    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 10-07-2014, 09:04 AM   #8326
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by heinen81 View Post
Yeah, that's exactly the responses I have found as well, just never an actual explanation as to "why" the front would be more consistent (I would be interested in hearing the physics behind that theory) as well as moving the rear tires forward would help minimally (given that there are way more effective ways to balance for traction) and doesn't make sense due to the fact a slightly longer wheelbase helps the stability on the straights. If I could find drivers who could attest that it no doubt improved the drive-ability of the car, I would be willing to give it a shot, however it looks to me like some Factory drivers bolted the parts on, and instantly Associated sold thousands of sets of arms and front towers that they normally would not have sold. They intelligently found another market for those items.
It is a tuning option. I see guys running the gulwings and loving them. I didnt. I like a more forgiving and easy car to drive. I feel like the RM parts did that for the car.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 10-07-2014, 09:12 AM   #8327
TomErickson's Avatar
So I just completed my build and installed the RM front arms with the MM front tower and mounted the shocks to the inner most hole which looks to be the same as the center hole of the RM. I have RM rear arms coming to test as well.
---Thanks to my Sponsors: Novak R/C, and Nankin Hobbies ----
TomErickson is offline   Reply With Quote
Old 10-07-2014, 09:13 AM   #8328
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
The Factory AE guys at Tacoma (and myself) are now running the Carbon/Hard straight front arms, with the stock gullwing tower, and reducing the stroke of the front shocks to 18mm with an additional 2mm internal limiter.
We run on a VERY high bite indoor clay track and this setup made a pretty dramatic difference in how smooth and predictable the buggy steers in the high speed sections of the track. We ran the gold cup this weekend, and in the high speed sections of the track, as the traction came up, the stock setup cars were a little edgy and unpredictable. Moving to this setup in the middle of the 3 day race made a very noticeable difference in how the car drove for me. It feels like it may have removed steering a little bit from the high speed sections of the track, and added it to the lower speed sections of the track... it's a bit hard to tell exactly what is happening, but the car was certainly easier and more predictable, which allowed me to push the car a little harder.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-07-2014, 09:15 AM   #8329
skrib21's Avatar
Trader Rating: 14 (100%+)
I know this isn't necessary the correct place for this ,but will the B5 shock caps work on my t4.2. One of the bleeder screws is stuck in the aluminum cap and only way to get it out is to drill it which is nearly impossible.
Jon Berding
SC5M ,HW XR10 STOCK, REEDY M3 17.5 ,SAVOX 1258
B6 , HW XR10 STOCK , REEDY M3 17.5, SAVOX 1258
T5M , REEDY 510r, REEDY M3 17.5, SAVOX 1258
"Cheap, fast and reliable. Pick two."
skrib21 is offline   Reply With Quote
Old 10-07-2014, 09:21 AM   #8330
This is great information for me. What hole did they mount to on the tower? The inside, middle or outside.
Looks like I need to add some limiters to my shocks. It would be great to get a quick complete front shock set-up if you have it.
Thanks!
Old 10-07-2014, 01:39 PM   #8331
Jcozz's Avatar
Trader Rating: 20 (95%+)
Tried the Inline set up this weekend at Tacoma for the gold cup. Saw lots of people doing it so I had to. Car was much much better. A lot more consistent. Rotated really good and was really stable! We will see how it does at my local carpet track.
Jared Cozzocrea
HobbyPro PRS1 / HobbyPro SB401 / Fusion Graphics / Mayor RC
Premier RC Raceway and Hobbies
Dave's RC Tracks
Jcozz is offline   Reply With Quote
Old 10-07-2014, 02:57 PM   #8332
What are the shock limiters doing to the way the buggy handles?
mackelby is offline   Reply With Quote
Old 10-07-2014, 05:18 PM   #8333
Trader Rating: 29 (100%+)
When used inside the shock body it reduces roll obviously when cornering but when accelerating it adds rear traction when done correctly. Essentially changing the droop of the shock.
Less droop in the front will usually give more on power steering, more droop willincrease off power steering.
Less droop in the rear will increase stability in high speed turns and increasing it will add more off power steering and also reduce a little high speed stability.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 10-07-2014, 05:23 PM   #8334
TOO-TALL's Avatar
Can you post a pic ...thinking of doing this to my car.
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
Old 10-07-2014, 10:48 PM   #8335
Super Moderator
This is a tiny adjustment to the overall leverage the arm has against the shock. Just start in the middle.
Here is what I ran in 17.5 this last weekend at the gold cup
Front Shock:
Carbon Flat RM arms
Stock MM tower
Middle hole tower mount
Outer hole arm mount
White Spring
Stock Piston
37.5 Oil
4mm Shock limiters (this is because I am running the MM tower, which would create too much droop without the extra limiters. the stroke listed below is key)
18mm stroke
23.5mm ride height
Rear
Stock everything, tower/arms/piston with 32.5 oil
Inner hole arm mount
~26mm stroke (taken from Luke Smith's setup.. i don't recall mine off hand)
23mm ride height
- RCSpecialties -
Old 10-08-2014, 11:31 AM   #8336
can you explain shock droop and what it looks like. Sorry for newbie questions.
Old 10-08-2014, 11:42 AM   #8337
Hi everyone. Anyone have any insight or some information for running a shorty in the B5M? I know Wild Cherry had an inline setup, but I was wondering if anyone was running the more traditional way. (Sideways) Forward or back, etc. I have even seen some with the ESC between the battery and the motor. Let me know! Thanks.
BTW running outdoors in south Florida, clay track, medium to high bite.
JHKracing is offline   Reply With Quote
Old 10-08-2014, 12:06 PM   #8338
Super Moderator
"Shock Droop" isn't a very good term to use, and can be confusing. There are two related things/terms to understand:
1: Droop
2: Shock Stroke
1- "Droop" is the distance the chassis travels between static ride height, and the point where the wheels come off the ground. (chassis lift or chassis rise)
2- "Shock Stroke" is the length of the shock shaft showing when it is fully extended.
- RCSpecialties -
Old 10-08-2014, 12:10 PM   #8339
Super Moderator
Guys that are running an "inline" setup, are referring to the ESC, and shorty battery, being run down the middle of the car. Drivers will cut out the inner webbing of the rear waterfall AND the chassis pod, so they can literally tuck their ESC inside the waterfall almost up against the motor. Then the shorty battery sits directly in front of the ESC lengthwise.
If you are looking for slightly more rear-tire weight bias, you can run your setup like I do... which is the shorty run horizontally in the back up against the waterfall, and then the ESC dead center right up against the battery. This requires you cut away the section of the chassis pod in-between the battery posts.
If you want a little more weight forward, you can run the battery horizontal against the waterfall, and then run your esc and reciever forward of the battery posts. Or you can even run the battery slightly more forward.
Static weight bias balance is a great tuning aid.
- RCSpecialties -
Old 10-08-2014, 02:38 PM   #8340
Zaxbys's Avatar
The first page of this thread has several pics of an "inline setup" if you want to see different ways to accomplish it.
Zaxbys is offline   Reply With Quote
