    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-09-2014, 09:30 AM   #6706
Send a message via ICQ to JiuHaWong
Originally Posted by QDRHRSE View Post
The B5 versions of pucks don't include a gear or rings.
Thank you for the information, that's what I thought when I looked up the kit. I had to verify to be sure I could use my bfast rings.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 08-09-2014, 03:22 PM   #6707
JatoTheRipper's Avatar
I have a question about the suggesting gearing in the manual.
I have a Turnigy TrackStar 10.5T/3730kV motor. The manual says to run 24/81 for a 10.5T Reedy motor, but a 21/81 with a 3300 or 3900 kV motor. I believe the Reedy 10.5T motor is a similar kV. Why would their gearing recommendations be contradictory?
Leaf Spring Mafia - Member #1
https://www.shapeways.com/shops/leafspringmafia
https://www.facebook.com/LeafSpringMafia
https://www.instagram.com/LeafSpringMafia
JatoTheRipper is online now   Reply With Quote
Old 08-09-2014, 03:44 PM   #6708
Rybeau40's Avatar
Originally Posted by Rybeau40 View Post
I have two questions:
1. How often do you guys change your Schelle slipper pads on the b5m
2. Are getting new front tires done as often as the rears?
Anyone plz?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 08-09-2014, 04:01 PM   #6709
Ostach24's Avatar
Trader Rating: 85 (100%+)
Finally got mine all wired up
Cobra Graphics
For all your graphic design needs.
CobraGraphics.net
Ostach24 is offline   Reply With Quote
Old 08-09-2014, 04:03 PM   #6710
Ostach24's Avatar
Just sprayed the body quick so I can use it until I get some time to do my nice one.
Cobra Graphics
CobraGraphics.net
Old 08-09-2014, 04:26 PM   #6711
Trader Rating: 34 (100%+)
Any need for the aluminum rear hubs for this car? I haven't seen much in this thread about the plastic ones breaking so is this a fluff part or the extra adjustments worth the cost.
GettinLapped is offline   Reply With Quote
Old 08-09-2014, 05:40 PM   #6712
Tech Legend
Wild Cherry's Avatar
Alloy hubs are stronger then the plastic, also the vertical stud allows more tuning options.
Only difference..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-09-2014, 05:53 PM   #6713
N4S
N4S's Avatar
Anyone plz?
Replace the pads when you see excess wear or decreased performance. My fronts last on average 3 x's longer than a set of rears.
N4S is offline   Reply With Quote
Old 08-09-2014, 06:04 PM   #6714
Anyone idea's I'm pushing in the corners.
Shaun L. Grider is offline   Reply With Quote
Old 08-09-2014, 08:36 PM   #6715
Ostach24's Avatar
Just got them bc they look nice, once you tweak the car how you need it to run fast you probably won't be adjusting much. Besides springs, oils and tires...
Cobra Graphics
CobraGraphics.net
Old 08-10-2014, 07:18 AM   #6716
Cridd's Avatar
Trader Rating: 16 (100%+)
From a quick tune guide
Intended goal = More on power steering
Lengthen front camber links
Raise front link on tower side and/or lower link on hub side Add more front caster/front kick up
Increase anti-squat
Reduce Ackermann angle
Move front shocks in on tower/rear shocks out on tower
Notes: As you tune for on power steering you'll likely see less off power steering. Also a car with lots of forward bite is going to progressively have a harder time maintaining on power steering as the rear wheels will fight to push straight forward.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 08-10-2014, 08:32 AM   #6717
Tech Legend
My B5M s dailed !!!!
Never driven better...
Car drives so sweet, now have new inspiration for victory.
Just saying......
George W. Cherry
Old 08-10-2014, 10:24 AM   #6718
Cridd's Avatar
Just saying......
Great news. What change?
Chris
B6D / T5M / SC5M
Old 08-10-2014, 11:08 AM   #6719
Tech Legend
We made a big improvement with the front end geometry.
My ride gained a huge improvement with corner stability & improved steering (more) ..
Its awesome .......
smoooth & fast car = good results
Latest tune trick from Tacompton
Posted all about a page back ..
George W. Cherry
Old 08-10-2014, 11:10 AM   #6720
3srcracing's Avatar
Trader Rating: 25 (100%+)
So I know this sounds like a stupid question, should my mod car be able to handle just like my mod car with the same power? Or will the two always feel pretty different?
My stock car is HOOKED up, I almost have that setup on my mod car but not quite yet. If I put the same setup on both cars should the drive similar even though they have such a power difference?
Thanks!
3srcracing is online now   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
hpiaddict
