Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#8011
This is kinda crazy. I was able to drop another 22 grams off the car. I normally run for 5 minutes and my temps are 160-165. Today we were doing 7 minute heats and my motor only got up to 135 degrees. I was pretty shocked. I was able to turn the timing up 2 degrees on the motor and temps got up to 150. My car should be close to the 1500 mark i think this week with the lighter battery.......maybe dropping the weight helps
Thanks BillPear for all the help!!!
#8013
Tried hartson's OCRC setup on my home track. Its VERY tight and high traction clay. Best setup I've tried so far! It felt really good on the track and had a lot of steering. I'd definetly recommend trying it out!
#8014
is there some toe blocks in the kit and shims
#8016
Advise to call in each day around 1pm and keep checking..
Parts for the B5 are arriving almost everyday.
B5 parts wall is now 3 ft x 5 ft and growing.
#8018
Had an awesome weekend with the car. Got a hold of a few sets of b5 rear arms and the car was awesome. I think with flat fronts and the RM tower it would be even better. Hartsons car was amazing it appeared to be so easy to drive through the corners. If you are rolling the throttle on you shouldnt have any problems though. Awesome car and made for a fun a main
#8019
I've been having trouble with heat with my B5ms. I have a car for both stock and mod. I haven't seen a whole lot about that trouble in this thread but I did see where dropping weight has made it better especially in stock. My stock comes in at almost 1600 grams but I have it geared at 29/75 which is pretty conservative compared to others and with 30degrees of motor timing in blinky mode. So I don't quite get why it's getting hot. Is it the weight? I ran the same setup on my 4.2 and it used to come off just warm. I don't see how some guys are running gearing like 69/32 with 17.5 and not getting way too hot? I'm running on an indoor track that isn't big but it isn't tight. Even with my mod car I'm running a Reedy 7.5 with gearing at 21/81 and it will come off at 185 and that's with stock timing at 20 degrees. I just saw Maifields latest setup and he's running the Reedy 7.5 gearing at 23/81 with 0 degrees of timing. Does that mean he retarded the timing on the motor from the stock 20 to 0? Or is 0 in reference to the stock 20? If that makes any sense lol. Any tips are really appreciated. My 17.5 is also a Sonic Mach 2.
#8020
#8021
im 33/69 35deg timing and come off @ ~150, reedy 17.5, my times are comparable to ~mid pack bmain at ocrc, so im def not babying it
#8023
Hard part are slightly heavier
#8024
R/C Tech Elite Member
#8025
WC runs on tiny tracks with super high bite. If that is not what your track is like disregard his advice 90% of the time. He says this stuff to get a reaction out of some. Its all fun and games but don't get sucked in. He has opinins.....but we all have options.
