" brands. Familiar with mid motor cars so all is well there. Running on high bite clay in mod, have a couple of questions (I have already checked the first page):
What spur gear is everyone running in mod? With the other brand mid motor car I've been running, we went to the smallest spur possible to get the motor as far back as possible. Similar concept here?
Are there any necessary parts or tuning options I should have in my box? Planning on having both the flat arms and tower and gull arms/ tower. Have tons of springs, oils, etc, so not concerned about that stuff but more B5 specific stuff.
What should I have in my box for spare parts? Arms, spindles, castor blocks?
Any help is appreciated!
Seth
3D-Seth is offline   Reply With Quote
Old 11-16-2014, 11:49 PM   #9142
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
nope
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-17-2014, 03:16 AM   #9143
Big Features's Avatar
Seth
Most folks run 75-78 spur gears. As for parts, you really dont "need" any options to make the car fast in Modified racing. I personnaly like the vented 2 pad slipper from the B4.2 WC (V2) and the Factory Team rear camber link. That is really all you need. I also the RM rear arms. They are 2mm shorter and sweep the wheels forward just a hair. Hope this helps.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 11-17-2014, 08:44 AM   #9144
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
In regards to the ADI MM Waterfall and fan mount, I was planning to pick one up to try out, but after talking friends at the track, I will pass. Seems like they are not very durable. Several locals are breaking them. The material appears to just not be up to RC specs. Just an FYI. Meh, I was kinda hoping it would be good. On the plus side, the weather is getting cooler, so my cars are dropping temps anyway. Wont really be an issue until next spring. Maybe by then someone (AE) can make a molded waterfall with a fan mount.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-17-2014, 09:14 AM   #9145
Jmuck69's Avatar
Seth
I normally run the 81 spur but do switch to 78 to move the motor back if needed.
  • glue front spindle inserts in
  • FT aluminum shock mounts or Schelle shock mounts
  • Aluminum C & D plates with inserts
  • Aluminum rear camber plate from Schelle (gives you one additional camber hole)
  • AE FT aluminum steering
  • AE FT aluminum rear hexes
Spare parts to keep would be the front suspension block. the buggy is tough. If you run Mod then putting electronics in-line and all of the other crazy get ups people run are not necessary. I think the stock AE 3 pad slipper is crap and would invest in one from Schelle or similar. Run it with normal layout. Oh and most importantly, have fun and clear some shelf space for the trophies that will be coming!
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-17-2014, 09:23 AM   #9146
I recently switched to the Proline Trifecta wing. Anyone tried this wing and noticed anything different in steering? I have noticed a bit more push. I think this is partly do to the downforce and partly to the weight. The trifecta wing is about 20 grams heavier than my previous JC wing.
Old 11-17-2014, 10:52 AM   #9147
It had been 22 years for me. The speed of the electronics today vrs. 22 years ago is INSANE. The straighter the track the worse I was. I was TERRIBLE! I built my shocks in a vented bladder configuration. Used Serpent bladders. The longest strait away is the farthest from drivers stand and is 90 degrees from stand. I looked as though I was drunk as a skunk. How embarrassing.
Old 11-17-2014, 12:11 PM   #9148
mxnickj's Avatar
Trader Rating: 51 (100%+)
Hey guys, can anybody help me with a setup that is forgiving for a medium traction clay track? I don't want a really aggressive setup but something that will be a little easier to drive. I'm currently at 32.5 oil, 3x1.4 pistons in front, middle hole on the tower and outside on the arms and 3x1.6 piston with 30wt oil in the rear, inside hole on tower and inside on the rear arms.
mxnickj is offline   Reply With Quote
Old 11-17-2014, 12:22 PM   #9149
are you running the B5 rear motor front tower and f/r arms?
Old 11-17-2014, 12:55 PM   #9150
mxnickj's Avatar
No, all the B5M parts are still on the car.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
