    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-28-2014, 12:36 PM   #721
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
the 4wd tires are wider. width might be an issue for roar with he tires on the car
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-28-2014, 12:58 PM   #722
Mason's Avatar
That's because those rules changed some time back. There are some minimum measurements for some items (but not wheel/tire widths) and obviously all dimensions have a maximum. Thereby if it fits the rules you can run it. There is no rule regarding 4wd fronts on 2wd or heck, rears on fronts, anymore. (if your local track or event makes a stipulation then so be it as they are free to do so!)
Fronts have been narrower for a few reasons. One being drawn from the real buggies when originally copied. The wedging caused by the amounts of caster we run is also less than a wide wheel. Also if you have driven something with fronts nearly as wide as rears, the steering seems like a detriment as the backend is chasing the front or the car is screwing itself into the ground.
With the static weight moving forward i'm sure there will be some developments with the front wheels.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-28-2014, 01:57 PM   #723
bilster44's Avatar
A two wheel buggy with four wheel front tires on it probably will not fit the width of the tech box at a Roar/Ifmar race, that everyone must use when going through tech inspection. Their just too wide.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 01-28-2014, 02:08 PM   #724
Wouldn't the width stay the same if you are using 0 offset wheels? The end of the axle would still be the widest part of the front end.
I'm not an expert, just a truggy enthusiast
kawi650 is offline   Reply With Quote
Old 01-28-2014, 02:11 PM   #725
Davidka's Avatar
Trader Rating: 75 (100%+)
The sidewall could overhang more on a narrower rim than the 4wd tires were designed for . The 22 rims are pretty wide, more so than the AE's and Losi's previous types.
Old 01-28-2014, 02:20 PM   #726
I was thinking if the tires were on appropriate sized rims, not the narrower 2wd front rims. I could see the sidewall overhang being a problem.
Didn't Proline make wide front 2wd tires and wheels that were nearly the size of 4wd fronts in the late-90s? Anyone remember those?
Old 01-28-2014, 02:24 PM   #727
Davidka's Avatar
I remember those, Losi did the same. They were really closer to the 2wd fronts we run now. Front tires were typically MUCH narrower in the early 90's.
Old 01-28-2014, 03:59 PM   #728
I am really hoping that the AE MM car does not require the amount of weight added to it that others do. Its kinda lame to buy a kit and then stick $100 into brass to make the car not suck. Plus it sucks to have all of that weight in 17.5. Also, drivers like spencer rivken ran rm for 17.5 on the same track he ran mm for mod recently at a larger race. Since he has both cars and is sponsored, he could run mm in both, but didnt. Maybe because the centro is kinda heavy for 17.5?
Old 01-28-2014, 04:10 PM   #729
I think the saddle pack will take care of that. A shorty will almost certainly require more weight if it's on anything but high grip.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-28-2014, 05:16 PM   #730
That is what I am hoping for. If the saddles are all I need for outdoor racing.
Old 01-28-2014, 05:39 PM   #731
Davidka's Avatar
Weight is a band-aid for setup. Remember when guys would put 6oz under their lipo batteries? Dakotah Phend just posted that he only runs 7gm in his 22 MM, a car with a reputation for needing a lot of weight.
If lots of weight must be added then either the setup hasn't been worked out (which can understandably take a while) or the car has adjustment limitations (Link locations, available spring rates, etc) to reach the right setup.
Old 01-28-2014, 07:45 PM   #732
BillPear's Avatar
Send a message via Yahoo to BillPear
Originally Posted by CaseyD View Post
Is it legal to run 4wd wheels on a 2wd buggy? How would that work at a race like the Reedy? Mix your barcodes with the ions?
The Reedy Race as do all major events require control tires. For the Reedy they were gold Barcodes front and Silver rear for 2wd, and Ions all around for 4wd.
If you feel like you need to run 4wd fronts on you 2wd buggy just run stadium truck and get out of my way
BillPear is offline   Reply With Quote
Old 01-28-2014, 07:59 PM   #733
Cridd's Avatar
Trader Rating: 16 (100%+)
I think shorty in 17.5 is better than saddles. With engine being tame and not not pushing the cars limits gives it time to settle. With mod motor, feels like you would need weight to have it settle quickly and push harder, brake, etc. but 17. a shorty feels best in MM to me. Our club only races 17.5 and 13.5 so no big motors.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 01-29-2014, 08:23 AM   #734
Bcholka's Avatar
+1
And this has been beaten to death on many a thread--but I think the majority of experienced stock buggy drivers will recommend running shorty packs. I've experimented lots with both and I keep ending up with running shorty's.
Also-I agree that having to add any substantial amount of weight is definitely a bandaid for improper setup, wrong tires, etc.
2-Tekno EB48.2's, 1-Tekno ET48, 1-Tekno NB48, 1-Tekno NT48, 1-Tekno SCT-410, 1-AE B5, 1-AE B5M, 1-Kyosho RT6, 1-Kyosho MP9e TKi, 1-TLR Losi Mini 8ight
Our Awesome Sponsors: Tekno RC, AKA Tires, Dialed Designs Airbrushing
Special Thanks to: Trackside Raceway, Clark R/C Park & RC Scoring Pro
Bcholka is offline   Reply With Quote
Old 01-29-2014, 08:28 AM   #735
Davidka's Avatar
Originally Posted by Bcholka View Post
+1
Another component to this is adjusting the motor. If a car drops a significant amount of weight due to lipo from NiMh or the change to short packs then the ideal amount of power changes with it. I used to run as much as a 6.5 in 2wd before lipo came in, then 7.5, 8.5, now I run a 10.5 and I can't really use any more power then that effectively.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
