    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 11-02-2014, 04:49 PM   #8881
samnelso's Avatar
3 gear
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 11-02-2014, 06:42 PM   #8882
Trader Rating: 29 (100%+)
It definitely looks 3 gear. Is he an MIP affiliate?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 11-03-2014, 08:21 AM   #8883
This has probably been answered 150 times but what are the main differences between the hard and normal parts on the B5M?
clydeywidey is offline   Reply With Quote
Old 11-03-2014, 08:24 AM   #8884
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
hard = less flex and more brittle. Plastic is more durable and has more flex. The hard parts also weight more.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 11-03-2014, 08:27 AM   #8885
What would the hard parts do in theory to make the car handle differently?
Old 11-03-2014, 08:51 AM   #8886
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
More responsive, but less mechanical grip.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 11-03-2014, 09:57 AM   #8887
Mason's Avatar
Originally Posted by Cpt.America View Post
Switched to the inline setup for club racing today. So far I like it.
Brandon, did you scale the car before and after? If so how much % change Front/Rear
Also has anyone differentiated between mounting the esc behind the battery vs in front?
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is online now   Reply With Quote
Old 11-03-2014, 11:43 AM   #8888
Putting together a shopping cart list for a stock B5M and wanted to get some input. Anything you guys would add or change here?
Kit: Team Associated B5M Kit
ESC: Tekin RS GEN 2 SPEC Sensored Brushless ESC
Motor: SchuurSpeed Extreme SPEC V3 17.5T Brushless Motor
Radio: Futaba 3PL 2.4GHz FHSS Radio System w/R2004GF Receiver
Servo: Savox SC-1258TG Standard Digital "High Speed" Titanium Gear Servo
Battery: Team Orion 2S "Carbon Pro" 100C Li-Poly Shorty Pack Battery w/Tubes (7.4V/4500mAh)
Charger: EcoPower "Electron 65 AC" LiPo/LiFe/NiMH AC/DC Battery Charger (6S/5A/50W)
Extra Parts:
Robinson Racing "Aluminum Pro" 48P Pinion Gear (35T)
Lunsford "Punisher" Associated B5/B5M Titanium Turnbuckle Kit (6)
Schelle Racing Ceramic Gearbox Bearing Set B5M
Schelle Racing B5M Carbon Battery Strap
Avid Racing Triad Evo Slipper Clutch (Spur 69t)
Avid Racing Revolution Bearings (For the rest of the car
Avid Racing Wing Mount Buttons
millsj2 is offline   Reply With Quote
Old 11-03-2014, 11:47 AM   #8889
samnelso's Avatar
Extra Parts:
I'd try and find a charger rated for higher than 5A and 50W. Rating of minimum 10A at 8.4V is usually my requirement.
Old 11-03-2014, 11:53 AM   #8890
Extra Parts:
My personal preference, get a different radio. IMO the Mt4s is the best in class for the 200-299 range. The receiver is smaller as well, which is nice on todays cars. I would avoid the "Eco" chargers. Are you placing a big Amain order? I would step up to this charger myself.
http://www.amain.com/ProTek-R-C-Prod...8A-80W/p260579
Also, IMO the TLR alum pinions are better then the robinson. They just seem to wear better.
Old 11-03-2014, 11:56 AM   #8891
Ordering most of this through Amain other than the bearings. I'll take a look at the Mt4s, TLS pinion as well as the other charger.
Old 11-03-2014, 12:02 PM   #8892
ironzgti35's Avatar
Trader Rating: 20 (100%+)
can you run the avid wing buttons on this kit? I assume there is some modifications needed
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 11-03-2014, 12:05 PM   #8893
yeah, you have to mod it. IMO it is a must. Wings come in all different thicknesses, and screwing the wing on make sense to me. Also, my wings last longer and are more secure with the screw on wings. There are plenty of post on here about how to do it. Exotek makes alum wing mounts and some spy shots have been seen for a JC alum wing mount. I prefer the "give" of the modded plastic ones.
Old 11-03-2014, 12:05 PM   #8894
joeld2llio's Avatar
I won't argue the MT4 is nice but that radio is in a completely different class. The 3PL is barely over $100 and the Rx are under $40.
B6 - B6D - B64D - T5M - DEX410v5
joeld2llio is offline   Reply With Quote
Old 11-03-2014, 12:07 PM   #8895
That was my thoughts on that radio. Figured I could get a budget radio for now and upgrade later.
