    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 09-03-2014, 05:55 PM   #7696
Speed Freak RC's Avatar
I am running Avid ceramic balls with a ceramic captured thrust on carpet without any issues or barking.
Speed Freak RC is offline   Reply With Quote
Old 09-03-2014, 06:07 PM   #7697
CaseyAnthonyFan's Avatar
The C alumn mount. Do you use a locknut to keep them down like the stock one?
CaseyAnthonyFan is offline   Reply With Quote
Old 09-03-2014, 06:23 PM   #7698
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
No. Small dab of loctite
pink_sleeve is offline   Reply With Quote
Old 09-03-2014, 06:45 PM   #7699
THankyou Sirs
Old 09-03-2014, 08:11 PM   #7700
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I never had issues with the ceramics in 17.5 buggy. Most of the issues I have experienced are in mod SC. heavier vehicles with strong motors. All ceramics can work fine, but it can be easier for new people to set the diffs with carbides.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 09-03-2014, 08:54 PM   #7701
First race was tonight!
Stock buggy - qualified 8/10 - Finished the main in 8th as well.
Could have qualified as high as fourth if I only shaved 10 seconds off my run but multiple multiple crashes prevented that. But at least its attainable!!
The guy running the show knew I was a newbie and had me run the novice main right after the stock main. I won! nothing to be super pompous about seeing as it was a much lower class, but it was fun. Now to just work on smooth mistake free laps and actually tuning the car and seeing how it affects my times.
Everyone was super nice and helpful, what a great community.
hcopp is offline   Reply With Quote
Old 09-03-2014, 09:33 PM   #7702
hcopp..... good job.. and that's what its all about .. meeting new people and having fun driving your car. :-)
rickster is offline   Reply With Quote
Old 09-04-2014, 02:47 PM   #7703
Something new from AVID. I have some coming. I will compare and report back
http://www.avidrc.com/product/5/acce...cessories.html
Old 09-04-2014, 02:57 PM   #7704
how long of a stud are you guys using on the alum hubs? With lets say +3mm washers?
Old 09-04-2014, 06:10 PM   #7705
Trader Rating: 29 (100%+)
Depends on which ball stud location you plan to use... you should be fine with an 8mm in all holes except 1 according to AE. In that one hole you have to use a 6mm otherwise it can damage the bearing. I'm not sure what hole it is as far as front to back but I know its the ones furthest towards the inside of the car.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 09-05-2014, 06:32 AM   #7706
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
Finally received my kit and started working on it last night. I'm waiting for a few parts I ordered for it, FT Aluminum front pin brace, FT Aluminum rear ball stud mount, Lundsford Titanium turnbuckles.
For now I will be running the HW Justock I picked up along with a Trinity D4 17.5 Maxzilla.
Hoping to get the car all done, get some practice in and hit my first race with the new car on Sat the 13th.
Jeepy2013 is offline   Reply With Quote
Old 09-05-2014, 07:17 AM   #7707
Jmuck69's Avatar
It's all location on the aluminum hubs. If you run the -2mm position (C tower) on the hub, then you will need the 4mm ballstud.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 09-05-2014, 07:33 AM   #7708
Im not sure that would work if he is using 3mm of spacers. He would only have 1mm of threads and it would snap on the first hard tumble. I understand what your saying but 6mm is a safer bet with 3mm of spacers.
Old 09-05-2014, 08:35 AM   #7709
3srcracing's Avatar
Trader Rating: 25 (100%+)
I just tried the hub insert upside down with the alunimum rear u brace +2 with another 2mm of spacers and its pretty dialed!
3srcracing is offline   Reply With Quote
Old 09-05-2014, 11:14 AM   #7710
MODELTECH22's Avatar
Trader Rating: 20 (100%+)
What associated standerd piston is the closest to a 3 hole 1.4??
22 3.0 Hobbywing
22 2.0 W/exotek chassis TEKIN
22T 2.0 Lrp Flow
SCT 22 2.0 Hobbywing
MODELTECH22 is offline   Reply With Quote
