    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-14-2014, 03:34 PM   #6871
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Wild Cherry View Post
Tonight
A Top K car driver little brother telling
him ...
George is catching you...
Braaaaaaaa!!!!!
Tacompton .2
Originally Posted by bilster44 View Post
I really do not understand why people just don't get it. The ball cups on our new cars are basically "eyelets" not cups like previous cars. Brand new ones can come a little out of round too. Even if your turn buckles are the "perfect" length, if you REALLY slam a pipe or have a BAD barrel roll, more times than not the eyelet/cup will distort in shape, causing a bind. If you take your pliers and give it a squeeze in the RIGHT place, bingo! Free as a bird again! No polishing and no rocket science involved either.
I have been trying to find the right spot for years. So I just polish my balls
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-14-2014, 04:24 PM   #6872
bilster44's Avatar
That "spot" certainly doesn't elude me.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 08-14-2014, 04:26 PM   #6873
bilster44's Avatar
Originally Posted by rc23 View Post
i agree with you.. to a point. Even with the perfect "pinch spot" (ive been doing that for 15 years on 1/8th scales) they still arent perfect without reaming the cups.
Depends on the cup, and it's overall condition I would think.
Old 08-14-2014, 04:28 PM   #6874
Trader Rating: 59 (100%+)
yes, im talking about AE cups specifically. And it also depends on the angle of the tie rod with ae cups which is why some are more bound than others
Ultimately its a pointless argument, as unless someone feels the difference between a reamed cup and non reamed cup they wont believe me. If we were in the same city i could easily prove to you that it does make a difference.
There are always people that go onto threads and claim theyve never had a problem. I saw the same thing in the Serpent thread where people were breaking chassis left and right and people would come in and say "you must drive it into a brick wall, ive never had a problem!!"
I hope one day AE will adjust their tolerance in the cups slightly so the average noob has less problems, until then ill try to advocate to people the 5 minute solution ive found to fix all their problems.
rc23 is offline   Reply With Quote
Old 08-14-2014, 04:52 PM   #6875
Trader Rating: 138 (100%+)
Tried that on the cups. didnt work
Worked on all 3 of my cars. Zero suspension bind now.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 08-14-2014, 05:36 PM   #6876
lol, I am 100% sure it would not make them free like the tlr cups in my video. I tried the pinch. it was marginal and didnt do what I wanted. Which is super free.
Old 08-14-2014, 08:31 PM   #6877
3srcracing's Avatar
Trader Rating: 25 (100%+)
So was finally able to try the exact same setup up in my mod and stock car, my stock car is still HOOKED up. My mod car is definitely better with the exact same setup!
So my question for you guys is if I am still looking for more traction what would you guys suggest me doing? (Mostly rear traction)
Setup link: https://onedrive.live.com/redir?resi...E89F581%211364
NOTE: I'm running 30/27.5wt oil now.
3srcracing is offline   Reply With Quote
Old 08-14-2014, 08:35 PM   #6878
Tech Legend
Wild Cherry's Avatar
Originally Posted by 3srcracing View Post
So my question for you guys is if I am still looking for more traction what would you guys suggest me doing? .
Start with the thin 1/24 lead piece under the shorty.(2.7oz)
If you do not wish to try the weight ?
Try inside hole on rear tower with 32.5 w
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-14-2014, 09:10 PM   #6879
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Jcozz View Post
Running b5m on indoor super high bite ozite carpet. Trying to get more on power steering and make it rotate faster. I'm running short short link on the rear hubs back in rear. Yellow rear spring grey front. 19mm rear ride height and 18mm front ride height. 1.6's all around 27.5/32.5. Proline tires all around. What do you guys think? Thanks!
What trailing axle?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 08-14-2014, 09:22 PM   #6880
Anyone got any ideas on carpet setup? Ran carpet for first time last night, had white rear springs and gray front, green roll bar, car was traction rolling coming into corner, tried going harder, went blue rear and red fronts trying the other 2 roll bars, seemed like it made it worse, everyone seems to be saying go harder for higher grip, but it seems like you can't get that slip by going harder on carpet, started to go softer and it was better, does this seem right or did I just not go hard enough?
Looked at heaps of different setups online, some brands of car are hard setup and some were quite soft with 2.0 springs on back and 2.16 on front.
Johnjoe38 is offline   Reply With Quote
Old 08-15-2014, 12:13 AM   #6881
ray_munday's Avatar
if its high grip carpet, try the following:
- add weight to the front (~50g) where you can in front of the servo. This smooths out corner entry and will reduce traction rolling. (The new AE brass front bulkhead will help).
- Ive preferred red front / white rear springs on carpet. Move the front shocks out on the tower.
- Run heavier damping. I used 37/32 with 1.6mm pistons.
- Keep the ride height low. 18mm is a good starting point.
- Gear diffs help on high grip. 3K-5K weight oil.
- Use the hard plastics if you have them.
The low profile stagger ribs smooth out the steering a lot (Schumacher or Proline).
Hope this helps. There are lots of other small changes you can make for carpet, but these seem to be the areas the car is most sensitive to.
Ray
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 08-15-2014, 05:06 AM   #6882
aeMatt's Avatar
For those experiencing ball-cup binding, recommend replacing stock studs with Lundsford Ti studs...problem solved
Team Associated\\\\\\Reedy\\\\\\JConcepts\\\\\\Airtronics\\\\\\Upgrade RC
www.rc10.com/www.jconcepts.net/www.airtronics.net/www.upgrade-rc.com
aeMatt is offline   Reply With Quote
Old 08-15-2014, 05:43 AM   #6883
Speed Freak RC's Avatar
I bought one of those 5.7mm reamers off ebay. My stock cups weren't that bad. I bought a replacement set since I snapped a Lunsford titanium turnbuckle in one (ball cup didn't even come off!) and they were tight. One spin with the reamer and they were butter. Found more than 1 spin was too much.
Wildcat1971- Glad the TLR cups work for you, but there's no way I am putting TLR parts on my car! haha
Speed Freak RC is offline   Reply With Quote
Old 08-15-2014, 05:57 AM   #6884
lol, I am not using the tlr cups. haha. but I am looking at trying the cup reamer.
Old 08-15-2014, 06:19 AM   #6885
Trader Rating: 20 (100%+)
I replaced my stock studs with the Lunsford's too and they are smooth. Before they were bound up like in Wildcats video.
The loosening could possibly be a result of the stretching caused by removing and replacing the ball cup ends, not 100% sure.
GTSSTANG is offline   Reply With Quote
