    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 08-06-2014, 09:44 PM   #6661
SkiRideDrive's Avatar
Hello guys, I am looking to join the B5M party. I am located in North San Diego County and plan on running primarily at SDRC and occasionally at OCRC.
I have included a list of what I plan on getting to start off. Please chime in if you think I should change any items and anything I will need in addition to what I've listed below. Please keep in mind that I am starting from scratch. I have only run 1/8 nitro previously and sold off all of my rc related gear a while back.
Buggy: B5M
Radio: Aitronics MT4 (any suggestions for lipo for transmitter?)
Batteries: Promatch Shorty
Battery Charger/Power Supply: Icharger 206B Ticket Combo (Do I need any additional wires or leads?)
ESC: Hobbywing Justock
Motor: Schurspeed 17.5
Gearing: (any suggestions?)
Steering Servo: Savox SC-1258TG
Tires: Dirt Web - Gold
Spare Parts: (any suggestions?)
Spare Fastener Kit: (any suggestions?)
Shock Oil: (any suggestions?)
Setup Tools: (any suggestions?)
Tools/Allens/Wheelnuts: Was thinking MIP (any suggestions?)
Body Paint: Tamiya
Thanks in advance for your help! Let me know if you think I would need anything else. The only thing I really have already is a soldering iron.
SkiRideDrive is offline   Reply With Quote
Old 08-06-2014, 10:51 PM   #6662
Trader Rating: 486 (100%+)
Build the car and try it out with the box set up. Then you can ask locals about set up. After that you can decide which direction you want to go. I think most people running a B5M stock like them lighter than they come out of the box but some dont.
Those are both very competitive tracks. I like my B5M mid-weight. So if it was me I'd want to go lighter. Set up and weight will be very important. You shouldn't need a lot of spares. I'd buy a few things to shed some weight. Ti turnbuckles & front axles, exotek slipper eliminator, an aluminum screw kit, aluminum wheel nuts, and maybe a cf battery strap. If you don't have a budget maybe pucks too. Don't get me wrong, you can run the car as it comes just fine. As far as the charger goes, why not just but a icharger 406? I'd recommend a low profile servo for stock....Futaba or KO. Why not try an SMC lipo? I swear by them and they are very inexpensive. MIP tools are the best. I think for the money there is no better radio than the MT4, the only problem is that after you use it for a while and then try an M12, you'll hate yourself. I make these recommendations based on the fact that you're going to run stock and where you'll be running. I also don't claim to be be a pro or the fastest guy at any track. That being said I've tried it all and have gone as far as to mod my car and weigh it after making each mod....so what I've recommended is the best bank for your buck. I own everything that I've recommended except for the Icharger 406...I have the 410. You want to get crazy? Run the aka light weight wheels and tires too....I mostly run outdoors so I can't remember which ones. Typos with their special wheel (Evo?) that has the 1/8 scale style bead. Those are worth 40 grams alone.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 08-06-2014, 11:23 PM   #6663
Trader Rating: 138 (100%+)
Chalk me up to someone who does not like it light. I took both of my cars to LRH tonight. Added the Pucks system, milled motor plate, cut gears, all plastic suspension mounts, borrowed a set of broken in tires to try, and the thing still would go tail happy on me. Took my Shurr Speed out and put it in the mod car with all of the aluminum stuff in it was stuck to the track. Did not notice any appreciable speed decrease, and motor only came off 5 degrees warner which topped off at between 145-150 depending on run time. I wont be putting all of the stock stuff back in, but will definitely be running the stock top shaft instead of aluminum, will throw the aluminum hubs back in there, getting rid of the cut gears as well. I like the car better a bit butt heavy.
jpcopeland1 is offline   Reply With Quote
Old 08-07-2014, 12:01 AM   #6664
Trader Rating: 22 (96%+)
Buggy: B5M
Body Paint: Tamiya
savox 1258 doesnt work in the b5 from my experience, i would go wtrh a protek 100ss if i were you
dezertranger96 is offline   Reply With Quote
Old 08-07-2014, 04:46 AM   #6665
What experience have you had that makes you think it wont work? Glitching? Brown outs? My brother has this servo in a 22 with a Spektrum radio (old DX3R) and zero problems. I preffer the XP Digital servos myself.
