    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 11-11-2014, 08:56 AM   #9016
heinen81's Avatar
Well moron, I was more asking a question about roll centers and how it affects the handling of the car. And, since some guys on here were nice enough to explain the dynamics behind it, I now know WHY the change would have an effect, and how. So here's a step for you..
1. If you have nothing useful to provide, shut your mouth.
-Speed Passion- Team Associated B5M; SP PRO 1.1 & 17.5 FANTOM TEAM HT
-Speed Passion- Team Associated B44.3; SP Reventon PRO 1.1 & 7.5 v3.0/13.5 MMM
heinen81 is offline   Reply With Quote
Old 11-11-2014, 09:10 AM   #9017
Originally Posted by micrors4guy View Post
i do not believe that AE makes a bladder conversion for the 12mm shocks.
I used serpent bladders, work well. No leaks yet. I built them as vented setups.
mackelby is offline   Reply With Quote
Old 11-11-2014, 09:11 AM   #9018
Here this will keep you busy for awhile.
Tune With Camber Links
Old 11-11-2014, 09:34 AM   #9019
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
he gave you about the best advise one can give for roll center adjustments. I have found that roll center adjustments will give different results based on the type of surface and how hard you brake on corner entry and how much throttle you give on exit.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 11-11-2014, 09:37 AM   #9020
heinen81's Avatar
Thanks, found that after I originally posted. Should have searched "Camber links" instead of ball stud height. Found more info, and some stuff on the B5M page of petitrc.com as well. Our local track isn't open during the week, so unfortunately it's hard to go practice with these changes ahead of time. The only track time available, is race day, so was looking for information that would lead me to a starting point instead of running a bunch of different trials. Thanks again.
Old 11-11-2014, 09:41 AM   #9021
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Heinen,
I have some links on the first page that might help. Under "other resources".
RCBuddha is offline   Reply With Quote
Old 11-11-2014, 09:44 AM   #9022
try it one day during qualifying. one qualifier use no ball stud stud washer, the nes try 3-4mm of washers. note the feel of the car then compare the times for each.
it may not lead to the best finishes for that day. However, if you focus on just driving and making no mistakes with those changes you will get good information and feed back on what you will need to change moving forward.
Rob Jensen
Old 11-11-2014, 10:36 AM   #9023
heinen81's Avatar
That's a good idea, the only thing that stinks is usually through the qualifiers, the track still has allot of bite, and I am not really looking for more side bite then. Once the mains roll around, it sort of develops that thin film of dust, and depending whether or not the previous mains drivers decide to blow off the track... you sometimes do not know what you are going to get in terms of a track condition until you are on the stand. The car has been leaps and bounds better than the first times out on a slightly loose track... I have started using SK Red sauce for the main, added a little weight behind shock tower, tipped my rear shocks in to the first hole from center of shock tower, removed ball stud washer, and moved hubs all the way forward. I can now at least turn my punch back up and it stays under me off the corner. It could be just a tick tighter out back, so this week I bought the aluminum +2/-2 ball stud mount to try in the main and will start this weekend at -1. Thanks again!
Old 11-11-2014, 10:51 AM   #9024
no problem, are you also running the RM rear arms? those are supposed to move the hubs forward a little more as well.
Rob Jensen
Old 11-11-2014, 12:39 PM   #9025
heinen81's Avatar
Not yet, but they are on the list. I believe it is another 1.5 mm further ahead if I remember right. We'll see how I am sitting after this weekend, and go from there if I feel I could stand to gain a little more. Dont want to change too much at once and move myself right back out of the ball park lol
Old 11-11-2014, 01:05 PM   #9026
BRSracing's Avatar
Trader Rating: 55 (100%+)
Thumbs up
Originally Posted by Vincent Ringler View Post
I'M going to try and answer your Ball stud question. What I'M going to tell you will give you all the info you need for how raising /lowering ball stud feels to you on the track.
Are you ready:
1) Go to your local track
2) Drive the car (get a good feel for it)
3) Now raise/lower ball stud
4) Go drive the car
5) Think about how your car preformed. look at your lap times
Now you can tell us what you found out.....
Six posts and already suspended
BRSracing is offline   Reply With Quote
Old 11-11-2014, 01:12 PM   #9027
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Whether the guy was being a donkey or not. Keep YOURSELF out of trouble and use the report function. The mod staff will decide if a post is out of line.
(the fact that he's suspended is completely unrelated to his post in this thread)
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 11-11-2014, 02:22 PM   #9028
heinen81's Avatar
^ ^ True. My bad, sorry everyone. I try to help anyone who may be looking for help, regardless if it seems obvious or not. I understand testing is the obvious way to determine what works, however with a limited schedule, I wanted to make sure I was at least starting on the right path to keep from wasting time on race day.
Old 11-11-2014, 03:52 PM   #9029
RCBuddha's Avatar
Default New item from RCShox
RCshox products and services
Old 11-11-2014, 04:52 PM   #9030
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by RCBuddha View Post
nice
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
