    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 11-10-2014, 07:40 AM   #9001
heinen81's Avatar
Learned allot of things from going down to Trackside to check out the Spektrum Nationals, which were run on a very high bite track. First, B5M's dominated buggy without a doubt and all the guys appeared to be using the flat front arms and Dirt Webz. The one thing that did shock me while checking out Cavalairi's (sp?) BM5, was how out of the box it looked! I see all these pictures of the battery trays hacked apart, esc's stuck to batteries that are run length-wise, ect... and all the winning B5M's down there looked out of the box except for the rear aluminum ball stud mount, aluminum rear hubs, aluminum front pin retainer and a set of clamping hexes.
One question i do have, in regards to the aluminum rear ball stud mount, depending on which way you mount it, is either +2 or -2. On medium bite tracks, does anyone have an idea which way would help the car more? What exactly does raising or lowering the rear ball stud mounting accomplish? thanks!
-Speed Passion- Team Associated B5M; SP PRO 1.1 & 17.5 FANTOM TEAM HT
-Speed Passion- Team Associated B44.3; SP Reventon PRO 1.1 & 7.5 v3.0/13.5 MMM
heinen81 is offline   Reply With Quote
Old 11-10-2014, 07:45 AM   #9002
Trader Rating: 18 (100%+)
I rub mine -2 because you can still run 4mm of washers getting the +2 roll center without having to flip the mount. Plus the CG is lower lol
Awesomatix A800XA - Xray XB2 2018
iTz Nicholas72 is offline   Reply With Quote
Old 11-10-2014, 08:12 AM   #9003
heinen81's Avatar
See, roll center. That was what I thought this affected... but all the tips I see out there, is everyone says the looser the track, lower the ball studs. Wouldn't this take away from side bite though? I could see how it would help forward traction, but to get the car to roll over and induce side bite... wouldn't you want to raise the ball studs/roll center to induce a bit more chassis roll?
Old 11-10-2014, 08:24 AM   #9004
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
When ever I lower the link, I feel like side bite is lost. It is one of the things I do when traction rolling and always seems to make it better.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-10-2014, 09:17 AM   #9005
Raise ballstuds = lower roll center = more chassis roll.
Lower ballstuds = higher roll center = less chassis roll. Raising ballstuds on low grip increases chassis roll which should theoretically increase grip. Sounds like you have roll center and center of gravity a bit mashed up.
nordfink is offline   Reply With Quote
Old 11-10-2014, 05:33 PM   #9006
Trader Rating: 90 (100%+)
anyone have trouble fitting the exotek slipper eliminator.
It did not finish correctly on the top shaft... The 3mm screw holes seemed under sized... Quality control these days is non existent.
dan-o is offline   Reply With Quote
Old 11-10-2014, 06:16 PM   #9007
pretty sure they are 4-40 screws....
Old 11-10-2014, 06:41 PM   #9008
Looks like Kody ran the 3 gear in his MM at the spectrum race.
Old 11-10-2014, 06:59 PM   #9009
hollywood3705's Avatar
Anybody have any experience with a gear diff in mod on medium to medium high bite light dust? Curious on how you changed your setup and the differences. Mine is on the way. Also any tricks like different gasket or different orings
hollywood3705 is offline   Reply With Quote
Old 11-10-2014, 07:07 PM   #9010
Were the Dirt Webz the 2.2 or the 2.4?
T5M Fantom 13.5 Tekin RSX
B5M Fantom 17.5 Tekin RSX
Losi 8E 2.0 Thunder Power 1900kv Hobbywing
Losi 8TE Castle
Losi 8T Nitro
jsteve5050 is offline   Reply With Quote
Old 11-10-2014, 07:16 PM   #9011
danny d's Avatar
2.2 for the dirt webs. We had the 60mm rims but not the tire....
danny d is offline   Reply With Quote
Old 11-10-2014, 10:23 PM   #9012
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Raising the inner ball studs doesn't raise the roll center, it lowers it.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-11-2014, 06:23 AM   #9013
Originally Posted by mackelby View Post
anyone tried bladder build shocks on their cars?
I assume that means no.lol
Well I have, hope to try it out car for first time Wed. Unless another auto I am apparently responsible for breaks down between now and then.
mackelby is offline   Reply With Quote
Old 11-11-2014, 07:21 AM   #9014
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
i do not believe that AE makes a bladder conversion for the 12mm shocks.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 11-11-2014, 08:43 AM   #9015
Suspended
I'M going to try and answer your Ball stud question. What I'M going to tell you will give you all the info you need for how raising /lowering ball stud feels to you on the track.
Are you ready:
1) Go to your local track
2) Drive the car (get a good feel for it)
3) Now raise/lower ball stud
4) Go drive the car
5) Think about how your car preformed. look at your lap times
Now you can tell us what you found out.....
Vincent Ringler is offline   Reply With Quote
