    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 10-03-2014, 01:06 PM   #8266
lbckevin's Avatar
Trader Rating: 91 (99%+)
Originally Posted by ronzo View Post
will alu. top shaft and mip pucks bi-metal wear out too fast with 13.5?
it will be no problem.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-03-2014, 01:10 PM   #8267
so when i am done pumping the shaft(shouldn't that be what she said), do I want see the shaft stay in place or recede some. sounds like shaft needs to stay where i left it???
mackelby is offline   Reply With Quote
Old 10-03-2014, 01:29 PM   #8268
Jmuck69's Avatar
Trader Rating: 14 (100%+)
It will stay in place after your done pumping. Make sure you clean the excess silicone oil off your shaft after you're done since it will make handling the nuts more difficult. shock mounting nuts that is...
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-03-2014, 03:05 PM   #8269
Cridd's Avatar
Trader Rating: 16 (100%+)
I have only used ball diffs, but wanted to play with gear diff on some high bite tracks, what diff oil would give me the closest feeling of a ball diff?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 10-03-2014, 03:22 PM   #8270
Trader Rating: 90 (100%+)
Lots start with 3000... Seems to be pretty good.
dan-o is offline   Reply With Quote
Old 10-03-2014, 04:19 PM   #8271
Emaculant's Avatar
Quick question will JConcepts Rulux 1/10th wheel fit on the B5m? The site speak of B4 and B44. Just don't want to have to return them after ordering.
Emaculant is offline   Reply With Quote
Old 10-03-2014, 04:28 PM   #8272
Yes, if it is designed for the B4 hex the wheel will fit the same on a B5.
34x17 is offline   Reply With Quote
Old 10-03-2014, 05:13 PM   #8273
B4.2 yes. ..B4, no...need to verify. ..
nordfink is offline   Reply With Quote
Old 10-03-2014, 05:25 PM   #8274
Unless my memory fails me, the Rulux wheels are not hex compatible. They were before hex adapters were the norm.
flintTRDTC is offline   Reply With Quote
Old 10-03-2014, 05:31 PM   #8275
I think you're right. ..
Old 10-03-2014, 06:47 PM   #8276
That is correct... Rulux rears use the pin style mounting and the fronts have 9.8mm hex (4wd) or bearing in the wheel (2wd).
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 10-03-2014, 08:17 PM   #8277
Trader Rating: 29 (100%+)
thanks
ronzo is offline   Reply With Quote
Old 10-03-2014, 08:39 PM   #8278
Bracer11's Avatar
Default 17.5 blinky class gearing
What are you guys running for gearing in the 17.5 blinky class?
Bracer11 is offline   Reply With Quote
Old 10-03-2014, 08:54 PM   #8279
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
With a Trinity D4 Maxzilla, I was running 69/31. Just went up to a 32 pinion. My can timing is at 55 degrees.
Jeepy2013 is offline   Reply With Quote
Old 10-03-2014, 08:55 PM   #8280
Emaculant's Avatar
So they won't fit the B5M?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Scott R
