    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-25-2014, 10:36 AM   #7306
mxnickj's Avatar
Trader Rating: 51 (100%+)
Originally Posted by Wild Cherry View Post
Which holes are you referring to on the wing ?
We mount the wing a bit more forward then the stock location for extra grip.
Use just one or two bars ..
Place the wing pad on top of wing for more strength.
Pardon the newbie question but what is the real purpose of that wing pad? Do you put a hole in the wing and run a screw into that piece to hold it on the wing? I'm sure its something really simple that I'm just overlooking
mxnickj is offline   Reply With Quote
Old 08-25-2014, 10:39 AM   #7307
RussF's Avatar
Trader Rating: 21 (100%+)
My limited newbie understanding was that it was installed under the wing and provided a place to mount a screw in it to force the wing up in the rear.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 08-25-2014, 11:11 AM   #7308
Jmuck69's Avatar
Its an angled wing shim to adjust the wing. no shim...3 degrees, with shim...6 degrees and reverse shim...0 degrees. if you use the 3 degree (no shim) then you run the shim on top of the wing.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 08-25-2014, 11:14 AM   #7309
Speed Freak RC's Avatar
It's tapered, you can use it to increase the wing angle by placing it under the wing on the wing mounts. Nothing more than that. If you want you can put a hole in the wing and use a screw to attach it to the bottom of the wing so that it doesn't get lost when removing the wing.
Speed Freak RC is offline   Reply With Quote
Old 08-25-2014, 11:15 AM   #7310
Jmuck69's Avatar
The screw is to give the wing a third point of attachment so the wing doesn't move around on the mount. makes it more solid.
B6D | B64D
Old 08-25-2014, 11:16 AM   #7311
RussF's Avatar
Ahhh!! Thanks guys, that make way more sense. I didnt notice it was not flat.
So what mounting position for the stock wing is best to start with? Forward or Rearward?
Old 08-25-2014, 11:21 AM   #7312
Mizchief's Avatar
I put an Al button head screw in mine, didn't think about the angle, could be where some of the high-speed push is coming from in my car.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 08-25-2014, 11:21 AM   #7313
Jmuck69's Avatar
6 degrees so run forward (screw hole towards the back). This is the baseline setup. To me, trimming the wing lip is more effective.
B6D | B64D
Old 08-25-2014, 11:33 AM   #7314
Trader Rating: 486 (100%+)
I added a gear diff to my 13.5 car over the weekend. I'm also running a slipper eliminator. It is very smooth and predictable. Since we run sugared bluegroove there is enough traction for the eliminator, even with a 13.5. The car was smooth as butter with 5k in the diff. I would do the same thing for my 17.5 car(s) if they made pucks for gear diffs like they do for the Kyosho cars. Bottom line is that the gear diff was worth at least a tenth or two in my average lap time, meaning that it did not make my fastest laps faster, rather, it made my lap times more consistent and helped me make less mistakes.
I have to say, working on the B5M is much easier than working on the RB6M. I think that in this case the way AE designed a specific MM design is very apparent. I was able to get the diff swapped in a few minutes. There are a few things that really stand out, small things, like the fact that the tranny uses 4 screws that are all the same.
I'll also add that AE's parts quality has really improved. I definitely can't complain about any of my B5s wearing parts fast. I've done a lot of racing and practice lately and the outdrives on my non-pucks cars are all still near perfect after a couple months.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 08-25-2014, 11:42 AM   #7315
Tech Legend
Wild Cherry's Avatar
Never seen someone go faster on clay with a gear diff till now.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-25-2014, 02:19 PM   #7316
racer_guy's Avatar
here's my baby finished at last
Team Associated RC10 B5m Mid-Motor Thread-img_0125.jpg   Team Associated RC10 B5m Mid-Motor Thread-img_0126.jpg   Team Associated RC10 B5m Mid-Motor Thread-img_0127.jpg
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 08-25-2014, 02:21 PM   #7317
Jason Baliban's Avatar
My kit should be arriving in a few days thanks to all of your input. Thank you very much for that.
I have a question about build/progress/journal posts. Should i do that in this thread or start a new journal thread? I feel like i should start a new thread but i just wanted to check on the "culture" of this forum.
Thanks again!
jB
High Sundry Productions
B5M | MBX-7Re | T5M | TC3 | RC10 "Graphite"
Jason Baliban is offline   Reply With Quote
Old 08-25-2014, 02:22 PM   #7318
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Thanks again!
jB
Do not do that in this thread.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 08-25-2014, 02:26 PM   #7319
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Aluminum vs Plastic shock caps. Please discuss. I see that most everyone including the pros use the plastic caps. I found the plastic caps got play in them rather fast and my alum caps have stayed slop free for months.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 08-25-2014, 02:41 PM   #7320
Tech Legend
[QUOTE=Jason Baliban;13491077]My kit should be arriving in a few days thanks to all of your input. Thank you very much for that.
Thanks again!
jB[/
Welcoming you to join and share your build ...
George W. Cherry
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Nspenc6
