    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree15Likes
Old 11-04-2014, 06:27 PM   #8941
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
This change in rotation cause throttling up in the air to drop the nose of the buggy vs. braking? Seems like I remember something about that with the early xfactory cars when they used 3 gear transmissions.
Cameron Kellogg is offline   Reply With Quote
Old 11-04-2014, 06:35 PM   #8942
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Zaxbys View Post
Yep, *now* I see that. Don't know how much I believe the "less rotating mass" or how much of an effect it'll have. It's just one more part you have to buy. The more interchangeable the parts are, the better.
+1 it wont be that much less rotating mass. they should have reused their current topshaft.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-04-2014, 06:47 PM   #8943
Jim Hustins's Avatar
I don't think it will have a big effect on it. The biggest factor of attitude adjustment in the air is the rotating mass of the tires.
I owe it all to Papa Lou.
Team Driver: Pro-Line, Maclan Racing, Xpert Servos, RC Soup, MIP, ARC
http://www.prolineracing.com/blog/team/jim-hustins/
http://www.youtube.com/user/jjlove1217?feature=mhee
https://www.facebook.com/jim.hustins.rc.racer
Jim Hustins is offline   Reply With Quote
Old 11-04-2014, 08:12 PM   #8944
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
It does have a big affect on it. Braking in the air with the motor spinning the opposite direction really limits how well you can drop the nose in the air. Hated it when I ran my durango that way.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-05-2014, 05:02 AM   #8945
RC10Nick's Avatar
motor rotation on an mm3 is the same as the motor rotation on an rm3, so you'll be able to jump just as well with it as with your old b4.
my dingo mm3 jumps perfectly fine. I can get the nose to do whatever it needs to in the air.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 11-05-2014, 07:40 AM   #8946
Ah yes, I forgot that the motor plate was moved to the same side as the normal 3 gear trans would be.
Old 11-05-2014, 11:32 AM   #8947
Maybe overthinking it. The only difference I can see with the 3 gear is the pinion is driving the spur from the front of it rather than the back of it which does not change the rotation from clockwise to counter clockwise. Guys correct me if Im wrong. I would think you would always want the rotation driving down which engages traction in its simplest terms.
If I recall correctly the 4g mid still drives the rotation down not up.
Bubonic-X is offline   Reply With Quote
Old 11-05-2014, 11:34 AM   #8948
Trader Rating: 59 (100%+)
no, a 4 gear trans spins in the opposite direction of the tires and a 3 gear spins same direction of the tires
rc23 is offline   Reply With Quote
Old 11-05-2014, 12:27 PM   #8949
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Bubonic,
This was posted a while back:
http://www.team-durango.com/blog/201...onfigurations/
Hope this helps.
RCBuddha is offline   Reply With Quote
Old 11-05-2014, 03:18 PM   #8950
Super Moderator
There is no such thing as "down or up" when you're talking about a motor that is spinning it's shaft in a circle.
- RCSpecialties -
Old 11-05-2014, 05:45 PM   #8951
Trader Rating: 28 (100%+)
What's the hot setup you guys are running for indoor mmedium to high grip?
T
TONY BACONATOR - Factory Team Associated, AKA, Byron's Fuels, BOOM R/C Graphics, Dialed R/C
mxtoeknee is offline   Reply With Quote
Old 11-06-2014, 10:02 AM   #8952
TonyWest's Avatar
Trader Rating: 50 (100%+)
Default Driving on ultra low grip
Are there any new tips guys are coming up with for ultra low grip tracks.
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 11-06-2014, 10:25 AM   #8953
Put the motor in the rear haha. Have you tried the Brass C Block?
Old 11-06-2014, 11:02 AM   #8954
dbowen's Avatar
There's a lot of things you can do for a low grip set up as Wildcat said get the brass 20 gram c block run the shorty pack all the way back, put the rear shocks all the way in on the tower, run a green rear spring, lighter oils, if you get the brass or aluminum c block you can run 3.5 degrees of toe and then put the .5 degree inserts in your hubs to get 4 degrees of total toe, and run the b5r rear arms and push the hubs all the way forward those are just a few things you can do to get more grip for a low grip track and it should have just as much grip as a rear motor car!
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 11-06-2014, 11:07 AM   #8955
heinen81's Avatar
I am on my third week of running my B5M with a 17.5 setup, at an indoor medium length track that starts out tacky, and after 80+ entries and 6 hours, starts to develop a layer of dust, even when the track is blown off between rounds.After the first week I thought... crap, i ordered the wrong configuration, this Mid motor sucks. On throttle out of the corner, I couldn't keep the rear wheels under me for the life of it.
I also looked at the brass pieces and thought "well thats dumb, because if the track is tacky to start, you have to pull everything apart to switch hangers back and forth as the track changes" I actually put the 30* block in front to assist in steering, and drilled and tapped the rear shock tower for a 4mm screw, and made a block of weight to add as the night wore on and the track went away. Car stuck like glue, no more feathering throttle and ddrs punch is back at 90%. night and day difference. The only other thing i did to make it work, was i also ran Sticky Kicks Red. Traction is no longer an issue.
-Speed Passion- Team Associated B5M; SP PRO 1.1 & 17.5 FANTOM TEAM HT
-Speed Passion- Team Associated B44.3; SP Reventon PRO 1.1 & 7.5 v3.0/13.5 MMM
heinen81 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Crazyybikerdude
