    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-24-2014, 07:49 AM   #661
Send a message via Skype™ to Cody227
correct. They use the aluminium chassis because it is easier to find a stiff, durable and clean design.
RC8b SC ~ B5m ~ B4m ~ Mini-Z
Cody227 is offline   Reply With Quote
Old 01-24-2014, 08:01 AM   #662
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by archerwin View Post
Just curious, why does the team associated drivers in the Reedy Race continue to use the b4.2/c4 when there is already the b5/b5m?
I would assume that since this buggy has been announced they would be showcasing it in this important race.
from interview with kody at the reedy.
"Responsible for working on the Associated B5, asked why they arenít running the new car he said it was down to simply a lack of cars to distribute to their team drivers with only one full car currently in existence."
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-24-2014, 10:54 AM   #663
bilster44's Avatar
I want that mid motor...NOW!
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 01-24-2014, 11:17 AM   #664
gticlay's Avatar
Originally Posted by Davidka View Post
The graphite b4 chassis was too stiff so we know it's easy enough to make a stiff molded chassis and a flat aluminum plate with no bracing is quite flexy. I'd be interested to hear a more detailed explanation of the decisions.
I'm not a fan of aluminum chassis either (well, you don't sound like a fan of them anyway). One way to potentially build flex in would be to cut some thinner graphite chassis. We have a guy up here that does chassis so maybe I'll figure out a way to start a little new company for that kind of thing
gticlay is offline   Reply With Quote
Old 01-24-2014, 11:19 AM   #665
yeah, I am not a huge alum chassis fan either. they get tore up easily and most club racer never realize their issues are a tweaked chassis.
Old 01-24-2014, 11:22 AM   #666
I prefer good old carbon fiber. They can be as flimsy or as stiff as you need them to be with add on reinforcing ribs. I've got a pin router and make my own chassis. Using the bolt on B5 front nose plate would make that easy.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 01-24-2014, 11:27 AM   #667
are you going to mount the sidepods with the cf, or go completely custom? CF get tore up on my track. Lots of rocks in the dirt. last week a fist sized rock made its way on the straight away.
Old 01-24-2014, 11:30 AM   #668
Tech Legend
Wild Cherry's Avatar
Prefer the stiffer alloy because mid motor is designed for high traction .
If you need more grip using the rear motor car is the better solution .
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 01-24-2014, 11:34 AM   #669
I generally go completely custom on my cars. If they get torn up I'll just go back into the garage to make another! I generally tear more things up in the street at home than I do at a track. It'll be a while before I pick up a B5. I'm still working on my 210 which I know you hate!!! The funny thing is that by the time I'm done with it, it'll probably be the car they should have always built since I've changed quite a bit.
Old 01-24-2014, 11:39 AM   #670
yeah, the 210 is the least favorite 2wd that I have owned. I go back and forth on the rm vs mm. I am unsure which I will get first to do a shoot out with my current fav 2wd buggy.
Old 01-24-2014, 11:47 AM   #671
gticlay's Avatar
I hear you WC. I'm just saying three flex chassis could be made - one that is the stock flex but couldn't bend or tweak like al does, a stiffer one, and a more flexy one. And I am starting out with the RM but pretty sure I'll get both for next year.
Old 01-24-2014, 11:48 AM   #672
The funny thing about that car (210) is that I came to the conclusion a while back that for anything other than blinky mode that in rear motor a saddle configuration centered on the chassis was nice and in mid motor a saddle configuration against the motor was best. AE comes out with these cars and proves that I was on to something except they effectively turned the side by side saddle configuration by 90 degrees in RM mode. I couldn't make the car handle the way I wanted it to with a shorty and the car is already so heavy that if I had to use a long stick pack, I couldn't get the weight where I wanted it. I don't like the chassis with bolt on sides and it's thousand screws which clearly AE doesn't like either. AE has taken what I like about the 210 and integrated it into a better laid out car and chassis design. I still personally prefer to run 3 gear in MM mode and if I can't get the car to work run 3 gear RM. I just don't like MM4 so I'm a bit torn on which B5 as a result.
Old 01-24-2014, 11:58 AM   #673
maybe they will the the 4 gear right...soon we will fine out.
Old 01-24-2014, 12:11 PM   #674
onefast8's Avatar
Trader Rating: 41 (100%+)
What is with the steering links on both cars? The o-ring to prop up the swept forward outer ballcup just looks cheesy to me. I'm guessing they did that for the link to clear the front shock?
Jake R.
onefast8 is offline   Reply With Quote
Old 01-24-2014, 12:14 PM   #675
yeah, I believe so. there are other cars that do the same thing
