    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 11-14-2014, 08:34 AM   #9076
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Thanks Krio, I'll be at the same track again tomorrow and will mess with drag brake during practice. When I could get the car to break lose enough to rotate it was fast but couldn't get it consistently to be worth the effort so I just was going neutral and coasting through.
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 11-14-2014, 08:45 AM   #9077
Krio's Avatar
Trader Rating: 150 (99%+)
If the car won't rotate enough without breaking the rear tires loose, then some setup changes will be in order. Hopefully drag brakes will help you cut down on your cornering times.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 11-14-2014, 09:10 AM   #9078
Trader Rating: 29 (100%+)
Yeah i think your diff may be a little too snug, gettin your drag brake set properly for your driving style will definitly help your overall lap times
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 11-14-2014, 09:56 AM   #9079
scr8pn4205's Avatar
On the diff? When you tighten it do you lock the slippper and hold one wheel and the locked spur and try to rotate the other wheel so it barely will slip the diff or is there a different way to do it?
thanks
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 11-14-2014, 10:43 AM   #9080
samnelso's Avatar
thanks
It's all feel. How I do it is I grab a tire in both hands and give them a quick spin in opposite directions so to not spin the drivetrain. I like the tires to rotate about 1/2-3/4 of a rotation after the spin.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 11-14-2014, 11:19 AM   #9081
scr8pn4205's Avatar
Thanks I will try that. U goin to the gobbler race at RCE?
Airtronics M12
TSR power
Old 11-14-2014, 11:29 AM   #9082
samnelso's Avatar
Absolutely and looking forward to a new layout!
Old 11-14-2014, 11:30 AM   #9083
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Drag Brake..In rear motor I ran 15-20%. In my MM I'm running 5% and have no desire or need for anymore. I had started with 18% (SP Reventon Pro) and the car would snap loose. As previously stated, car setup will have an obvious affect though.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 11-14-2014, 11:34 AM   #9084
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
Never could get used to drag brake... Car would snap loose to much!!
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 11-14-2014, 11:39 AM   #9085
scr8pn4205's Avatar
Im gonna try and get down there for that race and give the car a shakedown. Any setup tips for RCE with the B5M? Tire? prob blue dirtwebs open cell front closed cell rear?
Airtronics M12
TSR power
Old 11-14-2014, 11:45 AM   #9086
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Then you simply had too much. It isn't an on/off setting. I set mine JUST enough to control how easily the car rolls on it's own. I am running %12 or so on my Hobbywing. It's not very much at all.. you can just barely tell it is there. Run too much, and yeah, you would literally be hitting the brakes when your trigger reaches it's neutral point.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-14-2014, 11:53 AM   #9087
samnelso's Avatar
I really haven't been much of anywhere else offroad besides RCE, so my setup suggestions are probably limited. In general though, kit springs, f/r 32.5/30 oil with f/r 1.6 or 3x1.4 pistons, and b5 arms should get you going.
Tires, probably blue or green dirtwebs or PL electrons. Closed cell rear, front is your preference.
Old 11-14-2014, 11:58 AM   #9088
pumpkinfish's Avatar
Originally Posted by heinen81 View Post
I have tried these Vant shorty batteries from Barn Floor RC and love them. Good price, great performance and the shipping is instant. Use coupon code ILLTRYVANT for additional discount and free shipping.
http://thebarnfloor.com/catalog/prod...3#.VGYAIU0tCUk
What's with the dual 4mm plugs? Do they both need to be plugged in? I run 4mm low profile connectors on my esc's.
pumpkinfish is offline   Reply With Quote
Old 11-14-2014, 12:00 PM   #9089
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Being new to 2wd, I need some tips on braking? Last week running on damp clay, slicks all around was the best tire option, but my brakes were useless! Every time I used them the car would whip around and lock the rear up. Esc brakes are set at 40 in a Tekin RS, radio EPA was at 80 with some expo to slow it down even more. The only thing I didn't get a chance to try was drag brake. Is it just a learning curve with 2wd or could it be somewhere in the setup?
yes too much break. try to recalibrate the esc and radio again to make sure everything is set right. try it again and see where your at. highly likely you will need to dial down the esc break and the epA. you should be able to haul ass down the straight away and slam on the breaks... the car should not break free, just slow down.
ryanpatrickgore is offline   Reply With Quote
Old 11-14-2014, 12:29 PM   #9090
heinen81's Avatar
Here's what their website says ...."Dual 4mm Ports Note: You do not need to use all four 4mm ports when connecting the battery to your speed control. You can use only 2 ports as usual. The extra ports are provided for high-current draw systems since the battery has such a high output rating."
I have mine soldered 90 deg to the bullet plug. Sticks up a few mm, but all in all, fits great in the B5M.
-Speed Passion- Team Associated B5M; SP PRO 1.1 & 17.5 FANTOM TEAM HT
-Speed Passion- Team Associated B44.3; SP Reventon PRO 1.1 & 7.5 v3.0/13.5 MMM
heinen81 is offline   Reply With Quote
