    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 08-17-2014, 09:57 AM   #7021
Tech Legend
Wild Cherry's Avatar
GTI
Yup, my Lunsford Ti rods has to be only reason cause nothing else is different on my ride.
Go figure ...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-17-2014, 09:57 AM   #7022
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by gticlay View Post
I do. You have properly sized Lunsford turnbuckles.
my lunsfords are 1 5/8 long. Not even close to causing a dimple. They all bind.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-17-2014, 10:14 AM   #7023
I've been through two sets of ball cups now and have not had any binding.
DWill is offline   Reply With Quote
Old 08-17-2014, 10:37 AM   #7024
Tech Legend
Will
Which Ti rod are you using ?
George W. Cherry
Old 08-17-2014, 10:47 AM   #7025
The b5 rear arms will give me more forward bite right ? Will they take away from my rotation ? the buggy is turning good but has horrible forward bite
evolution03 is offline   Reply With Quote
Old 08-17-2014, 11:09 AM   #7026
suby723's Avatar
Trader Rating: 21 (100%+)
More rotation more forward bite.
suby723 is offline   Reply With Quote
Old 08-17-2014, 11:44 AM   #7027
So it sounds like a win win situation thanks i will have to give them a try sometime
Old 08-17-2014, 12:00 PM   #7028
CaseyAnthonyFan's Avatar
Should I buy brass arm mounts C and D or alumunim? Im running Mod. when would I need one or other. Brass heavier i know right. So i can use it as a tuning option?
CaseyAnthonyFan is offline   Reply With Quote
Old 08-17-2014, 12:16 PM   #7029
Super Moderator
Trader Rating: 17 (100%+)
Depends on if you feel you need the extra weight. If you run on high bite, probably not. If you run on lower bite, probably a good idea.
I'm of the mindset now that if need to add 40 grams to the rear of the car, I'll just run rear motor. Call me crazy LOL
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-17-2014, 12:39 PM   #7030
Tech Legend
Using 2.7 oz extra weight under the short pack,not just for traction.
Also for a lower CG which helps smooth out the car on higher traction conditions.
George W. Cherry
Old 08-17-2014, 03:19 PM   #7031
i run square pack in mine it feels better than shorty probably because of low to medium traction. i put some weight on back of shock tower down low above rear suspension holder seemed to make the car not to want to turn kinda pushy
Old 08-17-2014, 03:54 PM   #7032
Did someone post a graphical comparison of the 2 front towers, i.e. showing the differences in shock mount positions...? I remember seeing one, just can't find it now...
B5M
22 2.0
B44.2
TC4
SC10 4x4
Pellefa is offline   Reply With Quote
Old 08-17-2014, 04:28 PM   #7033
Speed Freak RC's Avatar
I have 1 3/4" lunsfords on mine. All the stock cups were fine. Broke one turnbuckle, installed replacement with new rod ends and they bind.
Luckily a quick turn with a 5.7mm ball cup reamer and good to go.
Last time I will chime in about the rod ends.
Speed Freak RC is offline   Reply With Quote
Old 08-17-2014, 05:09 PM   #7034
Tech Legend
Using mid tower & flat front arm with inside hole, the
shocks are at the same angle as using rear motor tower middle hole.
Difference is the shocks are lower a couple mm with mid tower & inside tower hole.
Lower makes for lower CG on front .
Makes for smoother steering.
Sorry never seen that graph.
I just thought maybe you were interested.
George W. Cherry
Old 08-17-2014, 05:50 PM   #7035
TOO-TALL's Avatar
Where do you buy the thin sheets to fit under the battery?
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
crustyfeet
