    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 09-10-2014, 01:07 PM   #7831
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Originally Posted by DWill View Post
Did WC get a vacation !
Yes, a one month vacation.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 09-10-2014, 01:25 PM   #7832
shannow's Avatar
Originally Posted by Wildcat1971 View Post
Nice......man that is huge....that is what she said, lol. 85g, wowsers. A square pack was no good?
Thanks ,
Don't have them and my saddles, I think, died yesterday. Fully charged they only lasted 5-10laps before dying and when I checked they were both at 8.2-8.3v after (I don't know what's wrong).
The saddles as far as I could try were very nice (100gr more than the shorty) I tried tonight the 85g weight and gave me a similar improvement but I might try a 140g version tomorrow and see what it does .
shannow is offline   Reply With Quote
Old 09-10-2014, 02:26 PM   #7833
The grub screw pressed against the insert. Because everything is already tight when new, it seems to bind it up often. When the car is new, you dont really need the screws. I would install them, but not tighten them up. then tighten as needed as it break in.
will do, thanks
gearit is offline   Reply With Quote
Old 09-10-2014, 02:27 PM   #7834
So what's the advantages of the aluminum shock cap? People say it's stronger? In what way? Or does that really matter? I haven't had any issues with my stock plastic ones.
If there are other reasons they are benificial I will concider the switch. I'm just not quite convinced there's enough benefit to justify the cost. Would love to hear some of your guys opinions on them tho.
Justinb86 is offline   Reply With Quote
Old 09-10-2014, 02:29 PM   #7835
Jmuck69's Avatar
I have noticed some slop develop between the FT bushings/mount and the plastic cap.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 09-10-2014, 02:32 PM   #7836
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
When I had the yokomo there was really no benefit with aluminum vs plastic. Im sure with the associated its the same. There is a benefit, plastic to plastic friction is higher than aluminum to plastic. BUT if you dont over tighten the nuts and squeeze the bushing you prevent this. The only other benefit is the bleed hole will be less likely to strip with the aluminum.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 09-10-2014, 02:35 PM   #7837
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
My plastic caps got super sloppy after a short time. I thought the bushing might have worn out, but I kept the bushing and replaces the plastic caps with alum. And it was instantly way way better. Slop gone. Now 4 months later, starting to get a little slop with the alum caps. This time I probably need to replace the plastic bushings. I am looking at getting the AVID shock bushings this go around.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-10-2014, 03:13 PM   #7838
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Aluminum on aluminum will just wear eachother out that much faster. Take whatever part is more expensive, and run aluminum. Take whatever part is cheaper, and keep it plastic. The cheaper plastic piece will take all the wear, and you simply replace that when you develop the slop. Your more expensive aluminum piece won't wear at all.
I assume the shock bushing would be cheaper, and the shock cap would be more expensive. So get alu shock caps, but keep the bushings plastic.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-10-2014, 03:16 PM   #7839
Super Moderator
Originally Posted by shannow View Post
Here's a 85g brass weight I made to improve my B5m on super slippery tracks (polished floor) hoping it can give ideas to people.
Why not just run a battery that weighs 85 grams more? You are already running a battery designed to be lighter than a full sized battery. typical shorty = ~200 grams, typical full size = ~300 grams.
You might as well gain the MAH/voltage advantage of a higher capacity battery to achieve your weight, considering it is in roughly the same location.
- RCSpecialties -
Old 09-10-2014, 04:08 PM   #7840
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
OK, to get the FDR where it is recommended with this Trinity D4 17.5 Maxzilla I need to run a 32t - 33t pinion with a 72 spur. I only have 1 pinion that large (a 31t) and it's a RR steal gear. I was thinking this is alot of rotating mass to get going......Are you guys running aluminum pinions or steal?
Jeepy2013 is offline   Reply With Quote
Old 09-10-2014, 04:29 PM   #7841
I use the TLR alum pinions. light and great wear
Old 09-10-2014, 04:31 PM   #7842
STLNLST's Avatar
Trader Rating: 21 (100%+)
We have done the back to back testing with a square pack vs shorty with weight. While the added mah gave me the same power at the end of a race as it did in the beginning the problems came with tuning. The square park was stuck and planted the car which gave it a push that was going to require a setup change. The shorty with weight still allowed us to move weight forward or backwards in the car which affected handling. I will revisit the square pack again a little later down the road. In 17.5 I feel this will be great to have. Mod guys love the square pack!!!!
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 09-10-2014, 04:43 PM   #7843
I did some testing with saddle and shorty outside on a slick to med at best track and the saddle seem to let the car keep rotating where as the shorty let it corner a little better and when I would drift it I could catch it faster with the shorty and I do run mod
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 09-10-2014, 04:55 PM   #7844
eper's Avatar
Trader Rating: 14 (100%+)
Is the forum to help out guys with questions or show off bling and rip on each other?
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 09-10-2014, 05:05 PM   #7845
No one is ripping on anyone. They were discussing brass weight vs mab weight
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
