    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 09-14-2014, 06:54 PM   #7921
luist99's Avatar
Send a message via MSN to luist99
Hey guys I'm looking for more steering coming in to the Conners I'm running 1.4- 1.6 piston 30F 27/1/2 shock weight, dirt webs all around. Front and rear rear motor b5 arms. Does any one have any pointers?
luist99 is offline   Reply With Quote
Old 09-14-2014, 06:59 PM   #7922
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Go back to the gullwing and mid motor rear arms...
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 09-14-2014, 08:06 PM   #7923
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
So went back to mm on an outdoor track again... Had bad luck and gave up too quick last time!!! Had great results today... Moved rear hubs all the way forward and used b5r arms front and back. This thing stuck all the way around the track like glue... Problem im having is the two middle doubles i cant get enough speed and have to hit it just right to clear them. Running 72-33 but not enough speed. Running that same gearing in my rear motor i could clear the doubles with ease!! Any suggestions?? A friend suggested going down on the spur to 69 and pinion to 34ish. If i went down on spur wouldnt i lose more top end yet?? I know the mm is alot heavier but it seems like a dog compared the the rm!!! Im torn between the two!! Any suggested on the 69/72 spurs?? Thanks guys and hope i can figure this out... By the way running reedy 17.5 blinky mode gen2 esc... Large outdoor 1/8 scale size track with multiple doubles and a triple.
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 09-14-2014, 08:16 PM   #7924
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by Skeeter36 View Post
Yes thats what most all use. There is one location that you need to use a 6mm and that is the forward inside location. If you use a BS that is too long it will damage the bearing sleeve and bearing.
cool thanks. I have to snag some 8mm ones. gonna have to look and see if I can steal some off my RM car until I get them in. That poor car just keeps getting molested for parts haha. I have everything I need to actually put it back together too... just not the time.
Guess that's next week's project lol.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 09-14-2014, 08:21 PM   #7925
suby723's Avatar
Trader Rating: 21 (100%+)
On our large outdoor track I went to 69/38 20timing. Give it a try, you will have a lot more topspeed.
suby723 is offline   Reply With Quote
Old 09-14-2014, 08:28 PM   #7926
Originally Posted by suby723 View Post
On our large outdoor track I went to 78/38 20timing. Give it a try, you will have a lot more topspeed.
Wow you could fit that big of a spur with that size pinion?
B5 NATION BABY!!
Old 09-14-2014, 08:46 PM   #7927
suby723's Avatar
Crap ment 69*****
Old 09-14-2014, 09:18 PM   #7928
Crap ment 69*****
Cool... Ya i was wondering...
B5 NATION BABY!!
Old 09-14-2014, 09:44 PM   #7929
Trader Rating: 29 (100%+)
If you have the gold colored offset caster block bushings you could try raising the front spindle height that should give you some more steering without changing arms and tower. Also where are your rear hubs located because that can effect the steering as well.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 09-14-2014, 09:58 PM   #7930
luist99's Avatar
Do I have to have the gold spacer can't I use the plastic to raise it? I have them in the middle. Also I'm still running the plastics rear hubs, I'm thinking of getting the aluminum ones but not sure if the would improve anything.
Old 09-15-2014, 07:30 AM   #7931
NoNothing's Avatar
I seem to have a lot of play in my rear and front hubs. It's been this way since I first built it.
Anyone have any advice on tightening it up?
+ YouTube Video
NoNothing is offline   Reply With Quote
Old 09-15-2014, 07:37 AM   #7932
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
Your always going to have some "play" in a offroad car, if it was tight, it would all bind up once dirt gets into everything.
You could use shims to tighten some of your car up a little more ( like the rear shafts moving in and out), just be careful not to make things too tight or you will most certainly have binding issues.
Jeepy2013 is offline   Reply With Quote
Old 09-15-2014, 07:42 AM   #7933
NoNothing's Avatar
Sweet, thank you.
I sort of thought it was normal given it built that way. Just seemed like a bit too much play.
Old 09-15-2014, 07:45 AM   #7934
Jeepy2013's Avatar
Originally Posted by NoNothing View Post
Sweet, thank you.
There definitley is a point of "too much" play, it all depends on how much use is on the car. At that point I would look at replacing arms, pins, pin holers as needed.
Old 09-15-2014, 07:50 AM   #7935
Super Moderator
slop = grip
