Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#7951
hey rigor and bill... I looked and I was measuring off my already modded b5m rear arms.. I had sanded the front and used a spacer washer behind to take up slack which moved the arm farther forward anyway... so I measured against a new arm and the b5 is .5mm farther forward then the b5m.. but still had the slack.. so I sanded the front of the b5 arm to try and move the arm as far forward as I could and used a spacer washer on it inback of arm...and it does move the arm about .75mm farther forward.. it almost touches the back of the chassis that way. just drove it a pack and it does have better rear bite.
dang need to keep modded parts separate from new stuff..lol
#7953
#7955
spacer used was a 1mm spacer from:
http://www.amain.com/product_info.ph...ter-Set-TLR-22
got from a local tlr racer just had to ream the hole slightly and it went right on.
i noticed an increase in rear bite from when it was free floating, and when i spaced the arm forward.
#7957
finally got to run my rm car last night,first impression on the car was "what push" I'm running the thienke setup and this car has steering for days,shorty forward and no weight up front,i was running brand new m3 ions also.My rear was actually a little loose,granted track was cold and traction wasn't the best but my rear was a little loose for my liking,but running two classes with only 7 races i didn't have anytime to change the setup,overall with only 5 packs on the car it should be really good
#7958
yes tried stock setup.. didn't like the push.. I went with the aggressive setup with the 30 deg. block... oh and move front shocks to outside hole on tower.
#7963
For those guys running the 155 grams shorty packs. What location are you running the pack?
