    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree15Likes
Old 10-12-2014, 10:25 PM   #8401
SnotRkt's Avatar
Originally Posted by 3srcracing View Post
Does anyone agree that practicing with a mod motor and racing with a stock motor will make you a better racer?
I would think your best option would be to practice with the motor you are going to race.
AE RC10B6, TD DEST210R
SnotRkt is offline   Reply With Quote
Old 10-13-2014, 06:53 AM   #8402
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default I am going to say no...
I think you will find that your brake points and how hard you push through the turns in stock is a completely different driving style than how you drive a mod more point and shoot. You can't afford to scrub any speed in a stock vs mod you can brake pivot and jam the throttle off the corners...
Plus you most often leverage way less brake in stock due to the speeds the car is going into the corners. I think it would be good to practice mod to continue to gain more experience in general as it will sharpen you as a whole, but if I were running stock again.. I would be out practicing a lot with the setup I was planning on racing.
Good Luck!
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 10-13-2014, 08:24 AM   #8403
Originally Posted by mackelby View Post
Question, what difference does a tapered verses standard shock piston do as far as car handling?
Hope you don't mind me asking again.
mackelby is offline   Reply With Quote
Old 10-13-2014, 08:29 AM   #8404
Trader Rating: 14 (100%+)
I couldn't remember either so i googled it.
http://www.rctech.net/forum/attachme...tons-shock.jpg
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 10-13-2014, 08:29 AM   #8405
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
different rebound and compression. taper down should mean that the piston rebounds quicker than it compresses.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-13-2014, 08:34 AM   #8406
8ight-e's Avatar
Trader Rating: 58 (100%+)
I didn't get any good hits.. was there a find for a 14mm hex on the rear of this buggy, I was thinking of running a b5m but it's hard to part with my box full of durango dex210 wheels front and rear. Any thoughts on how to run them w/o the hassle of replacing or removing all my tires?
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 10-13-2014, 08:39 AM   #8407
Default Shock body caps
This may have already been answered, but I will ask again because I am too lazy to sift through 500 pages...
is there some kind of advantage to running the aluminum shock caps over the plastic ?
sbuck10 is offline   Reply With Quote
Old 10-13-2014, 08:42 AM   #8408
Yes. The most important reason in the world..They are pretty , The plastic caps IMO wear out quicker. But that is subjective. If you get the alum caps, do yourself a favor and ditch the button head screws and get some good cap head screws for the bleeder.
Old 10-13-2014, 09:20 AM   #8409
lol...Thats good enough for me ! thanks
Old 10-13-2014, 10:25 AM   #8410
skrichter's Avatar
Send a message via AIM to skrichter
Inline setup testing (from Upgrade RC facebook page)
Team Associated RC10 B5m Mid-Motor Thread-1492315_582936065144204_909397656580354269_o.jpg
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 10-13-2014, 10:55 AM   #8411
WHAT THE HELL!!! That is a losi electronics config
Old 10-13-2014, 12:03 PM   #8412
I changed over to the line setup yesterday. Due to wiring and time, I started with the speedo and receiver on each side of the battery and the battery pushed to the waterfall. Inline. It ran VERY smooth. I am not sure if the lap time changed much... But I felt much more consistent when driving the car. It felt much easier to drive. When the car did start to break loose, it seems to be much easier to control the rotation. I also feel that the car is able to stay more level when cornering.
After the races, I had a few minutes to move the battery forward and tuck the ESC into the waterfall. I did some laps... I feel like with this setup (battery inline and forward) I could drive the car a LOT harder. On power steering is great now. It feels that the harder I am on the throttle on the exits, the more it wants to grab traction.
I hate to say, the computer was turned off so I do not have any lap times with this setup.
One other thing to note, even tho my average lap time is faster with this setup, the motor came off the track almost 10* cooler from the last time I raced, air temp was higher as well. So the car seems to like this setup a lot.
I am a Sportsman stock drive that is about to move into Expert in our club racing. Track is med to high traction, indoor, clay. Running Electron 2.2 front and rear.
front shocks:
Kyosho Red springs, inside hole on the tower, outside on the arm. 3x1.4 30w, 24mm
Rear motor front arms and towers. I am running the grub screws in the hubs.
Rear shocks:
Kyosho Gold springs, inside hole on the tower and the Arms. 2x1.6 27.5w, 24mm. Rear Motor Arms, again with the grub screws in the hubs.
I have MIP pucks, alum top shaft, stock slipper, Reedy 17.5 motor, 72/32 gearing. Lunsford turn buckles. Everything else is out of the box.
I should be racing again on Wednesday night and have lap times to work with at that point. Lap times from my race yesterday was a best at 16.2 (fastest time of the class), I was TQ in sportsman and would have been 5th in expert based on my times.
I have to say, I was a bit worried about cutting up the plastic to make this setup, but I can not see myself going back now... I love the way the car is driving and I can not wait to see the lap times with moving the battery forward more. It feels great, jumps great, and overall feels like it is a lot easier to drive.
If anyone is questioning making the change, I have to say that it has worked great for me.
AlmostIllegal is offline   Reply With Quote
Old 10-13-2014, 12:07 PM   #8413
MikeXray's Avatar
Trader Rating: 73 (100%+)
My take on this is that, give anyone who can handle a mod car at competitive pace for an entire race a stock car and how do they do? I've never seen them be slow, but I've seen plenty of the opposite
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-13-2014, 12:30 PM   #8414
It messes me up. Trigger pull and timing are off. Plus for my track, the setups are different. We stiffen up the car for mod, because there is so much traction, that at high speeds you want less weight transfer opposed to running a softer car. But mostly, mod and stock timing is different. I have given my stock car to mod guys before and they always struggle with trigger pull and timing. And they are too used to instant power. I was running 4wd buggy and stock buggy and it just messed me up too much when the classes were back to bad. I ran mod buggy and 4wd buggy this week and it was a much better transition.
Old 10-13-2014, 01:07 PM   #8415
Default Initial Setup of buggy
Hi Everyone,
I am a newbie. I purchased a rolling B5M. I am slowly getting all the electronics for the buggy (just purchased Trinity D4 and JustStock ESC). I should have everything else in a few more weeks. I plan to race stock on a green carpet track (MMR), but most of my practice time will be on dirt (FTR 510).
That being said I am curious if there are any general guide lines for setting up the buggy for my first run at a track. I would like to maximize my practice time.
Should i just download a basic setup sheet and go from there? Or just follow the manuals setup for shocks, camber, etc.
And the most important question...are there any issues with going back and forth between the two different surfaces.
I am guessing I should bring everything to the track for practice to make adjustments.
Any help or advice would be great. Thanks!
dstidham is offline   Reply With Quote
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
Crazyybikerdude
