    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 10-20-2014, 05:19 PM   #8611
Suspended
Originally Posted by ironzgti35 View Post
First time building a 10th and ball diff for that matter, just installed the rear and notice that the t nut is preventing the left arm from moving up. I compressed the spring a bit before building and ball diff feels smooth.
Do I need to just tighten the t nut more to get the movement and make the ball diff tighter?
Your diff doesnt look tight enough
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 10-20-2014, 05:25 PM   #8612
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
the t-nut could be in the wrong diff half also. it only properly fits in the correct diff half
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-20-2014, 05:37 PM   #8613
Vantard's Avatar
It's in the wrong half
Team faucet - hot and cold
Vantard is offline   Reply With Quote
Old 10-20-2014, 05:37 PM   #8614
ironzgti35's Avatar
Trader Rating: 20 (100%+)
I'll tighten the t nut up a little and see what it looks like. The manual says locked and back out 1/8th but I followed the vids from page 1 and it ended like the picture.
HB Racing Proline Sweep Racing USA - PT RC Racing Oils
ironzgti35 is offline   Reply With Quote
Old 10-20-2014, 05:43 PM   #8615
Vantard's Avatar
The white tab should be pretty much bottomed out in the channel. If it doesn't something is probably wrong so it's probably installed in the diff backwards, then the diff was installed backwards
Old 10-20-2014, 05:47 PM   #8616
ironzgti35's Avatar
It will tighten up all the way into the channel but the diff felt too tight so I backed it out.
Diff was installed with the head of the trust bolt on the passenger side
Old 10-20-2014, 05:50 PM   #8617
Vantard's Avatar
It may feel a little tight until you break it in or turn it by hand with tires on the wheels.
Old 10-20-2014, 06:03 PM   #8618
Vantard's Avatar
If you only compressed the spring "a bit" it was probably not enough. You want to do it all the way till the coils touch each other, spin it 180 and do it again.
Old 10-20-2014, 06:26 PM   #8619
Jason Baliban's Avatar
Originally Posted by Wildcat1971 View Post
Also, try going up in spring rates in the rear and/or softer in the front.
Are you finding any other oil wt helpful?
jB
High Sundry Productions
B5M | MBX-7Re | T5M | TC3 | RC10 "Graphite"
Jason Baliban is offline   Reply With Quote
Old 10-20-2014, 07:10 PM   #8620
I am running 1.6 f/r with 32.5/30 oils
Old 10-20-2014, 08:36 PM   #8621
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
same here
Jeepy2013 is offline   Reply With Quote
Old 10-20-2014, 08:37 PM   #8622
Trader Rating: 29 (100%+)
Thats pretty soft wildcat. What springs are you running?
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 10-20-2014, 08:53 PM   #8623
right now I am running white fronts and white rear. the track is not exactly smooth. when it is smoother I will go 35/32.5 with the 1.6's
Old 10-20-2014, 10:30 PM   #8624
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
That's not soft, with 1.6s a lot of people are running 30/27.5 with great success.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 10-20-2014, 11:10 PM   #8625
samnelso's Avatar
It's installed in the correct orientation. The t-nut should be pretty much bottomed out. Here's how I check for a proper diff setting. Others may have a different approach.
1. Compress spring with pliers, then assembly diff
2. tighten diff screw until nut pretty much bottoms out. I assembly the diff on the bench, but set it in the car.
3. install in car.
4. put tires on
5. take a tire in each hand and rotate them in opposite directions in a quick motion and let go simultaneously with both hands. I aim for about a 1/2 diff rotation after I let go.
6. adjust screw until you achieve this. Unscrewing the passenger inner camber link ball stud and keeping it on by just a few threads until the diff is set allows for a convenient way to access the diff screw.
7. set the rings by holding a tire and running the motor at about 10% throttle for 30sec. Then hold the other tire and repeat.
8. Diff will loosen up a bit, so tighten until about a 1/2 rotation spinning by hand is achieved
9. run on track a few minutes, check and tighten as needed.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