Old 08-07-2014, 04:52 AM   #6666
Super Moderator
Trader Rating: 17 (100%+)
I've run the Futaba BLS 451 for over 2 years now. I also tried that Spektrum low pro servo and it was ok. No complaints. My buddy uses the Savox 1258 with no issues.
I think the days of 'omg don't run that servo' are long behind us. They are all pretty high quality now.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-07-2014, 06:27 AM   #6667
Trader Rating: 20 (100%+)
I have also used the Futaba BLS 451 for a very long time in several vehicles, they are great with zero issues.
I also, just purchased a SAVOX 1258 for a B4.2. It is a good servo, no glitches or brown outs, but at first it buzzed so much I thought it was broken.
GTSSTANG is offline   Reply With Quote
Old 08-07-2014, 06:28 AM   #6668
Wrong thread. Meant for the B5 RM thread...
Old 08-07-2014, 08:27 AM   #6669
wayboarder's Avatar
Trader Rating: 14 (100%+)
Brass...
wayboarder is offline   Reply With Quote
Old 08-07-2014, 09:02 AM   #6670
Buggy: B5M
Body Paint: Tamiya
3 things Skiride..
Your radio is a good choice but Airtronics just came out with the MT4s it is a hundred bucks more but it is well worth the money because it is just as fast as the M12 and the screen is backlit
HobbyWing is a great speedo no questions asked. But when it comes to Quality and ease of use and setup I love the Orion Thier brakes are super smooth and other guys at the track will have a program box you can use to set it up. They came out with the R10 stock for 129.00 bucks it goes down to a 5 turn motor it just doesnt have any boost settings
That charger is complete overkill My buddy and I have a Thunder Power AC/DC charger I got mine on ebay for 60 bucks, we charge at 6 to 7 amps and he finishes top 5 in the A. Im an old fart so i race for fun in Arizona
The main reason i bring this up is because I did this too when I first started and all too many times I have seen guys get into this with the cheapest equipment or sometimes the most expensive equipment and they realize it is not what they needed
Go with the stuff that is reliable and will take you beyond novice. i have been doing this for 25 yrs so I have seen alot of people make the wrong choices when it comes to speedo's and radios. They realize quickly that they cant be competitive with cheap equipment or the wrong equipment and have to buy it all over again
Bubonic-X is offline   Reply With Quote
Old 08-07-2014, 09:19 AM   #6671
Thanks for the help guys!
Any reason why I would need the 406 over the 206b? The cost goes up significantly so I was just curious of the advantages. I was planning on picking up two battery packs.
I will look into the low profile servos. I'm assuming this is for weight savings?
SMC seemed to be the battery of choice in my search as well, but they seem to be out of stock. Any sources where I can get them other than directly from smc?
Do you guys know which tools are required to work on the B5M? I was thinking the MIP metric hex set including 1.5, 2, and 2.5. I suppose I would need a wheel wrench. Any other suggestions?
I will look into this as well.
Thanks again.
Old 08-07-2014, 09:30 AM   #6672
Thanks for the info!
Originally Posted by Bubonic-X View Post
3 things Skiride..
I will check out the mt4s. Also, any recommendations on a type or size of lipo to fit into the mt4 or mt4s? I used to run AA's and would rather have a rechargeable option.
Thanks. My original thought was run the super inexpensive hobbywing for now until I learned more and decided if I wanted to run stock or mod. Also if I picked up another esc later, I could have the inexpensive hobbywing as a spare. I will check out that orion.
So I was originally planning on going with a 1/8th Mugen and was speccing chargers for that until I realized 1/8th ebuggy is not nearly as popular as 2wd buggy. Perhaps I can look into downsizing. I was considering the larger charger so I can still go 1/8th later and be able to charge 4s in a reasonable time.
Thanks for the advice.
Old 08-07-2014, 10:04 AM   #6673
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by PFKAOG View Post
The weeds in your yard getting too high?
That's called "fresh crop"
And being a groupie doesn't make you part of the band
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 08-07-2014, 10:30 AM   #6674
Jmuck69's Avatar
Watch out, he will report you.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 08-07-2014, 10:34 AM   #6675
Tech Legend
Wild Cherry's Avatar
Muck
Just sent ...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
