    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-30-2014, 06:58 PM   #6466
vito's Avatar
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 07-31-2014, 06:38 AM   #6467
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Po'boy needs some shoes!!
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 07-31-2014, 06:51 AM   #6468
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Looking good!
TRCR, ARC r11 TC, hobbywing V3.1, TLR 22SCT™ 2.0, Team associated b6 buggy, futaba 4PX, Axial Wraith, Glamis Uno, Icharger 308, Simple Green, USMC
kjohnsiii is offline   Reply With Quote
Old 07-31-2014, 09:33 AM   #6469
Konich's Avatar
Well after not racing for 6 months I decided to take the B5M out for the first time. I'm using Hartson's setup for most of the car and Caveleri's Alum hub setup. B5R front arms and shock tower along with the rear arms. Also put in the Alum top shaft, Losi 22 Alum Driveshafts, Acer thrust, Alum rear hubs, and X-rings. Stock configuration with a full Proteck square pack.
Qualified 3rd for the 13.5 A-main, bad driving on my part left me with a 5th place finish. Overall the only thing I'm going to change is going to a shorty back to help with a little acceleration. Other than that I wouldn't change a thing except for my poor driving.
https://www.youtube.com/watch?v=hl45...dLpALT3G_WEgOA
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 07-31-2014, 10:16 AM   #6470
Trader Rating: 15 (100%+)
What do the B5R rear arms do on this car in terms of handling characteristics?
Tommygun1 is offline   Reply With Quote
Old 07-31-2014, 10:25 AM   #6471
Tech Legend
Wild Cherry's Avatar
More traction..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-31-2014, 07:10 PM   #6472
Rybeau40's Avatar
Anyone using the brass arm mounts? Currently using the aluminum ones, but wondering if it's worth swapping to brass for more weight. Anyone have a grams comparison?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 07-31-2014, 08:06 PM   #6473
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
If I put pucks in, I might use the brass. right now, my car feel pretty planted. but that would change if I removed 25 grams out of the tranny
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-31-2014, 09:07 PM   #6474
TOO-TALL's Avatar
With the blue rear hubs.what hole should I put the ball stud in for a med to high traction track?
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
Old 07-31-2014, 09:31 PM   #6475
Tech Legend
Use
Inside camber hole on chassis , 2 mm under stud
Rear outside hole on hub, 3 mm under stud, use 8mm ball
George W. Cherry
Old 07-31-2014, 09:38 PM   #6476
Trader Rating: 71 (100%+)
I'm running the brass arm mounts. Don't have the exact weight difference number handy, but does add a good amount of weight over plastic or aluminum, and does so in likely the best possible position for the mid motor car.
negatv1 is offline   Reply With Quote
Old 07-31-2014, 09:47 PM   #6477
TOO-TALL's Avatar
Originally Posted by Wild Cherry View Post
Use
thanks......so as the traction goes away and the track gets slick.Move the camber link to the rear inside hole??
www.skyski.com
www.foilforum.com
Old 07-31-2014, 10:01 PM   #6478
Tech Legend
No, stay outside more traction then inside.
Do you have a good idea why the track becomes slick ?
George W. Cherry
Old 08-01-2014, 09:49 AM   #6479
TOO-TALL's Avatar
The track dries out
Old 08-01-2014, 09:50 AM   #6480
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
drove the car lastnight and it was a blast. better than my old rb6 i believe. at the end of the night I added the weight under the shorty (thin lead) and it was definately an improvement! more stable for sure. lap times started dropping. end of the night the rc gods gave me some good karma and my good buddy dropped a grip of parts on my pit table for me! black alum hubs, and all the hard parts plus some extra spares! wow. christmas in july.
car is dialed
ryanpatrickgore is offline   Reply With Quote
