    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-18-2014, 12:41 PM   #7051
Konich's Avatar
Well raced my 13.5 in modified to see what I could do. Started 4th and finished 4th.
Anyone know that Dustin Evans guy? He's fast
https://www.youtube.com/watch?v=ZpcN...dLpALT3G_WEgOA
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 08-18-2014, 01:53 PM   #7052
ryan432greening's Avatar
Gentlemen/ladies, I need some help.
I am new to the racing side of RC. I recently went to my local outdoor track to break in my B5M. I have everything set to factory settings and am using a tekin rs gen2 10.5 turn with tekin gen2 esc. I'm using gold dirt webs. The track was a tad dusty, but not terrible. It looked like a 4wd kind of day but the car was absolutely awful. Constantly spinning the tires and while spinning the car always pulled to one side or the other. Is that a slipper adjustment that needs to be made? Diff adjustment? Should I run softer springs than stock? I'm just lost. I'm sure the car will be fun indoors this winter but I'd like to enjoy it before then.
I also had my SC10 out and while it was tough to drive as well, it had alot more traction than the buggy. I know I'm a terrible driver right now, but I know someone can help me make it a little better.
Help a newbie out, please? I'd really appreciate it. Everything I read from you guys is more centered towards front end handling, doesn't seem like many of you are struggling with rear end traction.
Thanks guys/gals!
B-Main Racing
TLR 22 4.0, TLR 22 3.0, 22-4 2.0, 8ight-E 4.0
ryan432greening is offline   Reply With Quote
Old 08-18-2014, 04:16 PM   #7053
TOO-TALL's Avatar
Originally Posted by Wild Cherry View Post
Using 2.7 oz extra weight under the short pack,not just for traction.
Also for a lower CG which helps smooth out the car on higher traction conditions.
2.7 oz thats alot of weight.....a new bottle of shock oil is 2 oz....my track has alot of traction so I might give it a try.
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
Old 08-18-2014, 04:45 PM   #7054
thecman26's Avatar
Trader Rating: 99 (100%+)
Yeah that Dustin Evans guys is pretty fast...
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 08-18-2014, 06:23 PM   #7055
Wrong thread, oops. This is mid-motor!
Buggy Buddy is offline   Reply With Quote
Old 08-18-2014, 06:40 PM   #7056
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
hah
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 08-18-2014, 07:14 PM   #7057
Tech Legend
Wild Cherry's Avatar
a saddle weights 2 oz more then a short pack.
Not so much weight really .
The point is its all slamed way low improving the CG for smoother handling on high traction.
On loose track the weight helps improve grip
Works, just try ...
Can trim a little and use less weight , don't recommend it however.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-18-2014, 07:30 PM   #7058
Trader Rating: 29 (100%+)
shock oil is a measure of volume, not physical weight. I understand what you mean but its 2 different measurements. 2.7 oz is only roughly 76 gr. its still alot if your running stock and trying to keep that baby on a diet.
Skeeter36 is offline   Reply With Quote
Old 08-18-2014, 10:00 PM   #7059
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I got my Protek Ti screws. I have not tried every brand screw, nor the lunsfords, but the protek ones were heads and shoulders above the tlr 22 screw kits tlr had. They have a more silver finish too. I replace the steel screws, so all of my holes were pre tapped. The only thing is.... they included all of the under the chassis screws and screws for the shock standoffs and arm mounts. I am, not use I want to use TI on the shocks , the transmission screws and the bumper screws. Anyway, if your looking for Ti screws for your car, the protek ones seem solid
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-18-2014, 10:49 PM   #7060
Tech Legend
Originally Posted by blingy View Post
WC you missed the point of the question
sorry bout that & missing your post here also.
I checked today the differences in the up travel .
The rear tower has about 3mm
The mid tower has less then 1mm but can still bottom out front of chassis.
Can say my ride landings off of the jumps was not changed or effected .
Handling and steering gain a huge improvement.
George W. Cherry
Old 08-19-2014, 03:37 AM   #7061
eper's Avatar
Trader Rating: 14 (100%+)
Thanks guys/gals!
Sounds like u may be on the wrong tires. And u may have a loose diff along with some tight suspension components. Best bet is to talk to one of the regulars and get them to look over your buggy and give u some pointers. Good luck and keep us posted.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 08-19-2014, 06:11 AM   #7062
shannow's Avatar
Thanks guys/gals!
I don't have the B5m yet (tomorrow hopefully) but what Lipo are you using ?
On loose track you may want saddles or the shorty fully at the back to gain weight at this end. That's an easy setup change. What ride height are you using ?
Jonathan
shannow is offline   Reply With Quote
Old 08-19-2014, 09:20 AM   #7063
Thnx WC that is what I was looking for
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 08-19-2014, 09:36 AM   #7064
Tech Legend
The set up with the flat arm & mid tower has to be one of the best improvements thus far.
1st mid tower & flat arm
2nd adding weight under short pack
All included with the Tacompton .2 set up.
George W. Cherry
Old 08-19-2014, 10:05 AM   #7065
Is there a setup section on this forum that I'm overlooking or something? I can't find any of these setups y'all are talking about.
Naxn is offline   Reply With Quote
