Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#8929
#8931
I have had both MM and currently have the BM5. Both hook up very similarly in my opinion. The edge in jumping and overall ease of driving goes to the B5M I would have to say. And once AE gets their poop in a group they should also have the edge in part support.
#8932
Not sure if it has been covered yet, but a Jconcepts finisher Centro body will fit right on a B5m. Doesn't quite contour the chassis in the front but fits right on no trimming needed.
#8933
[QUOTE=Wild Cherry;13213664]Had to on mine. It's been a long time but I'm getting some nice airbrushed bodies! Whoop!
#8935
#8936
Ugh...they called me back and told me otherwise. Apparently the etching needs to face the shock. So it will face forward on the rear-mount, backward on the mid-mount. Sorry for the confusion. They also shared the intent to get a quick document published online to show how the hub differences convert vis-a-vis the ball stud hole mounts and how that compares to the hub inserts on the plastic version.
-kyri
#8937
Anyone have a good set up for these new aluminum rear hubs? I called AE and they had no clue what even the stock setup was
#8938
With my B4’s I always liked running 0 anti squat in the rear, no shims under the front rear arm mount.
I am a little confused how to run / try 0 anti squat on the B5. Is there a C /D mount combo that will do this?
Would you need to buy the aluminum C / D mount and run no spacers?
#8939
#8940
The C and D mounts have inserts that change the toe and anti-squat. I'm not totally sure if there is a 0 option. There's no spacers like on the b4.
