    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-11-2014, 09:25 AM   #6736
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Mizchief View Post
Does 21/81 sound about right for a 8.5 Tekin Gen 2 system? Gearing chart suggested 22t for a reedy 8.5. Main track is about mid-sized for an indoor track has a couple of spots you really need to accelerate quickly.
21-23 probably 22
ryanpatrickgore is offline   Reply With Quote
Old 08-11-2014, 09:25 AM   #6737
aw you beat me george
im gonna try that new front end setup on tuesday geo, gonna wrench tonight on it a bit. im excited to try it if its really that much better... my car was great before
Old 08-11-2014, 09:26 AM   #6738
kurtblastoff's Avatar
Trader Rating: 80 (100%+)
I just put these on my car. very good quality. hexes are nice and tight on my mip wrenches. They're not as bright as the lunsford but $35.00 cheaper.
Check them out. http://www.ebay.com/itm/Team-Associa...item20ea3317f3
Team Associated RC10 B5m Mid-Motor Thread-unnamed-36-.jpg   Team Associated RC10 B5m Mid-Motor Thread-unnamed-37-.jpg   Team Associated RC10 B5m Mid-Motor Thread-unnamed-38-.jpg   Team Associated RC10 B5m Mid-Motor Thread-unnamed-39-.jpg   Team Associated RC10 B5m Mid-Motor Thread-unnamed-40-.jpg
kurtblastoff is offline   Reply With Quote
Old 08-11-2014, 09:39 AM   #6739
Tech Legend
Wild Cherry's Avatar
The new Tacompton front end setup* is so good, anyone will appreciate.
Never ever had the car drive so good.
* exclusive and only here on RcTech ..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-11-2014, 10:15 AM   #6740
CaseyAnthonyFan's Avatar
I want to buy Brass arm mounts. can you please tell me the differences to the D and C mounts. like when I would want to use the D over the C etc . Thanks in advance.
CaseyAnthonyFan is offline   Reply With Quote
Old 08-11-2014, 10:24 AM   #6741
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
D is at the Back of the car, C is in front of the transmission. Put brass on both will add a lot of weight in the rear of the car. Traction should go up and probably more pendulum with the Brass D mount
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-11-2014, 10:28 AM   #6742
Originally Posted by Wildcat1971 View Post
D is at the Back of the car, D is in front of the transmission. Put brass on both will add a lot of weight in the rear of the car. Traction should go up and probably more pendulum with the Brass D mount
When is C used? and more pendulum? thanks
Old 08-11-2014, 10:37 AM   #6743
D, because the weight is on the back of the car. Some guys only run the C brass because it puts the weight where they feel is "ideal".
Old 08-11-2014, 11:12 AM   #6744
Super Moderator
Trader Rating: 17 (100%+)
he made a typo
AE uses the following setup on their 8th scale and the terminology carried over. A and B are the front of the car. C and D the rear. So if the car was sitting on the table pointing away from you, and you were looking down at it, it would be like this:
front of car
A
B
C
D
back of car
There's no 'B' on the 2wd cars. But the front brace is still referred to as the A mount.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is online now   Reply With Quote
Old 08-11-2014, 11:17 AM   #6745
lol, I typed D twice... fail.. fixed
Old 08-11-2014, 12:16 PM   #6746
MPrincip's Avatar
Talking Suspension Binding
Has any suffured from the Front End of the car binding towards the bottom the suspension as your compressing it?
I noticed it with mine yesterday at the track. AS the car set on the bench, pressed the front end down and when it almost hit the bench i noticed the suspension binding. (Like it was progressivly stiffer)
I took the shocks off and made sure there was no air in them and bleeded correctly.
I did this to some of the other associated cars and they all did the same thing!
However the Losi 22, Serpent, and Kyosho cars didn't do this.
Thoughts woudl be appreciated.
MIKE PRINCIPATO
TEAM ASSOCIATED/REEDY(1986-2005)
PROLINE RACING
MPrincip is offline   Reply With Quote
Old 08-11-2014, 12:32 PM   #6747
Trader Rating: 59 (100%+)
ballcups.. do it with the camber links off and see
rc23 is offline   Reply With Quote
Old 08-11-2014, 12:33 PM   #6748
Tech Legend
If nothing is bent , not binding .
Your just noticing the shock scub..
George W. Cherry
Old 08-11-2014, 12:41 PM   #6749
MPrincip's Avatar
Talking
I will double check those things..
I am wondering if it's engineered in the design of the car? I as have checked this on multiple B5M's and they all did the same thing.
Interesting... IF any tries it on there's please post if they have the same issue.
MIKE PRINCIPATO
PROLINE RACING
Old 08-11-2014, 01:57 PM   #6750
Send a message via ICQ to JiuHaWong
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
