    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-30-2014, 08:15 AM   #7591
shannow's Avatar
From my experience if the car behaves it good out of the box I have found that putting a pro setup on it makes it worse because it follows their driving style (of even carpet condition) rather than mine. If I were you I'd make little changes only and only the ones that definitely improves one at a time. If it seems the same go back to original. Usually out of the box setup is balanced.
Jonathan
shannow is offline   Reply With Quote
Old 08-30-2014, 09:57 AM   #7592
Nemaris's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Bracer11 View Post
Anyone got any recommendations for running on carpet? The car was pretty decent out of the box. Running a speed passion reventon R and 13.5 SP motor.
For carpet make sure it is SLAMMED to the ground, really low like 17mm. That alone should really help. Also if you have the gear diff they tend to work better on carpet, although I have not tried the gear diff in this car.
Nemaris is offline   Reply With Quote
Old 08-30-2014, 11:25 AM   #7593
Originally Posted by 3srcracing View Post
So what does the 4mm trailing axle do over the 3?
I'm currently running 3 forward, if I put the 4 in what can I expect?
3mm will give more entry steering. the manual explains the effects and what ackerman and wb changes are reccomended with the changes.
best advice is take a practice day at your most visited track amd spend the day changing settings so you can see what effects you get with each change.
robbie_gtc is offline   Reply With Quote
Old 08-30-2014, 12:28 PM   #7594
Suspended
This is great advice. The only problem is most people are too lazy to take the time to do this and just want somebody who's taken the time to learn what the changes do to just hand over setups
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 08-30-2014, 06:42 PM   #7595
Super Moderator
Trader Rating: 17 (100%+)
got to run my car for the first time in a long time. I was on an outdoor track that they used sugar water on. I ended up having to go to flat arms / tower to tame the front end down. It was crazy how much of a difference that made, so anyone who feels they have too much or too reactive steering, definitely take these guys advice on the rear motor front arms / tower.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-30-2014, 07:14 PM   #7596
deftones.jt@gma's Avatar
Trader Rating: 26 (100%+)
Could not get a grasp on the MM stock and mod today so switched back to RM... Tried all kinds of setups in practice but the RM is just alot faster outdoors... I have two conversion kits for cheap!!! (Rm to MM)
STOCK FT RC10B5M Trinity D4 17.5 Hobbywing v3.1
MOD FT RC10B5M Trinity D3.5 8.5 Hobbywing v3.1
B5 NATION BABY!!
deftones.jt@gma is offline   Reply With Quote
Old 08-30-2014, 08:55 PM   #7597
Jason Baliban's Avatar
Ball Cup-Gate
+ YouTube Video
jB
High Sundry Productions
B5M | MBX-7Re | T5M | TC3 | RC10 "Graphite"
Jason Baliban is offline   Reply With Quote
Old 08-30-2014, 09:12 PM   #7598
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Jason Baliban View Post
Ball Cup-Gate
+ YouTube Video
jB
Definitely should be on the first page. Nice video.
RCBuddha is offline   Reply With Quote
Old 08-30-2014, 10:24 PM   #7599
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Had someone ask what the fan mount made by my friend looks like with the body on. This is with a JConcepts Silencer.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 08-31-2014, 12:19 AM   #7600
xrayracer1's Avatar
Ball Cup-Gate
+ YouTube Video
jB
Great video. I might also give this a go. I found success polishing the hell out of the ball cup with the dremel, but this seems like a better solution to the problem.
Gavin.
Converting nitro to electric is utter blasphemy.
xrayracer1 is offline   Reply With Quote
Old 08-31-2014, 02:23 AM   #7601
How about polishing the ball while it's inside the cup(rod end).
akaalkhater is offline   Reply With Quote
Old 08-31-2014, 03:10 AM   #7602
xrayracer1's Avatar
That's what I did. I took the ball stud out, put some graphite grease on it, put it back in and with a hex tool in the dremel I then polished the inside of it.
Gavin.
Old 08-31-2014, 07:10 AM   #7603
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
I agree, great video
Jeepy2013 is offline   Reply With Quote
Old 08-31-2014, 07:37 AM   #7604
Trader Rating: 14 (100%+)
Finally got to run my MM last night for the first time with something other than a 17.5 in it. I had gone through and redone everything so it was much closer to some of the team setups thinking I was going to be looking for rear bite. Car felt really good other than a slight push until i broke the front shock tower. By the way i will agree the Hard parts are much mrs fragile. The hit that broke it wasn't much. Anyway i am running the flat arms and still had the GW front tower in my box so i figured id try it. Middle hole on the flat was pretty close to the inside on the GW tower. The only other thing i did was adjust the ride height. Car felt a little better to me. Mind you i haven't driven the car much in the past 6 months and i am by no mean one of the fast guys but i could feel a slight positive difference.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 08-31-2014, 08:11 AM   #7605
Trader Rating: 138 (100%+)
I miss Wild Cherry. J/K.
Ran my car mod with square pack using what is posted as Cavs setup for Reedy Race and the car felt really good and was super fast. Drove a mod 22 2.0 with same motor and felt sluggish, had a short pack in it. Did not weight both cars, but felt similar in weight.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
